驱动文件:
- * SEGGER Microcontroller GmbH *
- * Solutions for real time microcontroller applications *
- * (c) 1996 - 2020 SEGGER Microcontroller GmbH *
- * Internet: www.segger.com Support: support@segger.com *
- ** emWin V6.20 - Graphical user interface for embedded applications **
- All Intellectual Property rights in the Software belongs to SEGGER.
- emWin is protected by international copyright laws. Knowledge of the
- source code may not be used to write a similar product. This file may
- only be used in accordance with the following terms:
- The software has been licensed to ARM LIMITED whose registered office
- is situated at 110 Fulbourn Road, Cambridge CB1 9NJ, England solely
- for the purposes of creating libraries for ARM7, ARM9, Cortex-M
- series, and Cortex-R4 processor-based devices, sublicensed and
- distributed as part of the MDK-ARM Professional under the terms and
- conditions of the End User License supplied with the MDK-ARM
- Professional.
- Full source code is available at: www.segger.com
- We appreciate your understanding and fairness.
- Licensing information
- Licensor: SEGGER Software GmbH
- Licensed to: ARM Ltd, 110 Fulbourn Road, CB1 9NJ Cambridge, UK
- Licensed SEGGER software: emWin
- License number: GUI-00181
- License model: LES-SLA-20007, Agreement, effective since October 1st 2011
- Licensed product: MDK-ARM Professional
- Licensed platform: ARM7/9, Cortex-M/R4
- Licensed number of seats: -
- -------------------------- END-OF-HEADER -----------------------------
- File : GUI_VNC_X_StartServer.c
- Purpose : Starts the VNC server using plain BSD socket API and
- alternate prepares handling of an incoming WebSocket
- connection handled by the embOS/IP web server.
- By default only the plain BSD socket API will be used.
- The WebSocket handling can be activated in GUIConf.h by
- enabling GUI_VNC_SUPPORT_WEBSOCKET_SERVER .
- The WebSocket based connection is intended to be used
- with the noVNC client written in HTML5 that uses
- WebSockets for communication.
- The noVNC sample per default uses the URI "/websockify"
- and port 80.
- Software: - emWin, with VNC
- - embOS
- - emNet (f.k.a. embOS/IP)
- Hardware: - STM32F746G-DISCO
- How To
- Start : Configure the maximum amount of VNC connections with the
- VNC_MAX_CLIENTS macro.
- To start, simply call GUI_VNC_X_StartServer()
- in your application, incrementing the ServerIndex parameter
- for each desired connection.
- #include "GUI.h"
- #include "GUI_VNC.h"
- #include "RTOS.h"
- #include "IP.h"
- #include "TaskPrio.h"
- #include <stdio.h>
- * Defines, configurable
- // Default configuration. Use GUIConf.h for override.
- #ifndef GUI_VNC_SUPPORT_PLAIN_SOCKET_SERVER
- #define GUI_VNC_SUPPORT_PLAIN_SOCKET_SERVER 0
- #endif
- #ifndef GUI_VNC_SUPPORT_WEBSOCKET_SERVER
- #define GUI_VNC_SUPPORT_WEBSOCKET_SERVER 1
- #endif
- // Define maximum number of VNC clients that can connect
- #define VNC_MAX_CLIENTS 3
- #if GUI_VNC_SUPPORT_WEBSOCKET_SERVER
- #include "IP_WEBSOCKET.h"
- #include "IP_Webserver.h"
- #include "WEBS_Conf.h" // Stack size depends on configuration
- // WebSocket web server configuration.
- #ifndef WEBSOCKET_VNC_URI
- #define WEBSOCKET_VNC_URI "/websockify"
- #endif
- #ifndef WEBSOCKET_VNC_PROTO
- #define WEBSOCKET_VNC_PROTO ""
- #endif
- #endif
- #define USE_RX_TASK 0 // 0: Packets are read in ISR, 1: Packets are read in a task of its own.
- // Web server and IP stack
- #define MAX_CONNECTIONS 1
- #define BACK_LOG 20
- #define IDLE_TIMEOUT 1000 // Timeout [ms] after which the connection will be closed if no new data is received.
- #define SERVER_PORT 80
- #define CHILD_ALLOC_SIZE 2560 // NumBytes required from memory pool for one connection. Should be fine tuned according
- // to your configuration using IP_WEBS_CountRequiredMem() .
- // Task priorities.
- enum {
- TASK_PRIO_WEBS_CHILD = 150
- ,TASK_PRIO_WEBS_PARENT
- ,TASK_PRIO_IP_TASK // Priority must be higher as all IP application tasks.
