查看: 3846|回复: 3
[emWin] STemWin教程第34章一个例程没有跑起来不知什么原因
发表于 2015-5-18 17:46:37 | 显示全部楼层 |阅读模式
按照例程,说是500ms轮流切换颜色,可是我按例程做的只切换一次。
void MainTask(void)
        WM_HWIN hDlg;
    GUI_Init();
    WM_SetDesktopColor(GUI_WHITE);      /* Automacally update desktop window */
    WM_SetCreateFlags(WM_CF_MEMDEV);  /* Use memory devices on all windows to avoid flicker */
    //PROGBAR_SetDefaultSkin(PROGBAR_SKIN_FLEX);
    //FRAMEWIN_SetDefaultSkin(FRAMEWIN_SKIN_FLEX);
    //BUTTON_SetDefaultSkin(BUTTON_SKIN_FLEX);
    //CHECKBOX_SetDefaultSkin(CHECKBOX_SKIN_FLEX);
    //DROPDOWN_SetDefaultSkin(DROPDOWN_SKIN_FLEX);
    //SCROLLBAR_SetDefaultSkin(SCROLLBAR_SKIN_FLEX);
    //SLIDER_SetDefaultSkin(SLIDER_SKIN_FLEX);
    //HEADER_SetDefaultSkin(HEADER_SKIN_FLEX);
    //RADIO_SetDefaultSkin(RADIO_SKIN_FLEX);
    //GUI_ExecDialogBox(_aDialogCreate, GUI_COUNTOF(_aDialogCreate), &_cbCallback, 0, 0, 0);
    hDlg = GUI_CreateDialogBox(_aDialogCreate,GUI_COUNTOF(_aDialogCreate),&_cbCallback,0,0,0);
    while(1)
        WM_SendMessageNoPara(WM_GetClientWindow(hDlg),WM_UPDATE);
        GUI_Delay(500);
发表于 2015-5-18 18:22:22 | 显示全部楼层
楼主你发个完整点的代码,我看看。
 楼主| 发表于 2015-5-18 21:56:44 | 显示全部楼层
可以了,在Dialog callback routine 中  要WM_GetClientWindow(hWin),而不能直接写hWin
case WM_UPDATE:
                    ucBackColor++;
                    if(ucBackColor >= 3){ucBackColor = 0;}
                        WM_InvalidateWindow(WM_GetClientWindow(hWin));
发表于 2015-5-18 22:18:09 | 显示全部楼层
回 zerone 的帖子
zerone:可以了,在Dialog callback routine 中  要WM_GetClientWindow(hWin),而不能直接写hWin
case WM_UPDATE:
                    ucBackColor++;
  &nb .. (2015-05-18 21:56)
[s:151]
GMT+8, 2025-5-12 16:18 , Processed in 0.363610 second(s), 24 queries .
