查看: 2362|回复: 0
[NetX] ThreadX NetX使能DHCP的情况下,等待IP就绪的专用回调功能
发表于 2021-1-23 09:41:50 | 显示全部楼层 |阅读模式
回调函数
  1. /**
  2. * @brief  IP address change call back
  3. * @param ip_instance: NX_IP instance registered for this callback
  4. * @param ptr: VOID * optional user data
  5. * @retval none
  6. */
  7. static VOID ip_address_change_notify_callback(NX_IP *ip_instance, VOID *ptr)
  8. {
  9.   tx_semaphore_put(&Semaphore);
  10. }
注册和等待:
  1.   /* register the IP address change callback */
  2.   ret = nx_ip_address_change_notify(&IpInstance, ip_address_change_notify_callback, NULL);
  3.   if (ret != NX_SUCCESS)
  4.   {
  5.     Error_Handler();
  6.   }
  7.   /* start the DHCP client */
  8.   ret = nx_dhcp_start(&DHCPClient);
  9.   if (ret != NX_SUCCESS)
  10.   {
  11.     Error_Handler();
  12.   }
  13.   /* wait until an IP address is ready */
  14.   if(tx_semaphore_get(&Semaphore, TX_WAIT_FOREVER) != TX_SUCCESS)
  15.   {
  16.     Error_Handler();
  17.   }
GMT+8, 2024-5-13 03:30 , Processed in 0.144483 second(s), 25 queries .