- #if USE_RX_TASK
- ,TASK_PRIO_IP_RX_TASK // Must be the highest priority of all IP related tasks.
- #endif
- // Task stack sizes that might not fit for some interfaces (multiples of sizeof(int)).
- #ifndef WEBS_TASK_STACK_OVERHEAD
- #define WEBS_TASK_STACK_OVERHEAD 0
- #endif
- #ifndef STACK_SIZE_SERVER
- #define STACK_SIZE_SERVER (2304 + WEBS_TASK_STACK_OVERHEAD)
- #endif
- // UDP discover
- #define ETH_UDP_DISCOVER_PORT 50020
- #define PACKET_SIZE 0x80
- #ifndef APP_TASK_STACK_OVERHEAD
- #define APP_TASK_STACK_OVERHEAD 0
- #endif
- * Defines, fixed
- * Types
- enum {
- SOCKET_TYPE_BSD = 0,
- SOCKET_TYPE_WEBSOCKET
- typedef struct {
- void * pConnection; // Pointer to connection context. NULL if disconnected.
- // Set (if NULL) when accepting a connection to tell the VNC
- // server task that a new connection has been opened.
- U8 SocketType; // Socket type of this connection instance.
- U8 MessageType; // Last received WebSocket message type.
- GUI_VNC_CONTEXT Context; // VNC context necessary for GUI.
- WEBS_WEBSOCKET_HOOK WebSocketHook; // WebSocket resources.
- #endif
- U8 acBuffer[GUI_VNC_BUFFER_SIZE]; // Buffer used for reading RFB protocol.
- } GUI_IP_VNC_CONNECTION;
- typedef struct {
- OS_STACKPTR int VNCServer_Stack[(4000 + APP_TASK_STACK_OVERHEAD)/sizeof(int)];
- OS_TASK VNCServer_TCB;
- } GUI_VNC_TASK;
- * Prototypes
- static int _cbWebSocket_GenerateAcceptKey (WEBS_OUTPUT* pOutput, void* pSecWebSocketKey, int SecWebSocketKeyLen, void* pBuffer, int BufferSize);
- static void _cbWebSocket_DispatchConnection(WEBS_OUTPUT* pOutput, void* pConnection);
- static int _cbWebSocket_Recv (IP_WEBSOCKET_CONTEXT* pContext, IP_WEBSOCKET_CONNECTION* pConnection, void* pData, unsigned NumBytes);
- static int _cbWebSocket_Send (IP_WEBSOCKET_CONTEXT* pContext, IP_WEBSOCKET_CONNECTION* pConnection, const void* pData, unsigned NumBytes);
- #endif
- * Static data
- static GUI_IP_VNC_CONNECTION _aConnections[VNC_MAX_CLIENTS];
- static GUI_VNC_TASK _aTasks [VNC_MAX_CLIENTS];
- static GUI_VNC_CONTEXT * _pFirstContext;
- static const IP_WEBS_WEBSOCKET_API _WebServerWebSocketAPI = {
- _cbWebSocket_GenerateAcceptKey, // pfGenerateAcceptKey
- _cbWebSocket_DispatchConnection // pfDispatchConnection
- static const IP_WEBSOCKET_TRANSPORT_API _WebSocketTransportAPI = {
- _cbWebSocket_Recv, // pfReceive
- _cbWebSocket_Send // pfSend
- // WebServer related
- static U32 _aPool[(CHILD_ALLOC_SIZE * MAX_CONNECTIONS) / sizeof(int)]; // Memory pool for the Web server child tasks.
- #endif
- // IP task related
- static IP_HOOK_ON_STATE_CHANGE _StateChangeHook;
- static int _IFaceId;
- static U8 _IPStackInit;
- // Task stacks and Task-Control-Blocks.
- static OS_STACKPTR int _IPStack[TASK_STACK_SIZE_IP_TASK/sizeof(int)]; // Stack of the IP_Task.
- static OS_TASK _IPTCB; // Task-Control-Block of the IP_Task.
- #if USE_RX_TASK
- static OS_STACKPTR int _IPRxStack[TASK_STACK_SIZE_IP_RX_TASK/sizeof(int)]; // Stack of the IP_RxTask.
- static OS_TASK _IPRxTCB; // Task-Control-Block of the IP_RxTask.
