查看: 1051|回复: 0
[Lua] LUA大量使用局部变量或者全局变量,速度区别并不大
发表于 2022-12-23 00:43:10 | 显示全部楼层 |阅读模式
H7-TOOL的RTOS Trace要大量用到局部变量或者全局变量,所以想在这个地方优化下,发现全部采用局部变量或者全局变量,区别并不大
之前整理的帖子:
LUA编程中,为什么局部变量访问比全局变量更快
https://www.armbbs.cn/forum.php?mod=viewthread&tid=116745
后面有精力了再研究这个问题。
[Lua] 纯文本查看 复制代码
--定时刷新
function OS_Refresh(quick)
	local ok
	local pcb
	local str
	local deltaTolTime
	local deltaIdleTime
	local time1, time2
	local TaskTotalTime1
	local IsrTotalTime1
	local IdleTime1
	local TaskPrio
	local StackSize
	local StackStart
	local StackEnd
	local StackHighest
	local NameAddr
	local StackPtr
	local TaskState
	local TaskRunCout
	local TaskExeTime
	local OSSem
	local OSDbg_SemID
	local OSDbg_SemNamePtr
	local OSDbg_SemCtr
	local OSDbg_SemNbrEntries
	local OSDbg_SemPendListHeadPtr
	local NameAddr
	local str1
	local OSFlag
	local OSDbg_FlagNbrEntries
	local OSDbg_FlagID
	local OSDbg_FlagResetSearch
	local OSDbg_FlagDelayClear
	local OSDbg_FlagNamePtr
	local OSDbg_FlagFlags
	local OSDbg_FlagPendListHeadPtr
	local OSQ
	local OSDbg_QId
	local OSDbg_QMsgSize
	local OSDbg_QCapacity
	local OSDbg_QEnqueued
	local OSDbg_QAvailabeStorage
	local OSDbg_QStart
	local OSDbg_QEnd
	local OSDbg_QNamePtr
	local OSDbg_QNbrEntries
	local OSDbg_QPendListHeadPtr
	local OSMutex
	local OSDbg_MutexId
	local OSDbg_MutexOwnershipcount
	local OSDbg_MutexInherit
	local OSDbg_MutexOriginalPriority
	local OSDbg_MutexHighestPriorityWaiting
	local OSDbg_MutexNamePtr
	local OSDbg_MutexOwerTCPPtr
	local str2
	local OSDbg_MutexNbrEntries
	local OSDbg_MutexPendListHeadPtr
GMT+8, 2025-6-6 23:21 , Processed in 0.235221 second(s), 24 queries .
