查看: 2864|回复: 1
[有问必答] BSP_key驱动请教
发表于 2021-6-20 07:32:52 | 显示全部楼层 |阅读模式
硬汉哥, 我吧stm32v4的按键移植到hal库下面
其他是一样的,就是采集端口不一样。
  1. static uint8_t IsKeyDown1(void)
  2. {
  3.     //if ((GPIO_PORT_K1->IDR & GPIO_PIN_K1) == 1 && (GPIO_PORT_K2->IDR & GPIO_PIN_K2) == 0)
  4.     if ((HAL_GPIO_ReadPin(GPIO_PORT_K1, GPIO_PIN_K1) == GPIO_PIN_SET )        \
  5.             && (HAL_GPIO_ReadPin(GPIO_PORT_K2, GPIO_PIN_K2) == GPIO_PIN_RESET))
  6.         return 1;
  7.     else
  8.         return 0;
  9. }
  10. static uint8_t IsKeyDown2(void)
  11. {
  12.     if ((GPIO_PORT_K1->IDR & GPIO_PIN_K1) == 0 && (GPIO_PORT_K2->IDR & GPIO_PIN_K2) == 1)
  13.     //if ((HAL_GPIO_ReadPin(GPIO_PORT_K1, GPIO_PIN_K1) == GPIO_PIN_RESET )        \
  14.             && (HAL_GPIO_ReadPin(GPIO_PORT_K2, GPIO_PIN_K2) == GPIO_PIN_SET))
  15.         return 1;
  16.     else
  17.         return 0;
  18. }
如果用库函数是可以的,但是寄存器的方式就不行,无法检测到,也就是无法到达return 1的语句
 楼主| 发表于 2021-6-20 07:35:38 | 显示全部楼层
已经解决了
  2. {
  3.     if ((GPIO_PORT_K1->IDR & GPIO_PIN_K1) != 0 && (GPIO_PORT_K2->IDR & GPIO_PIN_K2) == 0)
  4.     //if ((HAL_GPIO_ReadPin(GPIO_PORT_K1, GPIO_PIN_K1) == GPIO_PIN_SET )        \
  6.         return 1;
  7.     else
  8.         return 0;
  9. }
  11. {
  12.     if ((GPIO_PORT_K1->IDR & GPIO_PIN_K1) == 0 && (GPIO_PORT_K2->IDR & GPIO_PIN_K2) != 0)
  15.         return 1;
  16.     else
  17.         return 0;
  18. }
GMT+8, 2024-5-30 16:58 , Processed in 0.220651 second(s), 23 queries .