- #endif
- static int _ConnectCnt;
- // Webserver TCBs and stacks
- static OS_TASK _aWebTasks[MAX_CONNECTIONS];
- static OS_STACKPTR int _aWebStacks[MAX_CONNECTIONS][STACK_SIZE_SERVER/sizeof(int)];
- // Task stacks and Task-Control-Blocks for main WebServer task.
- static OS_STACKPTR int Stack_IP_Main[1536];
- static OS_TASK TCB_IP_Main;
- // File system info
- static const IP_FS_API *_pFS_API;
- #endif
- * WebServer related
- * _OnStateChange()
- * Function description
- * Callback that will be notified once the state of an interface
- * changes.
- * Parameters
- * IFaceId : Zero-based interface index.
- * AdminState: Is this interface enabled ?
- * HWState : Is this interface physically ready ?
- static void _OnStateChange(unsigned IFaceId, U8 AdminState, U8 HWState) {
- // Check if this is a disconnect from the peer or a link down.
- // In this case call IP_Disconnect() to get into a known state.
- if (((AdminState == IP_ADMIN_STATE_DOWN) && (HWState == 1)) || // Typical for dial-up connection e.g. PPP when closed from peer. Link up but app. closed.
- ((AdminState == IP_ADMIN_STATE_UP) && (HWState == 0))) { // Typical for any Ethernet connection e.g. PPPoE. App. opened but link down.
- IP_Disconnect(IFaceId); // Disconnect the interface to a clean state.
- * _closesocket()
- * Wrapper for closesocket()
- static int _closesocket(long pConnectionInfo) {
- int r;
- struct linger Linger;
- Linger.l_onoff = 1; // Enable linger for this socket to verify that all data is send.
- Linger.l_linger = 1; // Linger timeout in seconds
- setsockopt((long)pConnectionInfo, SOL_SOCKET, SO_LINGER, &Linger, sizeof(Linger));
- r = closesocket((long)pConnectionInfo);
- return r;
- * _Recv()
- * Wrapper for recv()
- static int _Recv(unsigned char *buf, int len, void *pConnectionInfo) {
- int r;
- r = recv((long)pConnectionInfo, (char *)buf, len, 0);
- return r;
- * _Send()
- * Wrapper for send()
- static int _Send(const unsigned char *buf, int len, void* pConnectionInfo) {
- int r;
- r = send((long)pConnectionInfo, (const char *)buf, len, 0);
- return r;
- * WEBS_IP_API
- * Description
- * IP related function table
- static const WEBS_IP_API _Webs_IP_API = {
- _Send,
- _Recv
- * _Alloc()
- * Wrapper for Alloc(). (emNet: IP_MEM_Alloc())
- static void * _Alloc(U32 NumBytesReq) {
- return IP_AllocEx(_aPool, NumBytesReq);
- * _Free()
- static void _Free(void *p) {
- IP_Free(p);
- * WEBS_SYS_API
- * Description
- * System related function table
- static const WEBS_SYS_API _Webs_SYS_API = {
- _Alloc,
- _Free
- * _AddToConnectCnt
- static void _AddToConnectCnt(int Delta) {
- OS_IncDI();
- _ConnectCnt += Delta;
- OS_DecRI();
- * _WebServerChildTask
- static void _WebServerChildTask(void *pContext) {
- WEBS_CONTEXT ChildContext;
- long hSock;
- int Opt;
- int r;
- hSock = (long)pContext;
- Opt = 1;
- setsockopt(hSock, SOL_SOCKET, SO_KEEPALIVE, &Opt, sizeof(Opt));
- IP_WEBS_Init(&ChildContext, &_Webs_IP_API, &_Webs_SYS_API, _pFS_API, &WebsSample_Application); // Initialize the context of the child task.
- if (_ConnectCnt < MAX_CONNECTIONS) {
- r = IP_WEBS_ProcessEx(&ChildContext, pContext, NULL);
- } else {
- r = IP_WEBS_ProcessLastEx(&ChildContext, pContext, NULL);
- if (r != WEBS_CONNECTION_DETACHED) {
- // Only close the socket if it is still in web server context and has
- // not been detached to another handler like a WebSocket handler.
- _closesocket(hSock);
- OS_EnterRegion();
- _AddToConnectCnt(-1);
- OS_Terminate(0);
- OS_LeaveRegion();
- * _WebServerParentTask
- static void _WebServerParentTask(void) {
- struct sockaddr_in InAddr;
- U32 Timeout;
- U32 NumBytes;
- long hSockListen;
- long hSock;
- int i;
- int t;
- int t0;
- int r;
- WEBS_BUFFER_SIZES BufferSizes;
- Timeout = IDLE_TIMEOUT;
- // Assign file system
- _pFS_API = &IP_FS_ReadOnly; // To use a a real filesystem like emFile replace this line.
