static void _DrawWindow3(WM_HWIN hWindows3)
WM_HWIN hItem ;
hItem = TEXT_CreateEx(0, 0, 180, 70, hWindows3, WM_CF_SHOW|WM_CF_MEMDEV, ID_TEXT3_0,TEXT_CF_LEFT, "工艺设置");
TEXT_SetTextAlign(hItem, GUI_TA_LEFT | GUI_TA_VCENTER);
TEXT_SetFont(hItem, &GUI_FontYahei);
TEXT_SetBkColor(hItem,0x800080);
hItem = EDIT_CreateEx(0, 450, 360, 30, hWindows3, WM_CF_SHOW|WM_CF_MEMDEV, 0, ID_EDIT3_0, 10);
EDIT_SetText(hItem, "");
EDIT_SetFont(hItem, &GUI_FontYahei);
EDIT_SetBkColor(hItem,1,GUI_GRAY);
hItem = EDIT_CreateEx(360, 450, 200, 30, hWindows3, WM_CF_SHOW|WM_CF_MEMDEV, 0, ID_EDIT3_1, 10);
hItem = EDIT_CreateEx(560, 450, 120, 30, hWindows3, WM_CF_SHOW|WM_CF_MEMDEV, 0, ID_EDIT3_2, 10);
EDIT_SetText(hItem, "软件版本");
hItem = EDIT_CreateEx(680, 450, 120, 30, hWindows3, WM_CF_SHOW|WM_CF_MEMDEV, 0, ID_EDIT3_3, 10);
EDIT_SetText(hItem, "1.0");
//line--1
hItem = TEXT_CreateEx(0, 82, 180, 40, hWindows3, WM_CF_SHOW|WM_CF_MEMDEV, ID_TEXT3_1,TEXT_CF_LEFT, "加捻方向");
hItem = EDIT_CreateEx(180, 82, 120, 40, hWindows3, WM_CF_SHOW|WM_CF_MEMDEV, 0, ID_EDIT3_4, 10);
hItem = TEXT_CreateEx(420, 82, 120, 40, hWindows3, WM_CF_SHOW|WM_CF_MEMDEV, ID_TEXT3_2,TEXT_CF_LEFT, "纱线支数");
hItem = BUTTON_CreateEx(540, 82, 60, 40, hWindows3, WM_CF_SHOW|WM_CF_MEMDEV, 0, ID_BUTTON3_0);
BUTTON_SetText(hItem, "公制");
BUTTON_SetFont(hItem, &GUI_FontYahei);
hItem = EDIT_CreateEx(600, 82, 120, 40, hWindows3, WM_CF_SHOW|WM_CF_MEMDEV, 0, ID_EDIT3_5, 10);
//line2
hItem = TEXT_CreateEx(0, 134, 180, 40, hWindows3, WM_CF_SHOW|WM_CF_MEMDEV, ID_TEXT3_3,TEXT_CF_LEFT, "捻度");
hItem = EDIT_CreateEx(180, 134, 120, 40, hWindows3, WM_CF_SHOW|WM_CF_MEMDEV, 0, ID_EDIT3_6, 10);
hItem = TEXT_CreateEx(300, 134, 120, 40, hWindows3, WM_CF_SHOW|WM_CF_MEMDEV, ID_TEXT3_4,TEXT_CF_LEFT, "T/m");
hItem = TEXT_CreateEx(420, 134, 120, 40, hWindows3, WM_CF_SHOW|WM_CF_MEMDEV, ID_TEXT3_5,TEXT_CF_LEFT, "纱线定长");
hItem = EDIT_CreateEx(600, 134, 120, 40, hWindows3, WM_CF_SHOW|WM_CF_MEMDEV, 0, ID_EDIT3_7, 10);
hItem = TEXT_CreateEx(720, 134, 120, 40, hWindows3, WM_CF_SHOW|WM_CF_MEMDEV, ID_TEXT3_6,TEXT_CF_LEFT, "m");
