查看: 2232|回复: 3
[SD/SDIO] stm32H743 sd使用dma问题 HAL_SD_ReadBlocks_DMA()读到数据全是0
发表于 2021-10-20 15:45:45 | 显示全部楼层 |阅读模式
请教一个下个 我使用stm32h743 sd使用dma  使用cubemx 生成的代码 通过HAL_SD_WriteBlocks_DMA()和 HAL_SD_ReadBlocks_DMA()函数读写 sd卡 ,读到的数据是0.
__align(4) uint8_t  write_buf[512];
__align(4) uint8_t  read_buf[512];
void sd_test(void)
        u32 i = 0, status;
        HAL_SD_CardStateTypeDef State;
  HAL_SD_CardCIDTypeDef SD_CardCID;
        State = HAL_SD_GetCardState(&hsd1);
        if(State == HAL_SD_CARD_TRANSFER)
                HAL_SD_GetCardCID(&hsd1,&SD_CardCID);
                printf("\r\n Initialize SD card successfully!\r\n\r\n");
                printf(" SD card information! \r\n");
                printf(" CardCapacity  : %llu \r\n",((unsigned long long)hsd1.SdCard.BlockSize*hsd1.SdCard.BlockNbr));
                printf(" CardBlockSize : %d \r\n",hsd1.SdCard.BlockSize);
                printf(" RCA           : %d \r\n",hsd1.SdCard.RelCardAdd);
                printf(" CardType      : %d \r\n",hsd1.SdCard.CardType);
                printf(" ManufacturerID: %d \r\n",SD_CardCID.ManufacturerID);
                printf("SD卡初始化失败\n" );
                while(1); // 停机
        for(i = 0; i < 512; i++)
                write_buf = i % 256;
        printf("------------------- Write SD card block data Test ------------------\r\n");
//status = HAL_SD_WriteBlocks(&hsd1,(uint8_t *)write_buf,0,1,0xffff);
status = HAL_SD_WriteBlocks_DMA(&hsd1,(uint8_t *)write_buf,0,512);
//status = BSP_SD_WriteBlocks_DMA((uint32_t *)write_buf,0,100);
if(status == 0)
    printf("Write block data ok \r\n" );
    printf("Write block data fail!\r\n " );
delay_ms(2000);
printf("------------------- Read SD card block data after Write ------------------\r\n");
status = HAL_SD_ReadBlocks_DMA(&hsd1,(uint8_t *)read_buf,0,512);
//status = BSP_SD_ReadBlocks_DMA((uint32_t *)read_buf, 2 ,100);
if(status == 0)
    printf("Read block data ok \r\n" );
        printf("0x%02x ", read_buf);
        if((i+1)%16 == 0)
            printf("\r\n");
}else
  printf("read block data fail %d\r\n", status);
发表于 2021-10-21 08:42:28 | 显示全部楼层
方便的话,可以使用我这个里面的V7-025,各种主流SD卡全部测试通过。
【安富莱】STM32H7用户手册发布,重在BSP驱动包设计方法,HAL库的框架学习,授人以渔,更新至91章(2021-03-22)
http://www.armbbs.cn/forum.php?m ... 6980&fromuid=58
发表于 2021-11-3 16:12:03 | 显示全部楼层
检查一下:
#define ENABLE_SD_DMA_CACHE_MAINTENANCE  1
也许,可以解决问题。
发表于 2023-7-6 13:14:45 | 显示全部楼层
leoo00 发表于 2021-11-3 16:12
检查一下:
也许,可以解决问题。
L4不支持这个,反正把对齐是弄了的。
GMT+8, 2024-5-16 08:59 , Processed in 0.156371 second(s), 25 queries .