- // _pFS_API = &IP_FS_emFile; // Use emFile
- // IP_WEBS_AddUpload(); // Enable upload
- // Configure buffer size.
- IP_MEMSET(&BufferSizes, 0, sizeof(BufferSizes));
- BufferSizes.NumBytesInBuf = WEBS_IN_BUFFER_SIZE;
- BufferSizes.NumBytesOutBuf = IP_TCP_GetMTU(_IFaceId) - 72; // Use max. MTU configured for the last interface added minus worst case IPv4/TCP/VLAN headers.
- // Calculation for the memory pool is done under assumption of the best case headers with - 40 bytes.
- BufferSizes.NumBytesParaBuf = WEBS_PARA_BUFFER_SIZE;
- BufferSizes.NumBytesFilenameBuf = WEBS_FILENAME_BUFFER_SIZE;
- BufferSizes.MaxRootPathLen = WEBS_MAX_ROOT_PATH_LEN;
- // Configure the size of the buffers used by the Webserver child tasks.
- IP_WEBS_ConfigBufSizes(&BufferSizes);
- // Check memory pool size.
- NumBytes = IP_WEBS_CountRequiredMem(NULL); // Get NumBytes for internals of one child thread.
- NumBytes = (NumBytes + 64) * MAX_CONNECTIONS; // Calc. the total amount for x connections (+ some bytes for managing a memory pool).
- IP_Logf_Application("WEBS: Using a memory pool of %lu bytes for %lu connections.", sizeof(_aPool), MAX_CONNECTIONS);
- if (NumBytes > sizeof(_aPool)) {
- IP_Warnf_Application("WEBS: Memory pool should be at least %lu bytes.", NumBytes);
- // Give the stack some more memory to enable the dynamical memory allocation for the Web server child tasks
- IP_AddMemory(_aPool, sizeof(_aPool));
- // Get a socket into listening state
- hSockListen = socket(AF_INET, SOCK_STREAM, 0);
- if (hSockListen == SOCKET_ERROR) {
- while(1); // This should never happen!
- IP_MEMSET(&InAddr, 0, sizeof(InAddr));
- InAddr.sin_family = AF_INET;
- InAddr.sin_port = htons(SERVER_PORT);
- InAddr.sin_addr.s_addr = INADDR_ANY;
- bind(hSockListen, (struct sockaddr *)&InAddr, sizeof(InAddr));
- listen(hSockListen, BACK_LOG);
- // Loop once per client and create a thread for the actual server
- do {
- Next:
- // Wait for an incoming connection
- hSock = 0;
- if ((hSock = accept(hSockListen, NULL, NULL)) == SOCKET_ERROR) {
- continue; // Error
- // Create server thread to handle connection.
- // If connection limit is reached, keep trying for some time before giving up and outputting an error message
- t0 = OS_GetTime32() + 1000;
- do {
- for (i = 0; i < MAX_CONNECTIONS; i++) {
- r = OS_IsTask(&_aWebTasks[i]);
- if (r == 0) {
- setsockopt(hSock, SOL_SOCKET, SO_RCVTIMEO, &Timeout, sizeof(Timeout)); // Set receive timeout for the client.
- OS_CREATETASK_EX(&_aWebTasks[i], "Webserver Child", _WebServerChildTask, TASK_PRIO_WEBS_CHILD, _aWebStacks[i], (void *)hSock);
- _AddToConnectCnt(1);
- goto Next;
- // Check time out
- t = OS_GetTime32();
- if ((t - t0) > 0) {
- IP_WEBS_OnConnectionLimit(_Send, _Recv, (void*)hSock);
- break;
- OS_Delay(10);
- } while(1);
- } while(1);
- * _OnRx
- * Discover client UDP callback. Called from stack
- * whenever we get a discover request.
- * Return value
- * IP_RX_ERROR if packet is invalid for some reason
- * IP_OK if packet is valid
- #if ETH_UDP_DISCOVER_PORT
- static int _OnRx(IP_PACKET *pInPacket, void *pContext) {
- char * pInData;
- IP_PACKET * pOutPacket;
- char * pOutData;
- U32 TargetAddr;
- U32 IPAddr;
- unsigned IFaceId;
- (void)pContext;
- IFaceId = IP_UDP_GetIFIndex(pInPacket); // Find out the interface that the packet came in.
