代码:
- /* Use of CMSIS compiler intrinsics for register exclusive access */
- /* Atomic 32-bit register access macro to set one or several bits */
- #define ATOMIC_SET_BIT(REG, BIT) \
- do { \
- uint32_t val; \
- do { \
- val = __LDREXW((__IO uint32_t *)&(REG)) | (BIT); \
- } while ((__STREXW(val,(__IO uint32_t *)&(REG))) != 0U); \
- } while(0)
- /* Atomic 32-bit register access macro to clear one or several bits */
- #define ATOMIC_CLEAR_BIT(REG, BIT) \
- do { \
- uint32_t val; \
- do { \
- val = __LDREXW((__IO uint32_t *)&(REG)) & ~(BIT); \
- } while(0)
- /* Atomic 32-bit register access macro to clear and set one or several bits */
- #define ATOMIC_MODIFY_REG(REG, CLEARMSK, SETMASK) \
- do { \
- uint32_t val; \
- do { \
- val = (__LDREXW((__IO uint32_t *)&(REG)) & ~(CLEARMSK)) | (SETMASK); \
- } while(0)
- /* Atomic 16-bit register access macro to set one or several bits */
- #define ATOMIC_SETH_BIT(REG, BIT) \
- do { \
- uint16_t val; \
- do { \
- val = __LDREXH((__IO uint16_t *)&(REG)) | (BIT); \
- } while ((__STREXH(val,(__IO uint16_t *)&(REG))) != 0U); \
- } while(0)
- /* Atomic 16-bit register access macro to clear one or several bits */
- #define ATOMIC_CLEARH_BIT(REG, BIT) \
- do { \
- uint16_t val; \
- do { \
- val = __LDREXH((__IO uint16_t *)&(REG)) & ~(BIT); \
- } while(0)
- /* Atomic 16-bit register access macro to clear and set one or several bits */
- #define ATOMIC_MODIFYH_REG(REG, CLEARMSK, SETMASK) \
- do { \
- uint16_t val; \
- do { \
- val = (__LDREXH((__IO uint16_t *)&(REG)) & ~(CLEARMSK)) | (SETMASK); \
- } while(0)