//line3
hItem = TEXT_CreateEx(0, 186, 180, 40, hWindows3, WM_CF_SHOW|WM_CF_MEMDEV, ID_TEXT3_7,TEXT_CF_LEFT, "锭速");
hItem = EDIT_CreateEx(180, 186, 120, 40, hWindows3, WM_CF_SHOW|WM_CF_MEMDEV, 0, ID_EDIT3_8, 10);
hItem = TEXT_CreateEx(300, 186, 120, 40, hWindows3, WM_CF_SHOW|WM_CF_MEMDEV, ID_TEXT3_8,TEXT_CF_LEFT, "r/min");
hItem = TEXT_CreateEx(420, 186, 120, 40, hWindows3, WM_CF_SHOW|WM_CF_MEMDEV, ID_TEXT3_9,TEXT_CF_LEFT, "长度修正系数");
hItem = EDIT_CreateEx(600, 186, 120, 40, hWindows3, WM_CF_SHOW|WM_CF_MEMDEV, 0, ID_EDIT3_9, 10);
//line4
hItem = TEXT_CreateEx(0, 238, 180, 40, hWindows3, WM_CF_SHOW|WM_CF_MEMDEV, ID_TEXT3_10,TEXT_CF_LEFT, "卷绕速度");
hItem = EDIT_CreateEx(180, 238, 120, 40, hWindows3, WM_CF_SHOW|WM_CF_MEMDEV, 0, ID_EDIT3_10, 10);
hItem = TEXT_CreateEx(300, 238, 120, 40, hWindows3, WM_CF_SHOW|WM_CF_MEMDEV, ID_TEXT3_11,TEXT_CF_LEFT, "r/min");
hItem = TEXT_CreateEx(420, 238, 120, 40, hWindows3, WM_CF_SHOW|WM_CF_MEMDEV, ID_TEXT3_12,TEXT_CF_LEFT, "整车锭数");
hItem = EDIT_CreateEx(600, 238, 120, 40, hWindows3, WM_CF_SHOW|WM_CF_MEMDEV, 0, ID_EDIT3_11, 10);
//line5
hItem = TEXT_CreateEx(0, 290, 180, 40, hWindows3, WM_CF_SHOW|WM_CF_MEMDEV, ID_TEXT3_13,TEXT_CF_LEFT, "卷绕电机频率");
hItem = EDIT_CreateEx(180, 290, 120, 40, hWindows3, WM_CF_SHOW|WM_CF_MEMDEV, 0, ID_EDIT3_12, 10);
hItem = TEXT_CreateEx(300, 290, 120, 40, hWindows3, WM_CF_SHOW|WM_CF_MEMDEV, ID_TEXT3_14,TEXT_CF_LEFT, "Hz");
hItem = TEXT_CreateEx(420, 290, 120, 40, hWindows3, WM_CF_SHOW|WM_CF_MEMDEV, ID_TEXT3_15,TEXT_CF_LEFT, "纱筒重量");
hItem = EDIT_CreateEx(600, 290, 120, 40, hWindows3, WM_CF_SHOW|WM_CF_MEMDEV, 0, ID_EDIT3_13, 10);
hItem = TEXT_CreateEx(720, 290, 120, 40, hWindows3, WM_CF_SHOW|WM_CF_MEMDEV, ID_TEXT3_16,TEXT_CF_LEFT, "kg");
//line6
hItem = TEXT_CreateEx(0, 342, 180, 40, hWindows3, WM_CF_SHOW|WM_CF_MEMDEV, ID_TEXT3_17,TEXT_CF_LEFT, "加捻电机频率");
hItem = EDIT_CreateEx(180, 342, 120, 40, hWindows3, WM_CF_SHOW|WM_CF_MEMDEV, 0, ID_EDIT3_14, 10);
hItem = TEXT_CreateEx(300, 342, 120, 40, hWindows3, WM_CF_SHOW|WM_CF_MEMDEV, ID_TEXT3_18,TEXT_CF_LEFT, "Hz");
