查看: 4623|回复: 2
[SEGGER RTT] SEGGER RTT最新目标板软件包V7.00(2021-04-19)
发表于 2021-4-19 10:25:51 | 显示全部楼层 |阅读模式
SEGGER_RTT_V700.zip (42.55 KB, 下载次数: 246)
  1. README.txt for the SEGGER RTT Implementation Pack.
  2. MDK-ARM specifics:
  3. https://wiki.segger.com/Keil_MDK-ARM#RTT_in_uVision
  4. Included files:
  5. ===============
  6. Root Directory
  7.   - Examples
  8.     - Main_RTT_InputEchoApp.c    - Sample application which echoes input on Channel 0.
  9.     - Main_RTT_MenuApp.c         - Sample application to demonstrate RTT bi-directional functionality.
  10.     - Main_RTT_PrintfTest.c      - Sample application to test RTT small printf implementation.
  11.     - Main_RTT_SpeedTestApp.c    - Sample application for measuring RTT performance. embOS needed.
  12.   - RTT
  13.     - SEGGER_RTT.c                - The RTT implementation.
  14.     - SEGGER_RTT.h                - Header for RTT implementation.
  15.     - SEGGER_RTT_Conf.h           - Pre-processor configuration for the RTT implementation.
  16.     - SEGGER_RTT_Printf.c         - Simple implementation of printf to write formatted strings via RTT.
  17.   - Syscalls
  18.     - RTT_Syscalls_GCC.c          - Low-level syscalls to retarget printf() to RTT with GCC / Newlib.
  19.     - RTT_Syscalls_IAR.c          - Low-level syscalls to retarget printf() to RTT with IAR compiler.
  20.     - RTT_Syscalls_KEIL.c         - Low-level syscalls to retarget printf() to RTT with KEIL/uVision compiler.
  21.     - RTT_Syscalls_SES.c          - Low-level syscalls to retarget printf() to RTT with SEGGER Embedded Studio.
测试:
 楼主| 发表于 2021-4-19 10:31:53 | 显示全部楼层
【专题教程第5期】工程调试利器RTT实时数据传输组件,替代串口调试,速度飞快,可以在中断和多任务中随意调用
http://www.armbbs.cn/forum.php?m ... 6177&fromuid=58
发表于 2021-4-20 10:09:57 | 显示全部楼层
在大佬的勾引下,入坑688版本。现在这个7试用试用。
GMT+8, 2025-5-15 21:05 , Processed in 0.226478 second(s), 27 queries .
