查看: 2138|回复: 2
[RL-TCPnet] MDK的RL-TCPnet组件BSD socket编程模式怪怪的
发表于 2020-5-21 16:40:18 | 显示全部楼层 |阅读模式
提供的TCP服务器例程:
void Server_Thread (void *arg) {
  SOCKADDR_IN addr;
  int sock, sd, res;
  int type = (int)arg;
  char dbuf[4];
  while (1) {
    sock = socket (AF_INET, type, 0);
    addr.sin_port        = htons(PORT_NUM);
    addr.sin_family      = PF_INET;
    addr.sin_addr.s_addr = INADDR_ANY;
    bind (sock, (SOCKADDR *)&addr, sizeof(addr));
    if (type == SOCK_STREAM) {
      listen (sock, 1);
      sd = accept (sock, NULL, NULL);
      closesocket (sock);  //此处要关闭之前建立的socket
      sock = sd;
    while (1) {
      res = recv (sock, dbuf, sizeof (dbuf), 0);
      if (res <= 0) {
      if (dbuf[0] == BLINKLED) {
        LED_SetOut (dbuf[1]);
    closesocket (sock);
如上,接收到了连接要关闭之前创建的socket,这有点怪怪的,如果我要用这个socket接收多个连接那不是要白瞎了
发表于 2020-5-21 18:09:01 | 显示全部楼层
因为你的程序里面listen (sock, 1)设置最大监听1个连接。
监听到1个连接后,还留着它干啥呢。。。。
代码不规范,亲人两行泪!
 楼主| 发表于 2020-5-21 22:34:05 | 显示全部楼层
好吧,说得在理
GMT+8, 2025-4-27 08:17 , Processed in 0.212773 second(s), 23 queries .
