查看: 3471|回复: 10
[MDK] 分享一种结构体内成员指定对齐的语法
More we do, more we can do.
发表于 2021-6-19 15:57:58 | 显示全部楼层 |阅读模式
最近数据存EEPROM带ECC,考虑到使用寿命,按规格书要求4字节存1个参数,搞出了这个写法。
  1. #include <stdio.h>
  2. #include <stdint.h>
  3. typedef struct
  4. {
  5.     uint8_t __attribute__((aligned (4))) a;
  6.     uint8_t __attribute__((aligned (4))) b;
  7.     uint8_t __attribute__((aligned (4))) c;
  8. }Aligned_Struct;
  9. int main()
  10. {
  11.     Aligned_Struct demo;
  12.     printf("0x%X 0x%X 0x%X", (uint32_t)&demo.a, (uint32_t)&demo.b, (uint32_t)&demo.c);
  13.     return 0;
  14. }
规格书写寿命脚注:
The Write cycle endurance is defined for groups of four data bytes located at addresses [4*N, 4*N+1, 4*N+2, 4*N+3] where N is an integer.
发表于 2021-6-19 17:27:03 | 显示全部楼层
这句英文并不是说要你4字节只能存一个参数。而是说写寿命的最小单位是一个group,每个group由4字节组成。
发表于 2021-6-20 11:08:44 | 显示全部楼层
谢谢分享。
发表于 2021-6-20 12:44:54 | 显示全部楼层
正确~~~
 楼主| 发表于 2021-6-21 12:23:28 | 显示全部楼层
我这个延长寿命的做法有问题吗,应该怎么改进?
发表于 2021-6-21 14:33:37 | 显示全部楼层
还有一种写法
  1. #pragma pack(4)
  2. typedef struct
  3. {
  4.     uint8_t a;
  5.     uint8_t b;
  6.     uint8_t c;
  7. }Aligned_Struct;
  8. #pragma pack()
发表于 2021-7-6 11:31:36 | 显示全部楼层
这些奇奇怪怪的语法,在哪里可以查到帮助文档?
发表于 2021-7-6 15:31:54 | 显示全部楼层
  1. typedef struct
  2. {
  3.     uint32_t  a;
  4.     uint32_t  b;
  5.     uint32_t  c;
  6. }Aligned_Struct;
跟这个有啥区别?
发表于 2021-7-6 15:57:34 | 显示全部楼层
这样兼容性太差了,直接使用uin32_t存每个数据就是四字节对其了呀
 楼主| 发表于 2021-7-6 23:46:29 | 显示全部楼层
你的写法跟楼主位的写法效果不一样,参见GCC手册:
6.62.11 Structure-Layout Pragmas
For compatibility with Microsoft Windows compilers, GCC supports a set of #pragma directives that change the maximum alignment of members of structures (other than zero-width
bit-fields), unions, and classes subsequently defined. The n value below always is required
to be a small power of two and specifies the new alignment in bytes.
发表于 2021-7-18 14:58:57 | 显示全部楼层
各位大仙是用的什么芯片,32位的编译器默认的结构体就是4字节对齐啊
GMT+8, 2024-6-6 22:20 , Processed in 0.177312 second(s), 25 queries .