hItem = TEXT_CreateEx(420, 342, 120, 40, hWindows3, WM_CF_SHOW|WM_CF_MEMDEV, ID_TEXT3_19,TEXT_CF_LEFT, "台产量");
hItem = EDIT_CreateEx(600, 342, 120, 40, hWindows3, WM_CF_SHOW|WM_CF_MEMDEV, 0, ID_EDIT3_15, 10);
hItem = TEXT_CreateEx(720, 342, 120, 40, hWindows3, WM_CF_SHOW|WM_CF_MEMDEV, ID_TEXT3_20,TEXT_CF_LEFT, "kg/h");
//line7
hItem = TEXT_CreateEx(0, 394, 180, 40, hWindows3, WM_CF_SHOW|WM_CF_MEMDEV, ID_TEXT3_21,TEXT_CF_LEFT, "任务完成后关机");
hItem = TEXT_CreateEx(180, 394, 120, 40, hWindows3, WM_CF_SHOW|WM_CF_MEMDEV, ID_TEXT3_22,TEXT_CF_LEFT, "关闭");
hItem = BUTTON_CreateEx(300, 394, 60, 40, hWindows3, WM_CF_SHOW|WM_CF_MEMDEV, 0, ID_BUTTON3_1);
BUTTON_SetText(hItem, "设置");
//button
hItem = BUTTON_CreateEx(350, 10, 150, 50, hWindows3, WM_CF_SHOW|WM_CF_MEMDEV, 0, ID_BUTTON3_2);
BUTTON_SetText(hItem, "导纱机构设置");
hItem = BUTTON_CreateEx(600, 10, 120, 50, hWindows3, WM_CF_SHOW|WM_CF_MEMDEV, 0, ID_BUTTON3_3);
BUTTON_SetText(hItem, "返回");
static void _cbWindow3(WM_MESSAGE* pMsg)
WM_HWIN hItem = pMsg->hWin;
switch (pMsg->MsgId)
case WM_CREATE:
/* 创建后设置聚焦 */
// WM_SetFocus(hItem);
case WM_KEY:
switch (((WM_KEY_INFO*)(pMsg->Data.p))->Key)
case GUI_KEY_ESCAPE:
GUI_EndDialog(hItem, 1);
case GUI_KEY_TAB:
WM_SetFocusOnNextChild(hItem);
case WM_PAINT:
GUI_RECT r;
WM_GetClientRect(&r);
GUI_SetBkColor(GUI_LIGHTGRAY);
GUI_Clear();
_DrawUpRectEx(&WIDGET_Effect_3D2L, &r);
_DrawWindow3(pMsg->hWin);
case WM_NOTIFY_PARENT:
if (pMsg->Data.v == WM_NOTIFICATION_RELEASED)
int Id = WM_GetId(pMsg->hWinSrc);
switch (Id)
case ID_BUTTON3_0:
case ID_BUTTON3_1: //关闭
case ID_EDIT3_2:
case ID_BUTTON3_3: //返回
default:
WM_DefaultProc(pMsg);
WM_HWIN CreateWindow3(void)
hWin =WM_CreateWindow(0, 0, 800, 480, WM_CF_SHOW|WM_CF_MEMDEV, _cbWindow3, 0);
return hWin;
while(1){
GUI_Delay(50);
ii++;
if(ii>=1000) ii=0;
for(iii=ID_EDIT3_4;iii<ID_EDIT3_4+12;iii++)
hMulti = WM_GetDialogItem(WM_GetClientWindow(hWin), iii);
EDIT_SetFloatMode(hMulti,ii,0,1000,0,GUI_EDIT_SUPPRESS_LEADING_ZEROES);
上面的这个例子我操作的时候,点解任何一个ID_BUTTON3_1的时候,会出现一个现象导致EDIT里面的值都不显示了。是什么原因。 |
