查看: 3114|回复: 26
[Embedded Studio] Embedded Studio正式开源其C/C++库源码emRun,比newlib表现出巨大性能和内存优势,并发布V7.10版本
发表于 2022-11-30 07:14:48 | 显示全部楼层 |阅读模式
https://www.segger.com/downloads/embedded-studio/
Setup_EmbeddedStudio_ARM_v710_win_x64.exe (242.34MB)
安装了最新版V7.10后,在此路径可以看到
性能比较:
资源需求比较:
发表于 2022-11-30 09:12:36 | 显示全部楼层
有点搞不懂Segger的版本号变更规则,首位版本号变更的变化比之前随便一个小版本的都少得多。
Version 7.10
Build
    Updated segger-cc compiler to version 15.0.1
    Updated segger-ld to version 4.38.0.
    Updated segger-rtl to version 4.22.0.
    The $(StudioDir)/lib directory is now writable, libraries are built from source code as required.
    The SEGGER C++ library package is now supplied as source code and built into the $(StudioDir)/lib directory as required.
    Add support for 0X hexadecimal prefix in debug expressions.
    Add "Supply Input Character Set" and "Supply Execution Character Set" project properties.
Debug
    Updated J-Link software to version V7.82c.
IDE
    Fixed prompt to install missing packages not appearing when manually installing packages and no package list has been downloaded.
Version 6.40
Build
    Updated segger-cc compiler to version 15.0.0
    Fixed External Build handling of embedded quotation marks in preprocessor defines and additional compiler options.
    Add support for Cortex-M85 processor.
    Added "Package > Package Directory" solution property.
    Updated the GCC/BINUTILS tools build to use the Arm GNU Toolchain 11.3.Rel1 source release.
    Changed "ARM Library Architecture" project property default to "Default".
    Package libraries now available for Library and Object File project types.
    Updated the LLVM/Clang tools build to use the 15.0.0 source release.
    Fixed "Generate Listing File" when using segger-cc/clang compilers.
    Fixed arm_neon.h so that it can compile with both segger-cc and clang compilers.
    Fixed usage of llvm LTO with compiler driver.
    Removed clang and segger-cc-ng binaries from distribution.
    Updated segger-ld to version 4.36.0.
    Updated segger-rtl to version 4.20.0.
Debug
    Add simulator support for primask, basepri registers.
    The Restrict Memory Access option applies to backtracing.
    Reassigned Alt+F11 to do instruction single step.
    Fixed unsigned decimal and octal display when Show Digit Separator is used.
    Fixed simulation of ARM encoded rev16/revsh instructions.
    The secure/non-secure state of Cortex-M23/Cortex-M33 devices is displayed in the status bar.
    Add option Show Struct Offsets to variable display windows.
    Add support for duplicate names in locals display.
    Add prompt for array slice in variable display windows.
    Fixed simulator clearing the execution trace on debug go.
    Execution trace window now locates to the last entry by default.
    Fixed incorrect % calculation in Execution profile window when used with J-Link.
    Updated J-Link software to version V7.82.
Editor
    Fixed Edit > Selection > Decrease Line Indent when line is below a collapsed fold.
IDE
    Added parallel download and install to package manager.
    Renamed Add Existing Project to Add Link To Existing Solution.
    Add Environment > Startup > Sort Project File On Save environment option which defaults to Yes.
    Add Import Linker Script action to project explorer context menu.
    Fixed graying of inactive code for header and assembly code files.
    Fixed preprocessor tools to use segger-cc when it is set as the compiler variant.
    Add Import CMake Generated Ninja Project to Import Project menu.
Version 6.34
Build
    Updated segger-cc compiler to version 14.2.1
    Updated segger-cc-ng compiler to version 14.92.0
    Fixed Source Navigator/Analyze command lines for libcxx projects.
    Fixed use of "Unwind Tables" with segger-cc compiler.
    Updated the LLVM/Clang tools build to use the 14.0.6 source release.
    Updated segger-ld to version 4.34.2.
    Updated segger-rtl to version 4.18.0.
Debug
    Fixed crash with watch window.
    Fixed crash with quick watch window.
    Updated J-Link software to version V7.70a.
Editor
    Fixed editor using incorrect file encoding when file is opened when a breakpoint is hit.
IDE
    Fixed license manager not allowing ARM and RISC-V licenses to be installed on one J-Link.
Version 6.32
Build
    Fixed percentage memory used calculation.
    Add "Library Heap Locking" project property.
Debug
    Add Show Digit Separator to variables and registers windows.
    Updated J-Link software to version V7.66c.
Editor
    Multi-line comments can now be folded.
    Fixed removal of editor tooltips when mouse cursor moves away.
    Added collapsed fold preview tooltip.
IDE
    Dark theme is now supported on macOS.
    Fixed crash when continue to debug used with no executable file.
    ANSI escape codes are now removed when copying text to the clipboard from the text build log.
    Add existing file now uses the standard native file open dialog on Windows.