- IPAddr = htonl(IP_GetIPAddr(IFaceId));
- if (IPAddr == 0) {
- goto Done;
- pInData = (char*)IP_UDP_GetDataPtr(pInPacket);
- if (memcmp(pInData, "Discover", 8)) {
- goto Done;
- // Alloc packet
- pOutPacket = IP_UDP_AllocEx(IFaceId, PACKET_SIZE);
- if (pOutPacket == NULL) {
- goto Done;
- // Fill packet with data
- pOutData = (char*)IP_UDP_GetDataPtr(pOutPacket);
- IP_UDP_GetSrcAddr(pInPacket, &TargetAddr, sizeof(TargetAddr)); // Send back Unicast
- memset(pOutData, 0, PACKET_SIZE);
- strcpy(pOutData + 0x00, "Found");
- memcpy(pOutData + 0x20, (void*)&IPAddr, 4); // 0x20: IP address
- IP_GetHWAddr(IFaceId, (U8*)pOutData + 0x30, 6); // 0x30: MAC address
- // Send packet
- IP_UDP_SendAndFree(IFaceId, TargetAddr, ETH_UDP_DISCOVER_PORT, ETH_UDP_DISCOVER_PORT, pOutPacket);
- Done:
- return IP_OK;
- #endif
- #endif
- * _StartIPTask
- * Task that initializes the IP stack and starts the WebServer tasks
- * if required.
- static void _StartIPTask(void) {
- IP_Init();
- _IFaceId = IP_INFO_GetNumInterfaces() - 1; // Get the last registered interface ID as this is most likely the interface we want to use in this sample.
- // Start TCP/IP task
- OS_CREATETASK(&_IPTCB, "IP_Task", IP_Task, TASK_PRIO_IP_TASK, _IPStack);
- #if USE_RX_TASK
- OS_CREATETASK(&_IPRxTCB, "IP_RxTask", IP_RxTask, TASK_PRIO_IP_RX_TASK, _IPRxStack); // Start the IP_RxTask, optional.
- #endif
- IP_AddStateChangeHook(&_StateChangeHook, _OnStateChange); // Register hook to be notified on disconnects.
- IP_Connect(_IFaceId); // Connect the interface if necessary.
- // IPv4 address configured ?
- while (IP_IFaceIsReadyEx(_IFaceId) == 0) {
- OS_Delay(200);
- OS_SetPriority(OS_GetTaskID(), TASK_PRIO_WEBS_PARENT); // This task has highest prio!
- OS_SetTaskName(OS_GetTaskID(), "IP_WebServer");
- // Open UDP port ETH_UDP_DISCOVER_PORT for emNet discover
- IP_UDP_Open(0L /* any foreign host */, ETH_UDP_DISCOVER_PORT, ETH_UDP_DISCOVER_PORT, _OnRx, 0L);
- #endif
- IP_WEBS_X_SampleConfig(); // Load a web server sample config that might add other resources like REST.
- _WebServerParentTask();
- #endif
- * Local functions
- * _GetTaskIndex()
- * Returns the zero-based index of the currently scheduled VNC task.
- * Return value
- * Task index : >= 0
- * Error : == -1
- static int _GetTaskIndex(void) {
- OS_TASK * pTask;
- int i;
- pTask = OS_GetTaskID();
- i = 0;
- // Look for index of this task.
- while (&_aTasks[i].VNCServer_TCB != pTask) {
- if (i >= VNC_MAX_CLIENTS) {
- return -1;
- i++;
- return i;
- * _cbWebSocket_GenerateAcceptKey()
- * Generates the value to send back for the Sec-WebSocket-Accept
- * field when accepting the connection.
- * Parameters
- * pOutput : Web server connection context.
- * pSecWebSocketKey : Pointer to a buffer containing the string of
- * the Sec-WebSocket-Key from the HTTP request.
- * SecWebSocketKeyLen: Number of characters of the Sec-WebSocket-Key
- * (without string termination).
- * pBuffer : Buffer where to store the accept key.
- * BufferSize : Size of buffer where to store the accept key.
- * Return value
- * Length of accept key : > 0
- * Error, buffer not big enough: == 0
- static int _cbWebSocket_GenerateAcceptKey(WEBS_OUTPUT* pOutput, void* pSecWebSocketKey, int SecWebSocketKeyLen, void* pBuffer, int BufferSize) {
- WEBS_USE_PARA(pOutput);
- return IP_WEBSOCKET_GenerateAcceptKey(pSecWebSocketKey, SecWebSocketKeyLen, pBuffer, BufferSize);
- * _cbWebSocket_DispatchConnection()
- * Dispatches the web server connection to the VNC server for
- * further handling and signals the VNC server task.
