查看: 4916|回复: 1
[LibJPEG] 【LibJPEG专题系列二十四】FAQ列表归档
春暖花开
发表于 2015-5-20 15:10:00 | 显示全部楼层 |阅读模式
Section - [24] Where are FAQ lists archived?
Many FAQs are crossposted to news.answers.  Well-run netnews sites will have the latest versions available
in that newsgroup.  However, there are a *lot* of postings in news.answers, and they can be hard to sort through.
The latest versions of news.answers postings are archived at rtfm.mit.edu. You can retrieve this FAQ by FTP as
rtfm.mit.edu:/pub/faqs/jpeg-faq/part1 and rtfm.mit.edu:/pub/faqs/jpeg-faq/part2.  If you have no FTP access,
send e-mail to mail-server@rtfm.mit.edu containing the lines
              send faqs/jpeg-faq/part1
              send faqs/jpeg-faq/part2
(If you don't get a reply, the server may be misreading your return address; add a line such as "path myname@
mysite" to specify your correct e-mail address to reply to.)  For more info about the FAQ archive, retrieve the file
rtfm.mit.edu:/pub/faqs/news-answers/introduction.
The same FAQs are also available from several places on the World Wide Web, of which my favorite is
http://www.faqs.org/faqs/. This FAQ is http://www.faqs.org/faqs/jpeg-faq/. Other popular WWW FAQ archives
include http://www.cs.ruu.nl/cgi-bin/faqwais and http://www.lib.ox.ac.uk/internet/news/.
        tom lane
        organizer, Independent JPEG Groupt
        gl@netcom.com or tgl@sss.pgh.pa.us
努力打造安富莱高质量微信公众号:点击扫描图片关注
春暖花开
 楼主| 发表于 2015-5-20 15:12:55 | 显示全部楼层
                                         Section 24—FAQ表归档
    很多常见问题都是在news.answers上发布的。正常运行的网络新闻网站将在该新闻组提供最新的版本。
然而,在news.answers中有太多的帖子,而且很难分类。
             news.answers张贴的最新版本存档于rtfm.mit.edu。您可以通过FTP地址rtfm.mit.edu:/pub/faqs/jpeg-faq/part1
以及rtfm.mit.edu:/pub/faqs/jpeg-faq/part2中检索该FAQ。如果你没有FTP访问权限,可以发送邮件到
mail-server@rtfm.mit.edu,并包含以下两个信息:
  (如果你没有得到答复,可能是服务器的误读返回地址;添加一行诸如“path MYNAME@ mysite”的指令来指定
正确的电子邮件地址回复。)获取更多的FAQ归档信息,可检索该文档rtfm.mit.edu:/pub/faqs/news-answers/introduction
    同样的常见问题也可从万维网的以下几个地址获取,我最喜欢的是http://www.faqs.org/faqs/。本FAQ的地址
http://www.faqs.org/faqs/jpeg-faq/。其他比较受欢迎的WWW FAQ归档汇总还有下面两个网址:
http://www.cs.ruu.nl/cgi-bin/faqwais http://www.lib.ox.ac.uk/internet/news/
        tom lane
        tgl@netcom.comtgl@sss.pgh.pa.us
GMT+8, 2024-6-9 16:23 , Processed in 0.225379 second(s), 25 queries .
