查看: 10359|回复: 4
[ThreadX全家桶] ThreadX版权问题请教
发表于 2021-4-19 10:08:00 | 显示全部楼层 |阅读模式
threadx开源免费的意思是不是我可以不交钱用到任何单片机上?我用到产品上后,哪天他又说不免费了,我在这基础上开发出来的产品是不是就得交钱了
发表于 2021-4-19 10:16:42 | 显示全部楼层
不是,是有免费列表的。
https://github.com/azure-rtos/th ... CENSED-HARDWARE.txt
还在持续更新
  1. LICENSED HARDWARE LIST
  2. Last Updated: 2021-04-01
  3. Microsoft has entered into OEM Agreements with manufacturers of the following
  4. microprocessors and microcontrollers (the “hardware”) to enable those
  5. manufacturers to include and distribute Azure RTOS in certain hardware. If you
  6. have obtained and/or are developing on microprocessor(s) and/or
  7. microcontroller(s) (“hardware”) listed below you inherit the “Distribution and
  8. Production Use” rights in Section 2 of the Microsoft Software License Terms for
  9. Microsoft Azure RTOS. If hardware is not listed below, you do not have those
  10. rights.
  11. STMicroelectronics:
  12.     STM32 MCUs
  13.     STM32 MPUs
  14. MediaTek:
  15.     MT3620 MCU (Azure Sphere)
  16. Microchip:
  17.     PIC 32-bit MCUs
  18.     SAM 32-bit MCUs
  19.     SAM 32-bit MPUs
  20. NXP:
  21.     i.MX RT10xx and RT116x/7x series crossover MCUs
  22.     LPC5500 series
  23. Renesas:
  24.     Synergy Platform
  25.     RX Family of MCUs
  26.     RA Family of MCUs
  27.     RZ Family of MPUs
  28. --------------------------------------------------------------------------------
  29. More coming soon. Please check back frequently for updates.
 楼主| 发表于 2021-4-19 10:29:51 | 显示全部楼层
eric2013 发表于 2021-4-19 10:16
不是,是有免费列表的。
https://github.com/azure-rtos/threadx/blob/master/LICENSED-HARDWARE.txt
谢谢
特别照顾组
发表于 2021-4-20 08:10:17 | 显示全部楼层
坚决不用不免费的,微软变化大,一直以来我不喜欢微软东西。
发表于 2021-4-20 12:20:11 | 显示全部楼层
偏见那么重?
GMT+8, 2025-5-20 19:39 , Processed in 0.325711 second(s), 24 queries .