- * Parameters
- * pConnection: Network connection handle.
- static void _cbWebSocket_DispatchConnection(WEBS_OUTPUT* pOutput, void* pConnection) {
- int i;
- OS_EnterRegion(); // Make sure that _pConnection does not get set from another task after being read by us.
- // Check current connections
- for (i = 0; i < VNC_MAX_CLIENTS; i++) {
- if (_aConnections[i].pConnection == pConnection) {
- break;
- if (_aConnections[i].pConnection == NULL) {
- _aConnections[i].pConnection = pConnection;
- _aConnections[i].SocketType = SOCKET_TYPE_WEBSOCKET;
- OS_LeaveRegion();
- return;
- OS_LeaveRegion();
- closesocket((long)pConnection);
- * _cbWebSocket_Recv()
- * WebSocket callback that for sending data using the underlying
- * network communication API (typically BSD socket API).
- * Parameters
- * pContext : WebSocket context.
- * pData : Where to store the received data.
- * NumBytes : Maximum amount of data to receive.
- * Return value
- * Amount of data received: > 0
- * Connection closed : == 0
- * Error : < 0
- static int _cbWebSocket_Recv(IP_WEBSOCKET_CONTEXT* pContext, IP_WEBSOCKET_CONNECTION* pConnection, void* pData, unsigned NumBytes) {
- IP_USE_PARA(pContext);
- return recv((long)pConnection, (char*)pData, NumBytes, 0);
- * _cbWebSocket_Send()
- * Parameters
- * pData : Data to send.
- * NumBytes : Amount of data to send.
- * Return value
- * Amount of data sent: > 0
- * Error : < 0
- static int _cbWebSocket_Send(IP_WEBSOCKET_CONTEXT* pContext, IP_WEBSOCKET_CONNECTION* pConnection, const void* pData, unsigned NumBytes) {
- return send((long)pConnection, (const char*)pData, NumBytes, 0);
- * _cbVNC_RecvWebSocket()
- * This function is called indirectly by the server; it's address
- * is passed to the actual server code as function pointer. It is
- * needed because the server is independent of the TCP/IP stack
- * implementation, so details for the TCP/IP stack can be placed
- * here.
- * Parameters
- * pConnection: Connection handle (WebSocket context).
- * Return value
- * Error : < 0
- static int _cbVNC_RecvWebSocket(U8* pData, int NumBytes, void* pConnection) {
- IP_WEBSOCKET_CONTEXT * pContext;
- int r;
- int NumBytesAtOnce;
- int i;
- U8 * pMsgType;
- U8 Close;
- r = -1; // Assume error.
- // Get ID of task to get the correct pointer to the message type.
- // If for some reason an incorrect task index is returned, close the socket.
- i = _GetTaskIndex();
- Close = IP_WEBSOCKET_FRAME_TYPE_CLOSE;
- pMsgType = (i < 0) ? &Close : &_aConnections[i].MessageType;
- pContext = (IP_WEBSOCKET_CONTEXT*)pConnection;
- if (NumBytes != 0) {
- do {
- if (pContext->NumBytesLeft != 0u) {
- r = (int)pContext->NumBytesLeft;
- } else {
- r = IP_WEBSOCKET_WaitForNextMessage(pContext, pMsgType);
- if (r > 0) { // O.K. ?
- if (*pMsgType == IP_WEBSOCKET_FRAME_TYPE_CLOSE) {
- IP_WEBSOCKET_Close(pContext, NULL, IP_WEBSOCKET_CLOSE_CODE_NORMAL_CLOSURE);
- r = 0; // Pretend connection closed.
- } else if (*pMsgType == IP_WEBSOCKET_FRAME_TYPE_BINARY) { // VNC uses binary messages.
- NumBytesAtOnce = SEGGER_MIN(NumBytes, pContext->NumBytesLeft);
- r = IP_WEBSOCKET_Recv(pContext, pData, NumBytesAtOnce);
- if (r > 0) {
- NumBytes -= r;
- } else {
- r = -1; // Error, pretend communication error as we expect binary messages.
- } while ((r > 0) && (NumBytes != 0));
- return r;
- * _cbVNC_SendWebSocket()
- * here.
- * Parameters
- * pConnection: Connection handle.
