查看: 102332|回复: 17
[嵌入式周报] 《安富莱嵌入式周报》第284期:2022.09.19--2022.09.25
发表于 2022-9-27 05:29:44 | 显示全部楼层 |阅读模式
GUI综合实战视频教程第1期:综合UI项目规划以及AppWizard和ThreadX GUIX初识(2022-09-24)
https://www.armbbs.cn/forum.php?mod=viewthread&tid=115615
视频版:
https://www.bilibili.com/video/BV1RT411T7PL
1、Matlab2022b发布,支持从 .NET 应用程序调用 MATLAB
https://ww2.mathworks.cn/product ... atest_features.html
视频:
详细更新如下:
2、FatFS作者ChaN老师分享的耳机放大器文章说明已经发布,包含固件源码
http://elm-chan.org/works/hpamp/report.html
/* Headphone Amplifier Controller    (C)ChaN, 2022 */
#include <avr/io.h>
#include <avr/sleep.h>
#include <avr/interrupt.h>
FUSES = {0x6A, 0xFD};                /* ATtiny13A fuses: Low, High */
#define BLV_LOW                2.3                /* Low battery threshold [volt] */
#define BLV_OFF                2.1                /* Shutdown threshold [volt] */
#define        MUL_VIN                0.333
#define        VREF                1.1
#define VOLT2AD(v)        ((uint16_t)(v * MUL_VIN * 1024 / VREF))
#define HOLD_TIME        50                /* Button hold time to trigger on/off (x10ms) */
#define        POWER_ENABLE()        PORTB |= _BV(3)
#define        POWER_DISABLE()        PORTB &= ~_BV(3)
#define        OUT_ENABLE()        PORTB |= _BV(0)
#define        OUT_DISABLE()        PORTB &= ~_BV(0)
#define        LED_ON()                PORTB |= _BV(2)
#define        LED_OFF()                PORTB &= ~_BV(2)
#define BUTTON                        (!(PINB & _BV(1)))
volatile uint8_t Stat;        /* Battery status: 0=empty, 1=low, 2=ok */
ISR(INT0_vect)                        /* Wake-up from sleep mode */
        GIMSK = 0;        /* Disable INT0 (on button down) */
ISR(TIM0_COMPA_vect)        /* 100Hz timer interrupt */
        uint8_t n;
        static uint8_t blink;
        n = Stat;
        if (n == 2 || (n == 1 && (++blink & 32))) {
                LED_ON();
        } else {
                LED_OFF();
static void delay_10ms (void)
        set_sleep_mode(SLEEP_MODE_IDLE);        /* Set Idle mode */
        sleep_mode();
static uint8_t test_button (void)        /* b0:status, b1:trigger */
        static uint8_t btn;
        if (BUTTON) {
                if (btn < HOLD_TIME) {
                        if (++btn == HOLD_TIME) return 3;
                return 1;
        } else {
                btn = 0;
                return 0;
static void power_off_mode (void)
        uint8_t n;
        Stat = 0;        /* LED off */
        for (;;) {
                /* LED off, power off, headphone off */
                LED_OFF();
                OUT_DISABLE();
                POWER_DISABLE();
                /* Wait for button released (100ms) */
                for (n = 10; n; n--) {
                        delay_10ms();
                        if (test_button() != 0) n = 10;
                /* Sleep and resume */
                TIMSK0 = 0;                                        /* Disable timer interrupt */
                cli();                                                /* Disable interrupts for critical operations */
                GIMSK = _BV(INT0);                        /* Enable button down interrupt (INT0) */
                set_sleep_mode(SLEEP_MODE_PWR_DOWN);        /* Set Power-Down mode*/
                sleep_enable();                                /* Enable sleep mode */
