查看: 687|回复: 0
[MDK] MDK AC6的汇编文件没法执行两个symbols加法
发表于 2022-4-30 02:16:00 | 显示全部楼层 |阅读模式
下面这样,没法正常执行
.dc.l Image$$ER_RO$$Length + Image$$ER_RW$$Length // Module Code Size
.dc.l Image$$ER_RW$$Length + Image$$ER_ZI$$ZI$$Length // Module Data Size
.text
    .align 4
    .syntax unified
    .section RESET
    // Define public symbols
    .global __txm_module_preamble
    // Define application-specific start/stop entry points for the module
    .global demo_module_start
    // Define common external references
    .global  _txm_module_thread_shell_entry
    .global  _txm_module_callback_request_thread_entry
    .eabi_attribute Tag_ABI_PCS_RO_data, 1
    .eabi_attribute Tag_ABI_PCS_R9_use,  1
    .eabi_attribute Tag_ABI_PCS_RW_data, 2
__txm_module_preamble:
    .dc.l   0x4D4F4455                                          // Module ID
    .dc.l   0x6                                                 // Module Major Version
    .dc.l   0x1                                                 // Module Minor Version
    .dc.l   32                                                  // Module Preamble Size in 32-bit words
    .dc.l   0x12345678                                          // Module ID (application defined)
    .dc.l   0x01000007                                          // Module Properties where:
        //   Bits 31-24: Compiler ID
        //           0 -> IAR
        //           1 -> ARM
        //           2 -> GNU
        //   Bit 0:  0 -> Privileged mode execution
        //           1 -> User mode execution
        //   Bit 1:  0 -> No MPU protection
        //           1 -> MPU protection (must have user mode selected)
        //   Bit 2:  0 -> Disable shared/external memory access
        //           1 -> Enable shared/external memory access
    .dc.l   _txm_module_thread_shell_entry - __txm_module_preamble // Module Shell Entry Point
    .dc.l   demo_module_start - __txm_module_preamble           // Module Start Thread Entry Point
    .dc.l   0                                                   // Module Stop Thread Entry Point
    .dc.l   1                                                   // Module Start/Stop Thread Priority
    .dc.l   1024                                                // Module Start/Stop Thread Stack Size
    .dc.l   _txm_module_callback_request_thread_entry - __txm_module_preamble // Module Callback Thread Entry
    .dc.l   1                                                   // Module Callback Thread Priority
    .dc.l   1024                                                // Module Callback Thread Stack Size
    //the tools can't add two symbols together, but it should look like this:
    //.dc.l   Image$$ER_RO$$Length + Image$$ER_RW$$Length         // Module Code Size
    //.dc.l   Image$$ER_RW$$Length + Image$$ER_ZI$$ZI$$Length     // Module Data Size
    //so instead we'll define hard values:
    .dc.l   0x4000                                              // Module Code Size
    .dc.l   0x4000                                              // Module Data Size
    .dc.l   0                                                   // Reserved 0
    .dc.l   0                                                   // Reserved 1
    .dc.l   0                                                   // Reserved 2
    .dc.l   0                                                   // Reserved 3
    .dc.l   0                                                   // Reserved 4
    .dc.l   0                                                   // Reserved 5
    .dc.l   0                                                   // Reserved 6
    .dc.l   0                                                   // Reserved 7
    .dc.l   0                                                   // Reserved 8
    .dc.l   0                                                   // Reserved 9
    .dc.l   0                                                   // Reserved 10
    .dc.l   0                                                   // Reserved 11
    .dc.l   0                                                   // Reserved 12
    .dc.l   0                                                   // Reserved 13
    .dc.l   0                                                   // Reserved 14
    .dc.l   0                                                   // Reserved 15
GMT+8, 2024-6-8 00:26 , Processed in 0.183422 second(s), 25 queries .
