我用guibuiler創建一button 希望按壓時能改變 button之背景色 但一直無法實現
附上生成原碼 請幫我看看哪裡不對 標註(1) (2) 是我添加 謝謝
#include <stddef.h>
#include "GUI.h"
#include "DIALOG.h"
#include "WM.h"
#include "BUTTON.h"
#include "CHECKBOX.h"
#include "DROPDOWN.h"
#include "EDIT.h"
#include "FRAMEWIN.h"
#include "LISTBOX.h"
#include "MULTIEDIT.h"
#include "RADIO.h"
#include "SLIDER.h"
#include "TEXT.h"
#include "ROGBAR.h"
#include "SCROLLBAR.h"
#include "LISTVIEW.h"
//EventsFunctionList
void OnButtonClicked(WM_MESSAGE * pMsg);
void OnButtonReleased(WM_MESSAGE * pMsg);
void OnButtonMovedOut(WM_MESSAGE * pMsg);
//EndofEventsFunctionList
* static data
* Dialog resource
* This table conatins the info required to create the dialog.
* It has been created by ucGUIbuilder.
{ FRAMEWIN_CreateIndirect, "BTN_TEST1", 0, 0, 0, 800,480,FRAMEWIN_CF_MOVEABLE,0},
{ BUTTON_CreateIndirect, "OK", GUI_ID_BUTTON0, 274,146,177,114,0,0}
** FunctionName:void PaintDialog(WM_MESSAGE * pMsg)
** Function: to initialize the Dialog items
** call this function in _cbCallback --> WM_PAINT
WM_HWIN hWin = pMsg->hWin;
** FunctionName:void InitDialog(WM_MESSAGE * pMsg)
** call this function in _cbCallback --> WM_INIT_DIALOG
//FRAMEWIN
FRAMEWIN_SetClientColor(hWin,0x00ffff);
FRAMEWIN_SetFont(hWin,&GUI_Font24B_ASCII);
FRAMEWIN_SetTextAlign(hWin,GUI_TA_VCENTER|GUI_TA_CENTER);
FRAMEWIN_AddCloseButton(hWin, FRAMEWIN_BUTTON_RIGHT, 0);
FRAMEWIN_AddMaxButton(hWin, FRAMEWIN_BUTTON_RIGHT, 1);
FRAMEWIN_AddMinButton(hWin, FRAMEWIN_BUTTON_RIGHT, 2);
FRAMEWIN_SetTitleHeight(hWin,24);
//GUI_ID_BUTTON0
BUTTON_SetBkColor(WM_GetDialogItem(hWin,GUI_ID_BUTTON0),BUTTON_CI_UNPRESSED,0xc00000);
BUTTON_SetBkColor(WM_GetDialogItem(hWin,GUI_ID_BUTTON0),BUTTON_CI_PRESSED,0xe0e0e0);
BUTTON_SetTextColor(WM_GetDialogItem(hWin,GUI_ID_BUTTON0),BUTTON_CI_UNPRESSED,0x80ffff);
BUTTON_SetFont(WM_GetDialogItem(hWin,GUI_ID_BUTTON0),&GUI_Font32B_ASCII);
* Dialog callback routine
static void _cbCallback(WM_MESSAGE * pMsg)
int NCode, Id;
switch (pMsg->MsgId)
case WM_PAINT:
PaintDialog(pMsg);
case WM_INIT_DIALOG:
InitDialog(pMsg);
case WM_KEY:
switch (((WM_KEY_INFO*)(pMsg->Data.p))->Key)
case GUI_KEY_ESCAPE:
GUI_EndDialog(hWin, 1);
case GUI_KEY_ENTER:
GUI_EndDialog(hWin, 0);
case WM_NOTIFY_PARENT:
Id = WM_GetId(pMsg->hWinSrc);
NCode = pMsg->Data.v;
switch (Id)
case GUI_ID_OK:
if(NCode==WM_NOTIFICATION_RELEASED)
case GUI_ID_CANCEL:
case GUI_ID_BUTTON0:
switch(NCode)
case WM_NOTIFICATION_CLICKED:
BUTTON_SetBkColor(WM_GetDialogItem(hWin,GUI_ID_BUTTON0),BUTTON_CI_PRESSED,0xe0e0e0); //---- (1)
// OnButtonClicked(pMsg);
BUTTON_SetBkColor(WM_GetDialogItem(hWin,GUI_ID_BUTTON0),BUTTON_CI_UNPRESSED,0xc00000); //---(2)
// OnButtonReleased(pMsg);
case WM_NOTIFICATION_MOVED_OUT:
// OnButtonMovedOut(pMsg);
default:
WM_DefaultProc(pMsg);
* MainTask
void MainTask(void)
GUI_Init();
WM_SetDesktopColor(GUI_WHITE); /* Automacally update desktop window */
WM_SetCreateFlags(WM_CF_MEMDEV); /* Use memory devices on all windows to avoid flicker */
//PROGBAR_SetDefaultSkin(PROGBAR_SKIN_FLEX);
//FRAMEWIN_SetDefaultSkin(FRAMEWIN_SKIN_FLEX);
//BUTTON_SetDefaultSkin(BUTTON_SKIN_FLEX);
//CHECKBOX_SetDefaultSkin(CHECKBOX_SKIN_FLEX);
//DROPDOWN_SetDefaultSkin(DROPDOWN_SKIN_FLEX);
//SCROLLBAR_SetDefaultSkin(SCROLLBAR_SKIN_FLEX);
//SLIDER_SetDefaultSkin(SLIDER_SKIN_FLEX);
//HEADER_SetDefaultSkin(HEADER_SKIN_FLEX);
//RADIO_SetDefaultSkin(RADIO_SKIN_FLEX);
while(1)
GUI_ExecDialogBox(_aDialogCreate, GUI_COUNTOF(_aDialogCreate), &_cbCallback, 0, 0, 0);
GUI_Delay(500);