- * Return value
- * Error : < 0
- static int _cbVNC_SendWebSocket(const U8* pData, int NumBytes, void* pConnection) {
- IP_WEBSOCKET_CONTEXT* pContext;
- int r;
- r = IP_WEBSOCKET_Send(pContext, pData, NumBytes, IP_WEBSOCKET_FRAME_TYPE_BINARY, 0); // Send a single frame (FIN bit set of data).
- if (r == 0) { // Connection closed ? => Send our close.
- return r;
- #endif
- #if GUI_VNC_SUPPORT_PLAIN_SOCKET_SERVER
- * _cbVNC_Recv()
- * here.
- * Parameters
- * Return value
- * Error : < 0
- static int _cbVNC_Recv(U8* pData, int NumBytes, void* pConnection) {
- * _cbVNC_Send()
- * here.
- * Parameters
- * Return value
- * Error : < 0
- static int _cbVNC_Send(const U8* pData, int NumBytes, void* pConnection) {
- * _ListenAtTCPAddr()
- * Creates a non-blocking socket for accepting a VNC connection.
- * Parameters
- * Port: Port to use for accepting connections.
- * Return value
- * Parent socket handle.
- static int _ListenAtTCPAddr(U16 Port) {
- int hSock;
- hSock = socket(AF_INET, SOCK_STREAM, 0);
- if (hSock <= 0) {
- while (1); // Should not happen.
- memset(&InAddr, 0, sizeof(InAddr));
- InAddr.sin_port = htons(Port);
- bind(hSock, (struct sockaddr*)&InAddr, sizeof(InAddr));
- listen(hSock, 1);
- setsockopt(hSock, SOL_SOCKET, SO_NBIO, NULL, 0); // Set socket non-blocking.
- return hSock;
- #endif
- * _ServerTask()
- * This routine is the actual server task.
- * It waits in an endless loop for a new WebSocket connection to be
- * signaled and handles the VNC connection.
- static void _ServerTask(void) {
- IP_WEBSOCKET_CONTEXT WebSocketContext[VNC_MAX_CLIENTS];
- #elif GUI_VNC_SUPPORT_PLAIN_SOCKET_SERVER
- int hSockParent;
- int SoError;
- int hSock;
- #endif
- int i;
- // Get ID of this task.
- // Start listening on a BSD socket for a connection.
- // WebSocket connections will be dispatched by the Web Server.
- hSockParent = _ListenAtTCPAddr(5900 + _aConnections[i].Context.ServerIndex); // Default port for VNC is is 590x, where x is the 0-based layer index.
- #endif
- while (1) {
- // Check that the connection handle is actually valid.
- // A handle of NULL is treated as invalid although some
- // TCP/IP stacks like Windows treat a socket handle of
- // 0 as valid. However this occurs very rare and in this
- // situation the peer should simply close the connection
- // after some time due to a timeout.
- // We will first check if a connection handle is present
- // which means checking for a WebSocket handle. If no
- // WebSocket handle is active we will check non-blocking
- // if there is any BSD socket to accept.
- #if (GUI_VNC_SUPPORT_PLAIN_SOCKET_SERVER == 0)
- OS_Delay(50); // Grant the system some time between retrying.
- continue;
- #else
- // Check if we have a connection to accept on the regular VNC port.
- hSock = accept(hSockParent, NULL, NULL);
- if (hSock == SOCKET_ERROR) {
- OS_LeaveRegion();
- // Check if this is an IP_ERR_WOULD_BLOCK or a real error.
- getsockopt(hSockParent, SOL_SOCKET, SO_ERROR, &SoError, sizeof(SoError));
- if (SoError != IP_ERR_WOULD_BLOCK) {
- while(1); // Should not happen.
- continue;
- // We have a connection on the regular VNC port.
- setsockopt(hSock, SOL_SOCKET, SO_BIO, NULL, 0); // Set child socket blocking.
- _aConnections[i].SocketType = SOCKET_TYPE_BSD;
- _aConnections[i].pConnection = (void*)hSock;
- OS_LeaveRegion();
- #endif
- if (_aConnections[i].SocketType == SOCKET_TYPE_WEBSOCKET) {
- // Initialize the WebSocket context for the server.
- IP_WEBSOCKET_InitServer(&WebSocketContext[i], &_WebSocketTransportAPI, (IP_WEBSOCKET_CONNECTION*)_aConnections[i].pConnection);
- // Run the actual server using the WebSocket context as connection handle.
- GUI_VNC_Process(&_aConnections[i].Context, _cbVNC_SendWebSocket, _cbVNC_RecvWebSocket, (void*)&WebSocketContext[i]);
- #endif
- if (_aConnections[i].SocketType == SOCKET_TYPE_BSD) {
- // Run the actual server using the BSD socket handle as connection handle.
