查看: 1703|回复: 3
请问C学到什么程度才能开始学板子呀
发表于 2022-11-22 09:38:44 | 显示全部楼层 |阅读模式
请问C学到什么程度才能开始学板子呀
发表于 2022-11-22 10:14:31 | 显示全部楼层
HAL库有个GPIO_Init函数,你能把这个函数的实现捋顺,我觉得大部分代码都可以了
  * @brief  Initializes the GPIOx peripheral according to the specified parameters in the GPIO_Init.
  * @param  GPIOx: where x can be (A..K) to select the GPIO peripheral.
  * @param  GPIO_Init: pointer to a GPIO_InitTypeDef structure that contains
  *         the configuration information for the specified GPIO peripheral.
  * @retval None
void HAL_GPIO_Init(GPIO_TypeDef  *GPIOx, GPIO_InitTypeDef *GPIO_Init)
  uint32_t position = 0x00U;
  uint32_t iocurrent;
  uint32_t temp;
  EXTI_Core_TypeDef *EXTI_CurrentCPU;
#if defined(DUAL_CORE) && defined(CORE_CM4)
  EXTI_CurrentCPU = EXTI_D2; /* EXTI for CM4 CPU */
#else
  EXTI_CurrentCPU = EXTI_D1; /* EXTI for CM7 CPU */
  /* Check the parameters */
  assert_param(IS_GPIO_ALL_INSTANCE(GPIOx));
  assert_param(IS_GPIO_PIN(GPIO_Init->Pin));
  assert_param(IS_GPIO_MODE(GPIO_Init->Mode));
  assert_param(IS_GPIO_PULL(GPIO_Init->Pull));
  /* Configure the port pins */
  while (((GPIO_Init->Pin) >> position) != 0x00U)
    /* Get current io position */
    iocurrent = (GPIO_Init->Pin) & (1UL << position);
    if (iocurrent != 0x00U)
      /*--------------------- GPIO Mode Configuration ------------------------*/
      /* In case of Output or Alternate function mode selection */
      if ((GPIO_Init->Mode == GPIO_MODE_OUTPUT_PP) || (GPIO_Init->Mode == GPIO_MODE_AF_PP) ||
          (GPIO_Init->Mode == GPIO_MODE_OUTPUT_OD) || (GPIO_Init->Mode == GPIO_MODE_AF_OD))
        /* Check the Speed parameter */
        assert_param(IS_GPIO_SPEED(GPIO_Init->Speed));
        /* Configure the IO Speed */
        temp = GPIOx->OSPEEDR;
        temp &= ~(GPIO_OSPEEDR_OSPEED0 << (position * 2U));
        temp |= (GPIO_Init->Speed << (position * 2U));
        GPIOx->OSPEEDR = temp;
        /* Configure the IO Output Type */
        temp = GPIOx->OTYPER;
        temp &= ~(GPIO_OTYPER_OT0 << position) ;
        temp |= (((GPIO_Init->Mode & GPIO_OUTPUT_TYPE) >> 4U) << position);
        GPIOx->OTYPER = temp;
      /* Activate the Pull-up or Pull down resistor for the current IO */
      temp = GPIOx->PUPDR;
      temp &= ~(GPIO_PUPDR_PUPD0 << (position * 2U));
      temp |= ((GPIO_Init->Pull) << (position * 2U));
      GPIOx->PUPDR = temp;
      /* In case of Alternate function mode selection */
      if ((GPIO_Init->Mode == GPIO_MODE_AF_PP) || (GPIO_Init->Mode == GPIO_MODE_AF_OD))
        /* Check the Alternate function parameters */
        assert_param(IS_GPIO_AF_INSTANCE(GPIOx));
        assert_param(IS_GPIO_AF(GPIO_Init->Alternate));
        /* Configure Alternate function mapped with the current IO */
        temp = GPIOx->AFR[position >> 3U];
        temp &= ~(0xFU << ((position & 0x07U) * 4U));
        temp |= ((GPIO_Init->Alternate) << ((position & 0x07U) * 4U));
        GPIOx->AFR[position >> 3U] = temp;
      /* Configure IO Direction mode (Input, Output, Alternate or Analog) */
      temp = GPIOx->MODER;
      temp &= ~(GPIO_MODER_MODE0 << (position * 2U));
      temp |= ((GPIO_Init->Mode & GPIO_MODE) << (position * 2U));
      GPIOx->MODER = temp;
      /*--------------------- EXTI Mode Configuration ------------------------*/
      /* Configure the External Interrupt or event for the current IO */
      if ((GPIO_Init->Mode & EXTI_MODE) == EXTI_MODE)
        /* Enable SYSCFG Clock */
        __HAL_RCC_SYSCFG_CLK_ENABLE();
        temp = SYSCFG->EXTICR[position >> 2U];
        temp &= ~(0x0FUL << (4U * (position & 0x03U)));
        temp |= (GPIO_GET_INDEX(GPIOx) << (4U * (position & 0x03U)));
        SYSCFG->EXTICR[position >> 2U] = temp;
        /* Clear EXTI line configuration */
        temp = EXTI_CurrentCPU->IMR1;
        temp &= ~(iocurrent);
        if ((GPIO_Init->Mode & GPIO_MODE_IT) == GPIO_MODE_IT)
          temp |= iocurrent;
        EXTI_CurrentCPU->IMR1 = temp;
        temp = EXTI_CurrentCPU->EMR1;
        if ((GPIO_Init->Mode & GPIO_MODE_EVT) == GPIO_MODE_EVT)
          temp |= iocurrent;
        EXTI_CurrentCPU->EMR1 = temp;
        /* Clear Rising Falling edge configuration */
        temp = EXTI->RTSR1;
        if ((GPIO_Init->Mode & RISING_EDGE) == RISING_EDGE)
          temp |= iocurrent;
        EXTI->RTSR1 = temp;
        temp = EXTI->FTSR1;
        if ((GPIO_Init->Mode & FALLING_EDGE) == FALLING_EDGE)
          temp |= iocurrent;
        EXTI->FTSR1 = temp;
    position++;
发表于 2022-11-23 09:00:26 | 显示全部楼层
用过标准库的稍微查一下相关寄存器表应该就懂了
发表于 2022-11-30 15:05:38 | 显示全部楼层
[mw_shl_code=c,true]/**
我也想问这个问题,没想到楼主捷足先登了。
GMT+8, 2025-6-10 12:49 , Processed in 0.215028 second(s), 24 queries .
