查看: 1089|回复: 3
i2c硬件配置读取lsm6dsow传感器
发表于 2022-5-23 16:37:05 | 显示全部楼层 |阅读模式
关于i2c硬件配置读取lsm6dsow传感器:
i2c3_scl :pg7
i2c3_sda:pg8
int I2CInit(int Index)
   if (Index == I2C3_ID){
        /*##-1- Configure the I2C peripheral ######################################*/
        I2cHandle[Index].Instance             = I2C3;
        I2cHandle[Index].Init.Timing          = 0x307075B1;
        I2cHandle[Index].Init.AddressingMode  = I2C_ADDRESSINGMODE_7BIT;
        I2cHandle[Index].Init.DualAddressMode = I2C_DUALADDRESS_DISABLE;
        I2cHandle[Index].Init.OwnAddress1     = 0;
        I2cHandle[Index].Init.OwnAddress2     = 0;
        I2cHandle[Index].Init.GeneralCallMode = I2C_GENERALCALL_DISABLE;
        I2cHandle[Index].Init.NoStretchMode   = I2C_NOSTRETCH_DISABLE;
        if(HAL_I2C_Init(&I2cHandle[Index]) != HAL_OK){
            printf("I2C3 init error \r\n");
            while(1);
        /* Enable the Analog I2C Filter使能模拟i2c过滤器 */
        HAL_I2CEx_ConfigAnalogFilter(&I2cHandle[Index],I2C_ANALOGFILTER_ENABLE);
    return 0;
void HAL_I2C_MspInit(I2C_HandleTypeDef *hi2c)
    GPIO_InitTypeDef  GPIO_InitStruct;
    RCC_PeriphCLKInitTypeDef  RCC_PeriphCLKInitStruct;
    static DMA_HandleTypeDef hdma_tx;
    static DMA_HandleTypeDef hdma_rx;
    if (hi2c->Instance == I2C3){
      /*##-1- Configure the I2C clock source. The clock is derived from the SYSCLK #*/
      RCC_PeriphCLKInitStruct.PeriphClockSelection = RCC_PERIPHCLK_I2C3;
      RCC_PeriphCLKInitStruct.I2c3ClockSelection = RCC_I2C3CLKSOURCE_SYSCLK;
      HAL_RCCEx_PeriphCLKConfig(&RCC_PeriphCLKInitStruct);
      /*##-2- Enable peripherals and GPIO Clocks #################################*/
      /* Enable GPIO TX/RX clock */
      __HAL_RCC_GPIOG_CLK_ENABLE();
      /* Enable I2Cx clock */
      __HAL_RCC_I2C3_CLK_ENABLE();
      /* Enable DMAx clock */
      __HAL_RCC_DMA1_CLK_ENABLE();
      __HAL_RCC_DMAMUX1_CLK_ENABLE();
    //pg8是sda、pg7是sck
      /*##-3- Configure peripheral GPIO ##########################################*/
      /* I2C TX GPIO pin configuration  发送gpio芯片配置*/
      GPIO_InitStruct.Pin              = GPIO_PIN_7;
      GPIO_InitStruct.Mode             = GPIO_MODE_OUTPUT_OD;//开漏
      GPIO_InitStruct.Pull             = GPIO_NOPULL;
      GPIO_InitStruct.Speed            = GPIO_SPEED_FREQ_VERY_HIGH;//高速
      GPIO_InitStruct.Alternate        = GPIO_AF4_I2C3; //引脚复用
      HAL_GPIO_Init(GPIOG, &GPIO_InitStruct);
      /* I2C RX GPIO pin configuration  读gpio芯片配置*/
      GPIO_InitStruct.Pin              = GPIO_PIN_8;
      /*##-4- Configure the DMA Channels #########################################*/
      /* Configure the DMA handler for Transmission process */
      hdma_tx.Instance                 = DMA1_Channel2;//通道2发送
      hdma_tx.Init.Request             = DMA_REQUEST_I2C3_TX;//i2c3发射
      hdma_tx.Init.Direction           = DMA_MEMORY_TO_PERIPH;//内存到外设模式
