查看: 8237|回复: 2
[客户分享] STM32F4固件库stm32f4_dsp_stdperiph_lib升级到1.4.0
发表于 2014-11-1 19:29:05 | 显示全部楼层 |阅读模式
百度云下载地址:
链接:http://pan.baidu.com/share/link? ... mp;amp;uk=286563520    密码:vscn
STM32F4的固件库升级到1.4.0了,本以为不升级了,ST要专注于STM32CubeF4,看来推广的不够成功
更新:
Main Changes
    [li]Add support of STM32F411xExx devices[/li][li]Miscellaneous update and enhancement in CMSIS, peripherals and examples (for more details, please refer to each component release notes).[/li]
Contents
Development Toolchains and Compilers
    quare][li]IAR Embedded Workbench for ARM (EWARM) toolchain V7.10.3 + ST-Link[/li][li]A software patch is needed to use STM32F411xE devices with EWARM V7.10. If you do not have this patch installed, you can install it from the following folder "\Utilities\Third_Party\Toolchains_STM32F411xE_Patches\EWARM7.10_STM32F411_Support.7z"[/li]
RealView Microcontroller Development Kit (MDK-ARM) toolchain V5.10 + ST-Link
    [li]A software patch is needed to use STM32F411xE devices with MDK-ARM V5.10. If you do not have this patch installed, you can install it from the following folder"\Utilities\Third_Party\Toolchains_STM32F411xE_Patches\MDK-ARM5.10_STM32F411_Support.7z"[/li]
STM32 TrueSTUDIO software (TrueSTUDIO) toolchain V5.1.0 + ST-Link
    [li]No software patch needed to use STM32F411xE devices with TrueSTUDIO V5.1.0 [/li]
Supported Devices and EVAL boards
    quare][li]STM32F40/41xxx devices and STM3240G-EVAL/STM3241G-EVAL boards[/li][li]STM32F427/437xx devices and STM32437I-EVAL board[/li][li]STM32F429/439xx devices and STM32429I-EVAL/STM32439I-EVAL boards[/li][li]STM32F401xx devices[/li][li]STM32F411xE devices[/li]
Known Limitations
    [li]stm324x9i_eval_audio_codec.c/.h[/li][li]If 2 audio streams are played in TDM format (the first stream is configured in codec SLOT0 and second stream in codec SLOT1) the Pause/Resume, Volume Control and Mute action will apply on both streams.[/li]
发表于 2014-11-3 08:23:40 | 显示全部楼层
Cube用了下感觉产生的代码不舒服,完全弱化硬件知识也不好
 楼主| 发表于 2014-11-8 11:13:46 | 显示全部楼层
GMT+8, 2025-5-13 01:47 , Processed in 0.221742 second(s), 24 queries .