- GUI_VNC_Process(&_aConnections[i].Context, _cbVNC_Send, _cbVNC_Recv, _aConnections[i].pConnection);
- #endif
- // Close the connection and invalidate the connection handle
- // so we can accept a new client.
- closesocket((long)_aConnections[i].pConnection);
- _aConnections[i].pConnection = NULL;
- * Global functions
- * GUI_VNC_X_StartServer()
- * This routine starts a separate task for the VNC server. It
- * requires that the OS and TCP/IP stack are already initialized.
- * Parameters
- * LayerIndex : Index of the GUI layer that is shown via VNC.
- * ServerIndex: Zero-based server index.
- * Return value
- * O.K.: 0
- * Additional information
- * This sample is intended to be used for starting one VNC server.
- * In case multiple layers shall be accessed by different server
- * instances (ServerIndex) this sample needs to be modified.
- int GUI_VNC_X_StartServer(int LayerIndex, int ServerIndex) {
- GUI_VNC_CONTEXT * pContext;
- char acName[16];
- GUI_VNC_CONTEXT * pContextTemp;
- // Check if maximum number of VNC clients is not exceeded.
- if (ServerIndex >= VNC_MAX_CLIENTS) {
- return -1;
- pContext = &_aConnections[ServerIndex].Context;
- // Init VNC context and attach to layer (so context is
- // updated if the display-layer-contents change).
- // If we already have a device, set the device pointer
- // to the already created one.
- if (_pFirstContext == NULL) {
- GUI_VNC_AttachToLayer(pContext, LayerIndex);
- _pFirstContext = pContext;
- } else {
- // New context makes use of existing device.
- pContext->pDevice = _pFirstContext->pDevice;
- pContext->xSize = _pFirstContext->xSize;
- pContext->ySize = _pFirstContext->ySize;
- pContext->BitsPerPixel = _pFirstContext->BitsPerPixel;
- pContext->pNext = NULL;
- // Update pNext pointers
- pContextTemp = _pFirstContext;
- while (pContextTemp->pNext) {
- pContextTemp = pContextTemp->pNext;
- pContextTemp->pNext = pContext;
- pContext->ServerIndex = ServerIndex;
- // Set up pointer to RFB buffer.
- pContext->pBuffer = _aConnections[ServerIndex].acBuffer;
- pContext->SizeOfBuffer = GUI_VNC_BUFFER_SIZE;
- // If this is the first time a VNC server is opened, start the IP stack.
- if (!_IPStackInit) {
- OS_CREATETASK(&TCB_IP_Main, "IP_MainTask", _StartIPTask, 110, Stack_IP_Main);
- _StartIPTask();
- #endif
- _IPStackInit = 1;
- // Create task for VNC server. It will wait for the signal
- // of a dispatched WebSocket connection.
- sprintf(acName, "VNC Server %d", ServerIndex);
- OS_CREATETASK(&_aTasks[ServerIndex].VNCServer_TCB, acName, _ServerTask, TASKPRIO_VNC, _aTasks[ServerIndex].VNCServer_Stack);
- // Enable WebSockets for the web server and setup the
- // URI "/websockify" with sub protocol "binary" for the
- // VNC data transfer.
- IP_WEBS_WEBSOCKET_AddHook(&_aConnections[ServerIndex].WebSocketHook, &_WebServerWebSocketAPI, WEBSOCKET_VNC_URI, WEBSOCKET_VNC_PROTO);
- #endif
- return 0;
- * GUI_VNC_X_getpeername()
- * Retrieves the IP addr. of the currently connected VNC client.
- * Parameters
- * ServerIndex: Index of server instance.
- * pIPAddr:[OUT] VNC client connected: U32 IP addr. in network endianess.
- * No client connected : 0
- void GUI_VNC_X_getpeername(int ServerIndex, U32 * pIPAddr) {
- struct sockaddr_in Client;
- int Len;
- if ((ServerIndex >= VNC_MAX_CLIENTS) || (ServerIndex < 0)) {
- return;
- if (pIPAddr) {
- pConnection = _aConnections[ServerIndex].pConnection;
- if (pConnection != NULL) {
- Len = sizeof(Client);
- getpeername((long)pConnection, (struct sockaddr*)&Client, &Len);
- *pIPAddr = Client.sin_addr.s_addr;
- } else {
- *pIPAddr = 0;
- /*************************** End of file ****************************/