                sleep_bod_disable();                /* Disable BOD in sleep mode */
                sei();                                                /* Eneble interrupt to wake-up */
                sleep_cpu();                                /* Enter sleep mode */
                /*------ Sleeping ------*/
                sleep_disable();                        /* Disable sleep mode */
                TIMSK0 = _BV(OCIE0A);                /* Enable timer interrupt */
                /* Press and hold the button for HOLD_TIME to start */
                do {
                        delay_10ms();
                        n = test_button();
                } while (n == 1);
                if (n == 3) break;        /* Exit if the button was held for HOLD_TIME, or stay power off */
        POWER_ENABLE();                /* Enable DC-DC converter */
        Stat = 2;                        /* LED on */
        for (n = 30; n; n--) delay_10ms();        /* 300ms */
        OUT_ENABLE();                /* Ebable headphone output */
static uint8_t battery_level (void)        /* Test battery status (2=ok, 1=low, 0=empty) */
        uint16_t adc;
        ADMUX = _BV(REFS0) | 2;                                        /* Select ADC2 with Vref = internal 1.1V */
        ADCSRA = _BV(ADEN)|_BV(ADSC)|_BV(ADIF)|0b011;        /* Enable ADC and start conversion */
        while (!(ADCSRA & _BV(ADIF))) ;                        /* Wait for EOC */
        adc = ADC;
        ADCSRA = 0;        /* Disable ADC */
        if (adc < VOLT2AD(BLV_OFF)) return 0;        /* Empty? */
        if (adc < VOLT2AD(BLV_LOW)) return 1;        /* Low? */
        return 2;
int main (void)
        uint8_t btct, btlv;
        /* Initialize GPIOs */
        PORTB = 0b00000;                /* Initialize PORTB as: */
        DDRB  = 0b01101;                /* BP4=Vbat, PB3=Power, PB2=LED, PB1=Button, BP0=OutEnable */
        DIDR0 = 0b10000;                /* Disable digital input on PB4 */
        /* Enable TC0 in 100 Hz interval timer */
        OCR0A = F_CPU / 256 / 100 - 1;
        TCCR0A = _BV(WGM01);
        TCCR0B = 0b100;
        sei();
        for (;;) {
                power_off_mode();        /* Power-off and wake-up */
                btct = btlv = 0;
                for (;;) {
                        delay_10ms();
                        if (test_button() == 3) break;        /* Test button */
                        btlv += battery_level();                /* Test battery level */
                        if (++btct == 50) {                                /* 50 times averaging */
                                if (btlv < 25) break;                /* Battery empty? */
                                Stat = btlv < 75 ? 1 : 2;        /* Battery ok or low? */
                                btct = btlv = 0;
3、分享个非常不错的JSON数据可视化在线软件
https://jsoncrack.com/editor
从效果来看非常不错,大大方便数据内容查看
4、英伟达发布2000TFLOPS的雷神芯片Thor,用于自动驾驶
https://blogs.nvidia.com/blog/2022/09/20/drive-thor/
https://www.anandtech.com/show/17582/nvidia-drops-drive-atlan-soc-introduces-2-pflops-drive-thor-for-2025-autos
在上周举行的全球开发者大会上,除了RTX4090显卡,就是这个了。
雷神Thor搭载了770亿晶体管,在算力上达到了2000TFLOPs(1TOPS代表每秒能进行10^12次操作),Thor的算力是特斯拉FSD芯片的14倍。
Atlan方案已经放弃
5、ST推出基于TOF的预定义手势检测系统
https://www.st.com/en/evaluation-tools/aek-sns-2tofm1.html?ecmp=tt28526_gl_social_sep2022
