查看: 997|回复: 4
[MDK] exit未定义是什么问题
发表于 2022-7-23 17:59:31 | 显示全部楼层 |阅读模式
我在使用MDK的Use MicroLIB选项时,函数中调用exit(1),编译时提示exit未定义是什么问题,程序中已添加<stdlib.h>头文件,有没有人知道的。
发表于 2022-7-24 00:49:43 | 显示全部楼层
微库没有这个。
 楼主| 发表于 2022-7-25 09:03:23 | 显示全部楼层
stdlib.h文件里是这样写的
extern _ARMABI_NORETURN void exit(int /*status*/);
    * causes normal program termination to occur. If more than one call to the
    * exit function is executed by a program, the behaviour is undefined.
    * First, all functions registered by the atexit function are called, in the
    * reverse order of their registration.
    * Next, all open output streams are flushed, all open streams are closed,
    * and all files created by the tmpfile function are removed.
    * Finally, control is returned to the host environment. If the value of
    * status is zero or EXIT_SUCCESS, an implementation-defined form of the
    * status 'successful termination' is returned. If the value of status is
    * EXIT_FAILURE, an implementation-defined form of the status
    * 'unsuccessful termination' is returned. Otherwise the status returned
    * is implementation-defined.
头文件里有对exit函数申明了。
 楼主| 发表于 2022-7-28 11:17:19 | 显示全部楼层
已解决 自己定义下这个函数 如:
_ARMABI_NORETURN void exit(int status)
while(1);
注意:这是一个无返回的函数。
发表于 2022-7-28 11:26:41 | 显示全部楼层
365497604 发表于 2022-7-28 11:17
已解决 自己定义下这个函数 如:
这个属于重定向,防止警告,也行。
GMT+8, 2024-6-4 13:24 , Processed in 0.177728 second(s), 25 queries .
