楼主 |
发表于 2020-12-19 02:24:49
显示全部楼层
解决了,加上这个处理就正常了
- UINT slide_win_event_process(GX_WINDOW *window, GX_EVENT *event_ptr)
- switch (event_ptr->gx_event_type)
- case GX_EVENT_SHOW:
- slide_animation_start(window);
- return gx_widget_event_process(window, event_ptr);
- case GX_EVENT_HIDE:
- gx_animation_drag_disable(&slide_animation, (GX_WIDGET *)window);
- default:
- return gx_window_event_process(window, event_ptr);
- return 0;
