查看: 4718|回复: 3
发布一个在读写sd卡时,此时sd卡拔出造成死机的处理方法
发表于 2016-3-27 15:06:57 | 显示全部楼层 |阅读模式
发布一个在读写sd卡时,此时sd卡拔出造成死机的处理方法,同时也在此记录一下,以备后用及有需要人们参考 。
stm32f4xx_hal_sd.c
红色的代码是增加上去的
函数名称: static HAL_SD_ErrorTypedef SD_CmdResp1Error(SD_HandleTypeDef *hsd, uint8_t SD_CMD)
  * @brief  Checks for error conditions for R1 response.
  * @param  hsd: SD handle
  * @param  SD_CMD: The sent command index
  * @retval SD Card error state
  HAL_SD_ErrorTypedef errorstate = SD_OK;
  uint32_t response_r1;
        uint32_t  cc = 0;
  while(!__HAL_SD_SDIO_GET_FLAG(hsd, SDIO_FLAG_CCRCFAIL | SDIO_FLAG_CMDREND | SDIO_FLAG_CTIMEOUT))
                if(++cc > 0x1ffff)                        // 自己加上去的,防止sd卡拔出后在此死循环造成死机
        if(cc >= 0x1ffff)
                printf("\r\n获取 SD 状态错误/超时,退出 ... ");                        // sd卡错误或者sd卡拔出
                return SD_DATA_TIMEOUT;
  if(__HAL_SD_SDIO_GET_FLAG(hsd, SDIO_FLAG_CTIMEOUT))
    errorstate = SD_CMD_RSP_TIMEOUT;
    __HAL_SD_SDIO_CLEAR_FLAG(hsd, SDIO_FLAG_CTIMEOUT);
    return errorstate;
  else if(__HAL_SD_SDIO_GET_FLAG(hsd, SDIO_FLAG_CCRCFAIL))
    errorstate = SD_CMD_CRC_FAIL;
    __HAL_SD_SDIO_CLEAR_FLAG(hsd, SDIO_FLAG_CCRCFAIL);
    return errorstate;
  /* Check response received is of desired command */
  if(SDIO_GetCommandResponse(hsd->Instance) != SD_CMD)
    errorstate = SD_ILLEGAL_CMD;
    return errorstate;
  /* Clear all the static flags */
  __HAL_SD_SDIO_CLEAR_FLAG(hsd, SDIO_STATIC_FLAGS);
  /* We have received response, retrieve it for analysis  */
  response_r1 = SDIO_GetResponse(SDIO_RESP1);
  if((response_r1 & SD_OCR_ERRORBITS) == SD_ALLZERO)
    return errorstate;
  if((response_r1 & SD_OCR_ADDR_OUT_OF_RANGE) == SD_OCR_ADDR_OUT_OF_RANGE)
    return(SD_ADDR_OUT_OF_RANGE);
  if((response_r1 & SD_OCR_ADDR_MISALIGNED) == SD_OCR_ADDR_MISALIGNED)
    return(SD_ADDR_MISALIGNED);
  if((response_r1 & SD_OCR_BLOCK_LEN_ERR) == SD_OCR_BLOCK_LEN_ERR)
    return(SD_BLOCK_LEN_ERR);
  if((response_r1 & SD_OCR_ERASE_SEQ_ERR) == SD_OCR_ERASE_SEQ_ERR)
    return(SD_ERASE_SEQ_ERR);
  if((response_r1 & SD_OCR_BAD_ERASE_PARAM) == SD_OCR_BAD_ERASE_PARAM)
    return(SD_BAD_ERASE_PARAM);
  if((response_r1 & SD_OCR_WRITE_PROT_VIOLATION) == SD_OCR_WRITE_PROT_VIOLATION)
    return(SD_WRITE_PROT_VIOLATION);
  if((response_r1 & SD_OCR_LOCK_UNLOCK_FAILED) == SD_OCR_LOCK_UNLOCK_FAILED)
    return(SD_LOCK_UNLOCK_FAILED);
  if((response_r1 & SD_OCR_COM_CRC_FAILED) == SD_OCR_COM_CRC_FAILED)
    return(SD_COM_CRC_FAILED);
  if((response_r1 & SD_OCR_ILLEGAL_CMD) == SD_OCR_ILLEGAL_CMD)
    return(SD_ILLEGAL_CMD);
  if((response_r1 & SD_OCR_CARD_ECC_FAILED) == SD_OCR_CARD_ECC_FAILED)
    return(SD_CARD_ECC_FAILED);
  if((response_r1 & SD_OCR_CC_ERROR) == SD_OCR_CC_ERROR)
    return(SD_CC_ERROR);
  if((response_r1 & SD_OCR_GENERAL_UNKNOWN_ERROR) == SD_OCR_GENERAL_UNKNOWN_ERROR)
    return(SD_GENERAL_UNKNOWN_ERROR);
  if((response_r1 & SD_OCR_STREAM_READ_UNDERRUN) == SD_OCR_STREAM_READ_UNDERRUN)
    return(SD_STREAM_READ_UNDERRUN);
  if((response_r1 & SD_OCR_STREAM_WRITE_OVERRUN) == SD_OCR_STREAM_WRITE_OVERRUN)
    return(SD_STREAM_WRITE_OVERRUN);
  if((response_r1 & SD_OCR_CID_CSD_OVERWRITE) == SD_OCR_CID_CSD_OVERWRITE)
    return(SD_CID_CSD_OVERWRITE);
  if((response_r1 & SD_OCR_WP_ERASE_SKIP) == SD_OCR_WP_ERASE_SKIP)
    return(SD_WP_ERASE_SKIP);
  if((response_r1 & SD_OCR_CARD_ECC_DISABLED) == SD_OCR_CARD_ECC_DISABLED)
    return(SD_CARD_ECC_DISABLED);
  if((response_r1 & SD_OCR_ERASE_RESET) == SD_OCR_ERASE_RESET)
    return(SD_ERASE_RESET);
  if((response_r1 & SD_OCR_AKE_SEQ_ERROR) == SD_OCR_AKE_SEQ_ERROR)
    return(SD_AKE_SEQ_ERROR);
  return errorstate;
发表于 2016-3-28 09:16:19 | 显示全部楼层
如果在写的时候,拔出来了,会不会造成FATFS文件系统崩溃?
 楼主| 发表于 2016-3-28 13:49:52 | 显示全部楼层
回 mewan 的帖子
mewan:如果在写的时候,拔出来了,会不会造成FATFS文件系统崩溃? (2016-03-28 09:16)
应该不会吧,反正每次读写前都是需要重新挂载系统的
发表于 2016-3-28 17:52:42 | 显示全部楼层
回 hpdell 的帖子
hpdell:应该不会吧,反正每次读写前都是需要重新挂载系统的 (2016-03-28 13:49)
你的每次读写之前都重挂载一次文件系统??不是一次挂载多次使用??
GMT+8, 2025-5-9 21:58 , Processed in 0.383046 second(s), 23 queries .
