发表于 2021-6-26 16:44:14
显示全部楼层
得想办法解决下,我看下这个函数,代码量太大了,本身I2C就很慢,这么搞确实有问题
- * @brief Read an amount of data in blocking mode from a specific memory address
- * @param hi2c Pointer to a I2C_HandleTypeDef structure that contains
- * the configuration information for the specified I2C.
- * @param DevAddress Target device address: The device 7 bits address value
- * in datasheet must be shifted to the left before calling the interface
- * @param MemAddress Internal memory address
- * @param MemAddSize Size of internal memory address
- * @param pData Pointer to data buffer
- * @param Size Amount of data to be sent
- * @param Timeout Timeout duration
- * @retval HAL status
- HAL_StatusTypeDef HAL_I2C_Mem_Read(I2C_HandleTypeDef *hi2c, uint16_t DevAddress, uint16_t MemAddress,
- uint16_t MemAddSize, uint8_t *pData, uint16_t Size, uint32_t Timeout)
- uint32_t tickstart;
- /* Check the parameters */
- assert_param(IS_I2C_MEMADD_SIZE(MemAddSize));
- if (hi2c->State == HAL_I2C_STATE_READY)
- if ((pData == NULL) || (Size == 0U))
- hi2c->ErrorCode = HAL_I2C_ERROR_INVALID_PARAM;
- return HAL_ERROR;
- /* Process Locked */
- __HAL_LOCK(hi2c);
- /* Init tickstart for timeout management*/
- tickstart = HAL_GetTick();
- if (I2C_WaitOnFlagUntilTimeout(hi2c, I2C_FLAG_BUSY, SET, I2C_TIMEOUT_BUSY, tickstart) != HAL_OK)
- return HAL_ERROR;
- hi2c->State = HAL_I2C_STATE_BUSY_RX;
- hi2c->Mode = HAL_I2C_MODE_MEM;
- hi2c->ErrorCode = HAL_I2C_ERROR_NONE;
- /* Prepare transfer parameters */
- hi2c->pBuffPtr = pData;
- hi2c->XferCount = Size;
- hi2c->XferISR = NULL;
- /* Send Slave Address and Memory Address */
- if (I2C_RequestMemoryRead(hi2c, DevAddress, MemAddress, MemAddSize, Timeout, tickstart) != HAL_OK)
- /* Process Unlocked */
- __HAL_UNLOCK(hi2c);
- return HAL_ERROR;
- /* Send Slave Address */
- /* Set NBYTES to write and reload if hi2c->XferCount > MAX_NBYTE_SIZE and generate RESTART */
- if (hi2c->XferCount > MAX_NBYTE_SIZE)
- hi2c->XferSize = MAX_NBYTE_SIZE;
- I2C_TransferConfig(hi2c, DevAddress, (uint8_t)hi2c->XferSize, I2C_RELOAD_MODE, I2C_GENERATE_START_READ);
- else
- hi2c->XferSize = hi2c->XferCount;
- I2C_TransferConfig(hi2c, DevAddress, (uint8_t)hi2c->XferSize, I2C_AUTOEND_MODE, I2C_GENERATE_START_READ);
- do
- /* Wait until RXNE flag is set */
- if (I2C_WaitOnFlagUntilTimeout(hi2c, I2C_FLAG_RXNE, RESET, Timeout, tickstart) != HAL_OK)
- return HAL_ERROR;
- /* Read data from RXDR */
- *hi2c->pBuffPtr = (uint8_t)hi2c->Instance->RXDR;
- /* Increment Buffer pointer */
- hi2c->pBuffPtr++;
- hi2c->XferSize--;
- hi2c->XferCount--;
- if ((hi2c->XferCount != 0U) && (hi2c->XferSize == 0U))
- /* Wait until TCR flag is set */
- if (I2C_WaitOnFlagUntilTimeout(hi2c, I2C_FLAG_TCR, RESET, Timeout, tickstart) != HAL_OK)
- return HAL_ERROR;
- I2C_TransferConfig(hi2c, DevAddress, (uint8_t) hi2c->XferSize, I2C_RELOAD_MODE, I2C_NO_STARTSTOP);
- else
- I2C_TransferConfig(hi2c, DevAddress, (uint8_t)hi2c->XferSize, I2C_AUTOEND_MODE, I2C_NO_STARTSTOP);
- } while (hi2c->XferCount > 0U);
- /* No need to Check TC flag, with AUTOEND mode the stop is automatically generated */
- /* Wait until STOPF flag is reset */
- if (I2C_WaitOnSTOPFlagUntilTimeout(hi2c, Timeout, tickstart) != HAL_OK)
- return HAL_ERROR;
- /* Clear STOP Flag */
- __HAL_I2C_CLEAR_FLAG(hi2c, I2C_FLAG_STOPF);
- /* Clear Configuration Register 2 */
- I2C_RESET_CR2(hi2c);
- hi2c->State = HAL_I2C_STATE_READY;
- hi2c->Mode = HAL_I2C_MODE_NONE;
- return HAL_OK;
- else
- return HAL_BUSY;