该套件包括两个飞行时间测距传感器,彼此相距23厘米。此方案专为电动升降门应用而设计,可通过预定义的脚部移动来打开/关闭行李箱
对应的官方文档里面有详细说明
6、NASA开源的飞行软件和嵌入式系统框架fprime
https://nasa.github.io/fprime/
fprime是一个软件框架,用于快速开发和部署嵌入式系统和航天应用。最初是由NASA的喷气推进实验室开发的开源软件,已成功被用于多种太空应用。它已被用于但不限于立方体卫星,小型卫星,仪器。
相关的资源链接全部提供了
7、TI分享的CANFD SiC信号改进型收发器视频教程
使用SiC版收发器,可以有效降低信号振铃问题,效果如下:
一般将CANFD的数据通信阶段速度提到8Msps问题大不
https://training.ti.com/designing-can-signal-improvement-capability-sic-transceivers
8、CMSIS-DSP软件包升级至V1.14
https://github.com/ARM-software/CMSIS-DSP/releases
最近更新频繁了,基本上半个月就更新一次。针对计算图,增加了Event Recorder支持
9、Google推出iMX RT1176配合自家珊瑚TPU的套件
https://coral.ai/products/dev-board-micro
规格:
效果:
还有个对应的POE和无线扩展板
10、各大IC厂家的参考设计案例
https://www.ti.com/reference-designs/index.html
https://www.analog.com/en/design-center/reference-designs.html
https://www.maximintegrated.com/ ... -design-center.html
https://www.microchip.com/en-us/tools-resources/reference-designs
之前分享了TI,ADI和美信,这次加入Microchip
数千个完整设计案例供大家参考。
TI:
美信:
ADI:
Microchip
11、牛屎芯片替换
https://www.instructables.com/Replacing-a-40-Pin-COB-With-a-44-Pin-QFP/
搞牛屎芯片替换的玩家非常多,其中尤其以替换万用表的玩家,因为三位半常用的芯片是7106/7107,四位半常用的是7129/7135
这个网上的一位玩家替换效果:
磨掉COB环氧树脂,使用这种封装的优势是成本低
换上新芯片的效果:
12、国产海天芯生产的三位半HT7106和四位半HT7135万用表IC
http://www.htcsemi.com/acpzs.asp?pages=1&dlb_id=37&xlb_id=14
三位半HT7106价格在3-6块,四位半的6-9块,价格还算非常给力。
像TI,瑞萨和美信,也都有相应系列的产品。
13、国内资讯
(1)沁恒的应用方案中心
做的也非常不错
https://www.wch.cn/application.html
他们还有一个选型框图做的也非常好
下面的小方框可以方便的查找
(2)兆易创新发布GD32A503系列首款车规级MCU
https://www.gigadevice.com/zh-hans/press-release/gigadevice-launches-gd32a503/
基于Cortex-M33内核,40nm车规级制程和高速嵌入式闪存eFlash技术,配备384KB Flash和48KB SRAM,另有专用代码空间可配置为64KB DFlash/4KB EEPROM
另外他们的TUV安全认证应该还在进行中,
(3)Holtek推出多款用于电机控制的单片机
https://www.holtek.com.cn/web/guest/news/-/news-center/search/all/2022/all
(4)极海通过TüV莱茵ISO 26262功能安全管理体系认证
https://www.geehy.com/news/news_detail/109
这个还是很给力的,直接上证书
14、H7-TOOL本周进展
H7-TOOL详细介绍:https://www.armbbs.cn/forum.php?mod=viewthread&tid=89934
(1)更新2.1.9版本所需功能。
(2)RTOS Trace初步完成uCOS-III,增加ThreadX的Trace中
uCOS-III初步的界面效果,最终效果略有不同,部分信息会在控件上刷新
这两天增加ThreadX的关键信息Trace,能正常检索了,还要继续改进。
(3)H7-TOOL的截图功能关键部分都已经打通了,下面是截图SDRAM显存数据效果
用户仅需接上SWD接口即可,无需用户嵌入代码到目标,填入显存地址即可。
而截图RA8875屏,太不容易了,坑有点多,因为需要通过SWD接口控制RA8875进入读像素操作,最后也是最关键的一步就是读取是显存地址自增模式,这个坑太多了,比写显存地址自增麻烦很多,花了很长时间才搞定
参与人数 1金币 +8 收起 理由
龙之谷 + 8 很给力!
 楼主| 发表于 2022-9-27 05:29:56 | 显示全部楼层
终于通宵更新完毕。
发表于 2022-9-27 07:20:16 | 显示全部楼层
感谢白工分享,每周必看。多休息,保重身体,别通宵啊
发表于 2022-9-27 08:21:59 | 显示全部楼层
楼主辛苦,第一次离沙发这么近
发表于 2022-9-27 08:42:37 | 显示全部楼层
发表于 2022-9-27 08:50:26 | 显示全部楼层
真的辛苦了!
发表于 2022-9-27 08:50:32 | 显示全部楼层
发表于 2022-9-27 09:20:01 | 显示全部楼层
楼主辛苦了
发表于 2022-9-27 09:22:14 来自手机 | 显示全部楼层
ヾ()~非常好
发表于 2022-9-27 09:47:12 | 显示全部楼层
硬汉哥,真的肝
发表于 2022-9-27 09:59:31 | 显示全部楼层
大佬要多注意身体,要有正常的作息时间。
 楼主| 发表于 2022-9-27 13:22:48 | 显示全部楼层
更新介绍里面的一个小错误。
发表于 2022-9-27 13:33:04 | 显示全部楼层
各大厂家的参考设计案例这个太给力了,原理图和PCBlayout都有,超级赞啊
发表于 2022-9-27 22:51:42 | 显示全部楼层
辛苦啦!  想咨询 云途半导体   http://ytmicro.com/about.php    建议应届生加入吗?
发表于 2022-9-28 10:57:06 | 显示全部楼层
楼主,新的guix教程在哪发的?
发表于 2022-9-29 09:21:29 | 显示全部楼层
现在这个资料挺全的
发表于 2022-9-29 16:31:13 | 显示全部楼层
13、国内资讯
国产MCU这几年发展迅猛,但是还有很多不足
比如,开发工具,技术文档,SDK等配套的软硬件
推广也不给力,比如,官方评估板贵的要死,上面就两颗芯片,买100多甚至200
有的厂家,在官网找不到技术文档和SDK,没有例程
在这点上,做的比较好的是沁恒,几乎每个芯片的主页都能找到对应的技术文档(而且是中文的)、MDK支持包、SDK和例程等等
发表于 2023-7-18 16:07:29 | 显示全部楼层
mark分享个非常不错的JSON数据可视化在线软件
GMT+8, 2025-5-13 20:22 , Processed in 0.384000 second(s), 28 queries .
