[C] 纯文本查看 复制代码 // C/C++ Standard Library Multithreading Interface
#if ( !defined(RTX_NO_MULTITHREAD_CLIB) && \
( defined(__CC_ARM) || \
(defined(__ARMCC_VERSION) && (__ARMCC_VERSION >= 6010050))) && \
!defined(__MICROLIB))
#define LIBSPACE_SIZE 96
//lint -esym(714,__user_perthread_libspace,_mutex_*) "Referenced by C library"
//lint -esym(765,__user_perthread_libspace,_mutex_*) "Global scope"
//lint -esym(9003, os_libspace*) "variables 'os_libspace*' defined at module scope"
// Memory for libspace
static uint32_t os_libspace[OS_THREAD_LIBSPACE_NUM+1][LIBSPACE_SIZE/4] \
__attribute__((section(".bss.os.libspace")));
// Thread IDs for libspace
static osThreadId_t os_libspace_id[OS_THREAD_LIBSPACE_NUM] \
// Check if Kernel has been started
static uint32_t os_kernel_is_active (void) {
static uint8_t os_kernel_active = 0U;
if (os_kernel_active == 0U) {
if (osKernelGetState() > osKernelReady) {
os_kernel_active = 1U;
return (uint32_t)os_kernel_active;
// Provide libspace for current thread
void *__user_perthread_libspace (void);
void *__user_perthread_libspace (void) {
osThreadId_t id;
uint32_t n;
if (os_kernel_is_active() != 0U) {
id = osThreadGetId();
for (n = 0U; n < (uint32_t)OS_THREAD_LIBSPACE_NUM; n++) {
if (os_libspace_id[n] == NULL) {
os_libspace_id[n] = id;
if (os_libspace_id[n] == id) {
if (n == (uint32_t)OS_THREAD_LIBSPACE_NUM) {
(void)osRtxKernelErrorNotify(osRtxErrorClibSpace, id);
} else {
n = OS_THREAD_LIBSPACE_NUM;
//lint -e{9087} "cast between pointers to different object types"
return (void *)&os_libspace[n][0];
// Mutex identifier
typedef void *mutex;
//lint -save "Function prototypes defined in C library"
//lint -e970 "Use of 'int' outside of a typedef"
//lint -e818 "Pointer 'm' could be declared as pointing to const"
// Initialize mutex
__USED
int _mutex_initialize(mutex *m);
int _mutex_initialize(mutex *m) {
int result;
*m = osMutexNew(NULL);
if (*m != NULL) {
result = 1;
} else {
result = 0;
(void)osRtxKernelErrorNotify(osRtxErrorClibMutex, m);
return result;
// Acquire mutex
__USED
void _mutex_acquire(mutex *m);
void _mutex_acquire(mutex *m) {
(void)osMutexAcquire(*m, osWaitForever);
// Release mutex
__USED
void _mutex_release(mutex *m);
void _mutex_release(mutex *m) {
(void)osMutexRelease(*m);
// Free mutex
__USED
void _mutex_free(mutex *m);
void _mutex_free(mutex *m) {
(void)osMutexDelete(*m);
//lint -restore
