查看: 3794|回复: 5
[MPU] 请教cubemx 配置的mpu问题
发表于 2021-7-30 14:45:38 | 显示全部楼层 |阅读模式
使用mx 配置了mpu。 单步跑当跑到 MPU_Config();后 进入此处报错。  请问是哪里配置错误了吗?void MemManage_Handler(void)
  /* USER CODE BEGIN MemoryManagement_IRQn 0 */
  /* USER CODE END MemoryManagement_IRQn 0 */
  while (1)
    /* USER CODE BEGIN W1_MemoryManagement_IRQn 0 */
    /* USER CODE END W1_MemoryManagement_IRQn 0 */
下边是mpu的内容
void MPU_Config(void)
  MPU_Region_InitTypeDef MPU_InitStruct = {0};
  /* Disables the MPU */
  HAL_MPU_Disable();
  /** Initializes and configures the Region and the memory to be protected
  MPU_InitStruct.Enable = MPU_REGION_ENABLE;
  MPU_InitStruct.Number = MPU_REGION_NUMBER0;
  MPU_InitStruct.BaseAddress = 0x24000000;
  MPU_InitStruct.Size = MPU_REGION_SIZE_512KB;
  MPU_InitStruct.SubRegionDisable = 0x0;
  MPU_InitStruct.TypeExtField = MPU_TEX_LEVEL0;
  MPU_InitStruct.AccessPermission = MPU_REGION_NO_ACCESS;
  MPU_InitStruct.DisableExec = MPU_INSTRUCTION_ACCESS_DISABLE;
  MPU_InitStruct.IsShareable = MPU_ACCESS_NOT_SHAREABLE;
  MPU_InitStruct.IsCacheable = MPU_ACCESS_CACHEABLE;
  MPU_InitStruct.IsBufferable = MPU_ACCESS_BUFFERABLE;
  MPU_InitStruct.Number = MPU_REGION_NUMBER1;
  MPU_InitStruct.BaseAddress = 0x30000000;
  MPU_InitStruct.Number = MPU_REGION_NUMBER2;
  MPU_InitStruct.BaseAddress = 0x80000000;
  MPU_InitStruct.Size = MPU_REGION_SIZE_256MB;
  MPU_InitStruct.AccessPermission = MPU_REGION_PRIV_RW_URO;
  MPU_InitStruct.Number = MPU_REGION_NUMBER3;
  MPU_InitStruct.BaseAddress = 0xD0000000;
  MPU_InitStruct.Size = MPU_REGION_SIZE_32MB;
  /* Enables the MPU */
  HAL_MPU_Enable(MPU_PRIVILEGED_DEFAULT);
发表于 2021-7-30 14:55:43 | 显示全部楼层
先看下MDK的Hard Fault reports具体错误类型。
 楼主| 发表于 2021-7-30 15:00:20 | 显示全部楼层
请问stm32cube ide 在哪里可以看到这个reports
 楼主| 发表于 2021-7-30 16:21:50 | 显示全部楼层
故障发生时,堆栈指针的值。请确认这个值指向一个有效的堆栈内存区域。
MSP = 主堆栈指针
PSP = 进程堆栈指针
 楼主| 发表于 2021-7-30 17:53:05 | 显示全部楼层
已解决 是mpu配置错误了
发表于 2021-7-30 18:06:59 | 显示全部楼层
访问类型全部修改下即可
MPU_REGION_FULL_ACCESS
GMT+8, 2025-5-11 05:51 , Processed in 0.235310 second(s), 24 queries .
