查看: 2343|回复: 2
[emWin] emwin 对话框 切换几次 就会死机
发表于 2017-2-16 18:30:39 | 显示全部楼层 |阅读模式
项目中emwin 对话框 切换几次 就会死机,进入硬件错误,到底如何释放内存呢...
切换速度快了也会死机...
创建代码
第一个页面
WM_HWIN* CreateHomeDLG(void) {
    static WM_HWIN hWin[7];
    uint8_t i;
    GUI_SetBkColor(0x00F8cf7a);
    GUI_Clear();
    GUI_SetColor(GUI_WHITE);
    GUI_UC_SetEncodeUTF8();
    //WINDOW_SetDefaultBkColor(0x00CEE7F7);
    hWin[0] = GUI_CreateDialogBox( _aDialogCreate, GUI_COUNTOF(_aDialogCreate),  _cbDialog, WM_HBKWIN, 0, 0);
    hWin[1] = GUI_CreateDialogBox(_aDialog1Create, GUI_COUNTOF(_aDialog1Create), _cbDialog1, WM_HBKWIN, 0, 0);
    hWin[2] = GUI_CreateDialogBox(_aDialog2Create, GUI_COUNTOF(_aDialog2Create), _cbDialog2, WM_HBKWIN, 0, 0);
    hWin[3] = GUI_CreateDialogBox(_aDialog3Create, GUI_COUNTOF(_aDialog3Create), _cbDialog3, WM_HBKWIN, 0, 0);
    hWin[4] = GUI_CreateDialogBox(_aDialog4Create, GUI_COUNTOF(_aDialog4Create), _cbDialog4, WM_HBKWIN, 0, 0);
    hWin[5] = GUI_CreateDialogBox(_headCreate, GUI_COUNTOF(_headCreate), _cbHead, WM_HBKWIN, 0, 0);
    hWin[6] = GUI_CreateDialogBox(_buttonDiaCreate, GUI_COUNTOF(_buttonDiaCreate), _cbButtonDia, WM_HBKWIN, 0, 0);
    for (i=0;i<7;i++)
        currentDLG.currentRunDLGhwin=hWin;
    for (i=7;i<10;i++)
        currentDLG.currentRunDLGhwin=NULL;
    currentDLG.name=homeDLG;
    return hWin;
第二个页面
WM_HWIN* CreateRealTimeDLG(void) {
    uint8_t i;
    GUI_Clear();
    for (i=0;i<7;i++)
    for (i=7;i<10;i++)
    currentDLG.name=realDLG;
    return hWin;
//关闭对话框
void exitCurrentDlg(void)
    uint8_t i;
    for (i=0;currentDLG.currentRunDLGhwin!=NULL;i++)
        GUI_EndDialog( currentDLG.currentRunDLGhwin,0);
        WM_DeleteWindow(currentDLG.currentRunDLGhwin);
    GUI_Clear();
//切换对话框
void dlgChange(uint32_t keys)
    //退出现在页面
    switch (currentDLG.name)
        case homeDLG:
            //按钮A
            if (keys&0x010000)
                exitCurrentDlg();
                CreateRealTimeDLG();
            else if (keys&0x020000);
            else if (keys&0x040000);
            else if (keys&0x080000);
            else if (keys&0x100000);
            else if (keys&0x200000);
            else if (keys&0x400000);
            else if (keys&0x800000);
          else;
        case realDLG:
            if (keys&0x010000);
            //按钮上
                exitCurrentDlg();
                CreateHomeDLG();
          else;
发表于 2017-2-17 09:18:43 | 显示全部楼层
这么创建模式,建议先创建一个对话框排查下。看这个代码,没有发现什么问题。
发表于 2017-2-17 15:32:01 | 显示全部楼层
看下STM32启动文件里面的栈数据是多少 一般是0x00000800
GMT+8, 2025-5-15 00:21 , Processed in 0.222798 second(s), 30 queries .