      hdma_tx.Init.PeriphInc           = DMA_PINC_DISABLE;//外设地址
      hdma_tx.Init.MemInc              = DMA_MINC_ENABLE;//内存地址递增
      hdma_tx.Init.PeriphDataAlignment = DMA_PDATAALIGN_BYTE;//外设数据以字节对齐
      hdma_tx.Init.MemDataAlignment    = DMA_MDATAALIGN_BYTE;//内存数据以字节对齐
      hdma_tx.Init.Mode                = DMA_NORMAL;//正常模式传输
      hdma_tx.Init.Priority            = DMA_PRIORITY_LOW;//低优先级
      if(HAL_DMA_Init(&hdma_tx)!= HAL_OK){
            printf("hdma_tx error\r\n");
      /* Associate the initialized DMA handle to the the I2C handle */
      __HAL_LINKDMA(hi2c, hdmatx, hdma_tx);
      hdma_rx.Instance                 = DMA1_Channel3;//接收
      hdma_rx.Init.Request             = DMA_REQUEST_I2C3_RX;
      hdma_rx.Init.Direction           = DMA_PERIPH_TO_MEMORY;//外设到内存
      hdma_rx.Init.PeriphInc           = DMA_PINC_DISABLE;
      hdma_rx.Init.MemInc              = DMA_MINC_ENABLE;
      hdma_rx.Init.PeriphDataAlignment = DMA_PDATAALIGN_BYTE;
      hdma_rx.Init.MemDataAlignment    = DMA_MDATAALIGN_BYTE;
      hdma_rx.Init.Mode                = DMA_NORMAL;
      hdma_rx.Init.Priority            = DMA_PRIORITY_HIGH;
      if(HAL_DMA_Init(&hdma_rx)!= HAL_OK){
            printf("hdma_rx error\r\n");
      __HAL_LINKDMA(hi2c, hdmarx, hdma_rx);
      /*##-5- Configure the NVIC for DMA #########################################*/
      /* NVIC configuration for DMA transfer complete interrupt (I2Cx_TX) */
      HAL_NVIC_SetPriority(DMA1_Channel2_IRQn, 0, 0);
      HAL_NVIC_EnableIRQ(DMA1_Channel2_IRQn);
      /* NVIC configuration for DMA transfer complete interrupt (I2Cx_RX) */
      HAL_NVIC_SetPriority(DMA1_Channel3_IRQn, 0, 0);
      HAL_NVIC_EnableIRQ(DMA1_Channel3_IRQn);
      /*##-6- Configure the NVIC for I2C #########################################*/
      /* NVIC for I2Cx */
      HAL_NVIC_SetPriority(I2C3_ER_IRQn, 0, 1);
      HAL_NVIC_EnableIRQ(I2C3_ER_IRQn);
      HAL_NVIC_SetPriority(I2C3_EV_IRQn, 0, 2);
      HAL_NVIC_EnableIRQ(I2C3_EV_IRQn);
void HAL_I2C_MspDeInit(I2C_HandleTypeDef *hi2c)
        /* I2C3:SCL: PG7   SDA: PG8 */
        /*##-1- Reset peripherals ##################################################*/
        __HAL_RCC_I2C3_FORCE_RESET();
        __HAL_RCC_I2C3_RELEASE_RESET();
        /*##-2- Disable peripherals and GPIO Clocks #################################*/
        /* Configure I2C Tx as alternate function  */
        HAL_GPIO_DeInit(GPIOG, GPIO_PIN_7);
        /* Configure I2C Rx as alternate function  */
        HAL_GPIO_DeInit(GPIOG, GPIO_PIN_8);
        /*##-3- Disable the DMA Channels ###########################################*/
        /* De-Initialize the DMA Channel associated to transmission process */
        HAL_DMA_DeInit(&hdma_tx);
        /* De-Initialize the DMA Channel associated to reception process */
        HAL_DMA_DeInit(&hdma_rx);
        /*##-4- Disable the NVIC for DMA ###########################################*/