 楼主| 发表于 2022-11-30 10:12:13 | 显示全部楼层
Version 7. ...
这个版本更新规格就跟FreeRTOS差别不多,6.X, 7.X, 8,X, 9,X, 10,X
小更小号,大更大号
发表于 2022-11-30 10:28:44 | 显示全部楼层
不到250M的大小了,之前可是快800M的
 楼主| 发表于 2022-11-30 11:26:28 | 显示全部楼层
是的,这次升级,他们专门解决了下软件包问题,工具链之类也是单独安装了
More we do, more we can do.
发表于 2022-11-30 12:56:04 | 显示全部楼层
官网可完全没有提到“开源”,只是安装后有源代码,还是商业软件。
emRun can be licensed in source code to individual companies as well as be included as libraries by providers of toolchains.
发表于 2022-11-30 14:08:29 | 显示全部楼层
国产MCU不给它配支持包,再好的工具也没用,每次从MDK导出项目?何苦?
 楼主| 发表于 2022-11-30 14:59:21 | 显示全部楼层
配了,当前有GD,灵动微,极海,上海先楫等
https://studio.segger.com/packages/
 楼主| 发表于 2022-11-30 15:00:52 | 显示全部楼层
一直是商业的,只是个人,教育等免费使用全功能版。
还有一个区别,这个开源出来的没有注释,他们把注释给删掉了。
发表于 2022-11-30 15:10:11 | 显示全部楼层
开源不等于免费,就像ThreadX那样。
发表于 2022-11-30 15:39:21 | 显示全部楼层
主要是完美配合JLINK,解决MDK莫名崩溃的问题
发表于 2022-12-1 12:28:04 | 显示全部楼层
没有注释看代码。。。。要命了 亲
发表于 2022-12-1 12:29:53 | 显示全部楼层
如何才能得到有“注释” 的源码呢?   现在再去看这种源码 再优化没精力 , 没时间, 也没必要了。  国内的工资是负担不起这样的人才的。
 楼主| 发表于 2022-12-1 13:57:37 | 显示全部楼层
roguebear 发表于 2022-12-1 12:29
如何才能得到有“注释” 的源码呢?   现在再去看这种源码 再优化没精力 , 没时间, 也没必要了。  国内的 ...
比注释更狠的是,很多优化都是汇编实现的。
发表于 2022-12-1 19:34:18 | 显示全部楼层
那这个开源没有太大意义了。 开发成本和时间才高。 芯片嘛隔一年就有更强的出来了。不差那点优化。真到那个地步,估计好多人一辈子都碰不到。
 楼主| 发表于 2022-12-2 09:21:50 | 显示全部楼层
roguebear 发表于 2022-12-1 19:34
那这个开源没有太大意义了。 开发成本和时间才高。 芯片嘛隔一年就有更强的出来了。不差那点优化。真到那个 ...
有些人喜欢研究这个。
固件開發工程師
发表于 2022-12-2 09:38:54 | 显示全部楼层
希望Segger能放出和商用软件Keil/IAR的性能对比,不能跟一个免费的gcc/newlib较劲啊。
 楼主| 发表于 2022-12-2 10:11:18 | 显示全部楼层
我比较过。
【性能测评】DSP库,MDK5的AC5,AC6,IAR和Embedded Studio的三角函数性能(2022-06-04更新)
https://www.armbbs.cn/forum.php?mod=viewthread&tid=95455
【测试帖】比较IAR,MDK的AC5和AC6以及Embedded Studio的CLANG和GCC编译HAL库性能(2019-04-06更新)
https://www.armbbs.cn/forum.php?mod=viewthread&tid=93102
发表于 2022-12-2 12:45:18 | 显示全部楼层
我看了下介绍,说是购买了ES7.10商业license,源码就带有注释的.
所以想学的多,还得花钱买!
发表于 2022-12-7 04:42:54 | 显示全部楼层
这个能不能上传个压缩包
 楼主| 发表于 2022-12-7 04:59:53 | 显示全部楼层
在水一方 发表于 2022-12-7 04:42
这个能不能上传个压缩包
可以的,白天了我弄下
发表于 2022-12-7 10:16:18 | 显示全部楼层
是的,不等于。请问你哪里看到它写了开源?
发表于 2022-12-7 10:20:27 | 显示全部楼层
最近刚好遇到了,切换到GCC后,算力性能一直偏低。不过它这是商业软件,不能用。
发表于 2022-12-7 11:58:12 | 显示全部楼层
GCC的通用性和适配性强
发表于 2022-12-7 14:09:34 | 显示全部楼层
你说得对。emRun不是开源,只是提供了源码。
发表于 2022-12-8 08:35:01 | 显示全部楼层
学习和gcc对比下,看看不同之处,借鉴一下挺好
 楼主| 发表于 2022-12-20 15:08:06 | 显示全部楼层
升级至7.10a
GMT+8, 2025-4-29 13:58 , Processed in 0.396263 second(s), 28 queries .
