查看: 3825|回复: 2
[AppWizard] AppWizard的回调函数怎么用,和GUIBuilder.exe有所不同
发表于 2020-11-10 18:39:22 | 显示全部楼层 |阅读模式
按照GUIBuilder.exe那样往回调函数添加操作,但获取的进度条句柄有问题
void cbID_SCREEN_Main(WM_MESSAGE * pMsg) {
  GUI_USE_PARA(pMsg);
        int          NCode;
        int          Id;
        int a;
         WM_HWIN                     hItem;
          switch (pMsg->MsgId) {
                  case WM_INIT_DIALOG:
                                NCode = pMsg->Data.v;
                        switch(Id)
                                        case        ID_PROGBAR_Battery:
                                                hItem = WM_GetDialogItem(pMsg->hWin, ID_PROGBAR_Battery);
                                                a = PROGBAR_GetValue(hItem);
                                default:
  default:
    WM_DefaultProc(pMsg);
发表于 2020-11-11 09:07:01 | 显示全部楼层
程序有问题,怎么在INIT消息里面做了个  switch(Id)
发表于 2021-1-26 23:41:01 | 显示全部楼层
楼主请问有进展了吗
GMT+8, 2025-5-20 04:26 , Processed in 0.379404 second(s), 24 queries .
