查看: 1676|回复: 11
[RTOS Trace] H7-TOOL的FreeRTOS Trace功能,仅差一个关键变量的检索差不多就完成了
发表于 2023-1-11 00:59:38 | 显示全部楼层 |阅读模式
由于FreeRTOS所有对象创建基本都是动态内存管理方式(当然新版很多也支持静态方式),所以检索起来比较麻烦。
特别是这个条件编译比较多的TCB任务控制块结构体定义,其中有一个统计任务执行时间的成员,这个最不容易获取,因为前面有好几个宏定义控制。
如果是程序主动输出,那就简单很多。但我们这里需要被动检索,这就麻烦很多了
 * Task control block.  A task control block (TCB) is allocated for each task,
 * and stores task state information, including a pointer to the task's context
 * (the task's run time environment, including register values)
typedef struct tskTaskControlBlock                         /* The old naming convention is used to prevent breaking kernel aware debuggers. */
        volatile StackType_t        *pxTopOfStack;        /*< Points to the location of the last item placed on the tasks stack.  THIS MUST BE THE FIRST MEMBER OF THE TCB STRUCT. */
        #if ( portUSING_MPU_WRAPPERS == 1 )
                xMPU_SETTINGS        xMPUSettings;                /*< The MPU settings are defined as part of the port layer.  THIS MUST BE THE SECOND MEMBER OF THE TCB STRUCT. */
        ListItem_t                        xStateListItem;        /*< The list that the state list item of a task is reference from denotes the state of that task (Ready, Blocked, Suspended ). */
        ListItem_t                        xEventListItem;                /*< Used to reference a task from an event list. */
        UBaseType_t                        uxPriority;                        /*< The priority of the task.  0 is the lowest priority. */
        StackType_t                        *pxStack;                        /*< Points to the start of the stack. */
        char                                pcTaskName[ configMAX_TASK_NAME_LEN ];/*< Descriptive name given to the task when created.  Facilitates debugging only. */ /*lint !e971 Unqualified char types are allowed for strings and single characters only. */
        #if ( ( portSTACK_GROWTH > 0 ) || ( configRECORD_STACK_HIGH_ADDRESS == 1 ) )
                StackType_t                *pxEndOfStack;                /*< Points to the highest valid address for the stack. */
        #if ( portCRITICAL_NESTING_IN_TCB == 1 )
                UBaseType_t                uxCriticalNesting;        /*< Holds the critical section nesting depth for ports that do not maintain their own count in the port layer. */
        #if ( configUSE_TRACE_FACILITY == 1 )
                UBaseType_t                uxTCBNumber;                /*< Stores a number that increments each time a TCB is created.  It allows debuggers to determine when a task has been deleted and then recreated. */
                UBaseType_t                uxTaskNumber;                /*< Stores a number specifically for use by third party trace code. */
        #if ( configUSE_MUTEXES == 1 )
                UBaseType_t                uxBasePriority;                /*< The priority last assigned to the task - used by the priority inheritance mechanism. */
                UBaseType_t                uxMutexesHeld;
        #if ( configUSE_APPLICATION_TASK_TAG == 1 )
                TaskHookFunction_t pxTaskTag;
        #if( configNUM_THREAD_LOCAL_STORAGE_POINTERS > 0 )
                void                        *pvThreadLocalStoragePointers[ configNUM_THREAD_LOCAL_STORAGE_POINTERS ];
        #if( configGENERATE_RUN_TIME_STATS == 1 )
                uint32_t                ulRunTimeCounter;        /*< Stores the amount of time the task has spent in the Running state. */
        #if ( configUSE_NEWLIB_REENTRANT == 1 )
                /* Allocate a Newlib reent structure that is specific to this task.
                Note Newlib support has been included by popular demand, but is not
                used by the FreeRTOS maintainers themselves.  FreeRTOS is not
                responsible for resulting newlib operation.  User must be familiar with
                newlib and must provide system-wide implementations of the necessary
                stubs. Be warned that (at the time of writing) the current newlib design
                implements a system-wide malloc() that must be provided with locks. */
                struct        _reent xNewLib_reent;
        #if( configUSE_TASK_NOTIFICATIONS == 1 )
                volatile uint32_t ulNotifiedValue;
                volatile uint8_t ucNotifyState;
        /* See the comments in FreeRTOS.h with the definition of
        tskSTATIC_AND_DYNAMIC_ALLOCATION_POSSIBLE. */
        #if( tskSTATIC_AND_DYNAMIC_ALLOCATION_POSSIBLE != 0 ) /*lint !e731 !e9029 Macro has been consolidated for readability reasons. */
                uint8_t        ucStaticallyAllocated;                 /*< Set to pdTRUE if the task is a statically allocated to ensure no attempt is made to free the memory. */
        #if( INCLUDE_xTaskAbortDelay == 1 )
                uint8_t ucDelayAborted;
        #if( configUSE_POSIX_ERRNO == 1 )
                int iTaskErrno;
} tskTCB;
 楼主| 发表于 2023-1-11 01:08:53 | 显示全部楼层
发表于 2023-1-11 08:13:48 | 显示全部楼层
能不能通过map文件找到
 楼主| 发表于 2023-1-11 09:16:15 | 显示全部楼层
tovinz 发表于 2023-1-11 08:13
能不能通过map文件找到
由于是动态内存管理,他们没有TCB方式定义的变量,全是动态内存申请的,所以搜不到。
H7 TOOL 大法好!
发表于 2023-1-11 10:04:23 | 显示全部楼层
有一说一 , 个人觉得 ucos的代码风格比Freertos要好很多 , 而且源码易懂 , 文件名命名也比较好
 楼主| 发表于 2023-1-11 10:07:26 | 显示全部楼层
是的,FreeRTOS的源码不适合阅读,可读性略差。
发表于 2023-1-11 15:17:35 | 显示全部楼层
这个得检索宏定义有效性来识别了
代码不规范,亲人两行泪!
 楼主| 发表于 2023-1-12 01:28:01 | 显示全部楼层
missfox 发表于 2023-1-11 15:17
这个得检索宏定义有效性来识别了
这个思路,AC6需要用户添加一个参数才行。得再考虑下
H7-TOOL的RTOS Trace操作MDK AC5和MDK AC6的宏定义异同
https://www.armbbs.cn/forum.php? ... d=117118&fromuid=58
 楼主| 发表于 2023-1-16 10:37:09 | 显示全部楼层
实践证明通过各种方案检索这个变量,很难锁定偏移。得换个思路试试了。
发表于 2023-1-16 10:57:12 | 显示全部楼层
能不能定位到动态创建函数,比如在动态分配的时候会返回分配的内存地址, 再去读那个内存地址的内容
 楼主| 发表于 2023-1-16 11:41:43 | 显示全部楼层
有个函数,不过得需要用户同时开启使用空闲任务的句柄宏定义才行
#if( ( configGENERATE_RUN_TIME_STATS == 1 ) && ( INCLUDE_xTaskGetIdleTaskHandle == 1 ) )
	TickType_t xTaskGetIdleRunTimeCounter( void )
		return xIdleTaskHandle->ulRunTimeCounter;
 楼主| 发表于 2023-1-17 00:37:34 | 显示全部楼层
已经找到解决办法,就是检索略微满分
GMT+8, 2025-6-3 07:29 , Processed in 0.500141 second(s), 27 queries .