        HAL_NVIC_DisableIRQ(DMA1_Channel2_IRQn);
        HAL_NVIC_DisableIRQ(DMA1_Channel3_IRQn);
        /*##-5- Disable the NVIC for I2C ###########################################*/
        HAL_NVIC_DisableIRQ(I2C3_ER_IRQn);
        HAL_NVIC_DisableIRQ(I2C3_EV_IRQn);
void I2C_Read(int Index,unsigned char DeviceAddress,int AddressStart,unsigned char *pReadBuf,int ReadNum)
    /* LPS33K_I2C_ADD   0x5D --->0xBA      LPS33K_ID            0xB1  */
    /* NST118_I2C_ADD   0x48 --->0x90        */
    /*lsdow_i2c_add   0xD5 */
    if(Index == I2C3_ID){
         uint8_t  ret = HAL_I2C_Mem_Read_DMA(&I2cHandle[Index],(uint16_t)((DeviceAddress << 1)),
        AddressStart, I2C_MEMADD_SIZE_8BIT, pReadBuf, ReadNum);
        if(ret == 0)
            printf("hal ok\r\n");
        else if(ret == 1){
            printf("hal error\r\n");
        else if(ret == 2){
            printf("hal busy\r\n");
            printf("hal timeout\r\n");
        /* Wait for the end of the transfer */
        while (HAL_I2C_GetState(&I2cHandle[Index]) != HAL_I2C_STATE_READY){
void I2C_Write(int Index,unsigned char DeviceAddress,int AddressStart,unsigned char *pWriteBuf,int WriteNum)
    /* Write EEPROM_PAGESIZE */
    if(HAL_I2C_Mem_Write_DMA(&I2cHandle[Index] , (uint16_t)(DeviceAddress<<1), AddressStart,
    I2C_MEMADD_SIZE_8BIT, (unsigned char*)pWriteBuf, WriteNum)!= HAL_OK)
        /* Writing process Error */
        // Error_Handler();
        printf("HAL_I2C_Mem_Write_DMA error ! \r\n");
    /*  Before starting a new communication transfer, you need to check the current
    state of the peripheral; if it抯 busy you need to wait for the end of current
    transfer before starting a new one.
    For simplicity reasons, this example is just waiting till the end of the
    transfer, but application may perform other tasks while transfer operation
    is ongoing. */
static int32_t platform_write1(void *handle, uint8_t reg,uint8_t *bufp, uint16_t len)
    I2C_Write(I2C3_ID,LSM6DSO_I2C_ADD_L,reg,(uint8_t*)bufp,len);
    return 0;
//i2c3读寄存器操作
static int32_t platform_read1(void *handle, uint8_t reg, uint8_t *bufp, uint16_t len)
    I2C_Read(I2C3_ID,LSM6DSO_I2C_ADD_L,reg,(uint8_t*)bufp,len);
    printf("reg = 0x%x\r\n",reg);
    return 0;
static void platform_delay(uint32_t ms)
    HAL_Delay(ms);
void LSM6DSO_Init(void)
    uint8_t whoamI,rst;
    lsm6dso_dev_ctx.write_reg1 = platform_write1;
    lsm6dso_dev_ctx.read_reg1 = platform_read1;
    lsm6dso_dev_ctx.handle = NULL;
    platform_delay(BOOT_TIME);
    lsm6dso_device_id_get(&lsm6dso_dev_ctx, &whoamI);
    printf("whoamI = 0x%x\r\n",whoamI);
发表于 2022-5-24 01:57:12 | 显示全部楼层
楼主的是什么问题,程序分享还是什么。
 楼主| 发表于 2022-5-26 13:55:47 | 显示全部楼层
eric2013 发表于 2022-5-24 01:57
楼主的是什么问题,程序分享还是什么。
都显示了图片内容了……,咨询问题
发表于 2022-5-27 01:05:38 | 显示全部楼层
gck 发表于 2022-5-26 13:55
都显示了图片内容了……,咨询问题
这个看不出来有啥问题。
GMT+8, 2025-5-10 12:17 , Processed in 0.370935 second(s), 27 queries .
