查看: 3121|回复: 0
[技术分享] 分享一个测试NB73物联网模块的Lua脚本
发表于 2021-7-28 10:00:03 | 显示全部楼层 |阅读模式
NB73.lua (2.06 KB, 下载次数: 4)
接线方法:
  TOOL      NB73
    TVCC  --- VCC
    GND    --- GND
    TTLTX --- RX
    TTLRX --- TX
测试说明:
   1、缺省9600波特率,AT指令集
   2、依次发AT指令查询模块编号、SIM卡号、信号质量
   3、返回结果中搜索OK判断成功与否
   4、判断信号RSSI范围(小于25)
   5、可显示模块电流,如有需要可对电流范围进行判断
Lua程序:
--F01=自动测试,TestNB73()
beep()
--成功叫一声,失败叫三声
function TestErr(void)
  print("测试失败")
  beep()
  delayms(100)
  beep()
  delayms(100)
  beep()
end
function TestOk(void)
  print("测试通过")
  beep()
end
--测试NB73硬件功能
function TestNB73(void)
  local COM_485 = 1
  local Parity = 0
  local DataBits = 8
  local StopBits = 1
  local tx_str
  local rx_str
  local rx_len
  local str
  local curr
  local volt
  local ret = "OK"
  local pos
  local rssi = 99
  print("开始测试NB73")
  beep()
  write_reg16(0x01FF,2) --启动ADC模式2,低速扫描测电流
  uart_cfg(COM_485, 9600, Parity, DataBits, StopBits)
  volt = read_analog(4)
  curr = read_analog(5)
  str = string.format("电压 %0.1fV 电流 %0.1fmA", volt, curr)
  print(str)
  print("1.查询IEMI")
  tx_str = "AT+CGSN=1\r\n"
  uart_send(COM_485, tx_str)
  rx_len, rx_str = uart_recive(COM_485, 100, 100)
  print(tx_str..rx_str)
  if (string.find(rx_str,'OK') == nil) then
    ret = "ERROR"
    goto quit_err
  end
  print("2.查询SN")
  tx_str = "AT+SN\r\n"
    ret = "ERROR"
    goto quit_err
  end
  print("3.查询智能卡号")
  tx_str = "AT+NCCID?\r\n"
    ret = "ERROR"
    goto quit_err
  end
  print("4.查询信号质量")
  tx_str = "AT+CSQ\r\n"
    ret = "ERROR"
    goto quit_err
  end
  --判断信号质量
  pos = string.find(rx_str,'+CSQ:')
  if (pos  ~= nil) then
    rx_str = string.sub(rx_str, pos + 5, pos + 6)
    rssi = tonumber(rx_str)
    print("rssi = ", rssi)
    goto quit_err
  end
  if (rssi > 25) then
    print("信号质量很差")
    goto quit_err
  end
::quit_err::
  if (ret == "OK") then
    TestOk()
    TestErr()
  end
  return ret
end
运行结果:
GMT+8, 2025-6-6 10:23 , Processed in 0.282806 second(s), 26 queries .
