查看: 1875|回复: 7
[STM32H7] 串口不定长收发,初始化会打印串口缓冲区长度的0
发表于 2023-3-13 16:06:13 | 显示全部楼层 |阅读模式
#include "bsp.h"
UART_HandleTypeDef huart1;
DMA_HandleTypeDef hdma_usart1_rx;
DMA_HandleTypeDef hdma_usart1_tx;
ALIGN_32BYTES(__attribute__((section (".RAM_D2"))) uint8_t RxBuff[512]);
__IO uint8_t RxNum = 0;
__IO uint8_t g_UartIsOK = 0;
//定义_sys_exit()以避免使用半主机模式
void _sys_exit(int x)
        x = x;
//重定义fputc函数
int fputc(int ch, FILE *f)
        while((USART1->ISR&0x40)==0);//循环发送,直到发送完毕
        USART1->TDR=(uint8_t)ch;
        return ch;
/* USART1 init function */
void bsp_InitUart(void)
  huart1.Instance                    = USART1;
  huart1.Init.BaudRate               = 115200;
  huart1.Init.WordLength             = UART_WORDLENGTH_8B;
  huart1.Init.StopBits               = UART_STOPBITS_1;
  huart1.Init.Parity                 = UART_PARITY_NONE;
  huart1.Init.Mode                   = UART_MODE_TX_RX;
  huart1.Init.HwFlowCtl              = UART_HWCONTROL_NONE;
  huart1.Init.OverSampling           = UART_OVERSAMPLING_16;
  huart1.Init.OneBitSampling         = UART_ONE_BIT_SAMPLE_DISABLE;
  huart1.Init.ClockPrescaler         = UART_PRESCALER_DIV1;
  huart1.AdvancedInit.AdvFeatureInit = UART_ADVFEATURE_NO_INIT;
  if (HAL_UART_Init(&huart1) != HAL_OK)
  if (HAL_UARTEx_SetTxFifoThreshold(&huart1, UART_TXFIFO_THRESHOLD_1_8) != HAL_OK)
  if (HAL_UARTEx_SetRxFifoThreshold(&huart1, UART_RXFIFO_THRESHOLD_1_8) != HAL_OK)
  if (HAL_UARTEx_DisableFifoMode(&huart1) != HAL_OK)
  __HAL_UART_ENABLE_IT(&huart1,UART_IT_IDLE);
void HAL_UART_MspInit(UART_HandleTypeDef* uartHandle)
  RCC_PeriphCLKInitTypeDef PeriphClkInitStruct = {0};
  if(uartHandle->Instance==USART1)
    PeriphClkInitStruct.PeriphClockSelection = RCC_PERIPHCLK_USART1;
    PeriphClkInitStruct.Usart16ClockSelection = RCC_USART16CLKSOURCE_D2PCLK2;
    if (HAL_RCCEx_PeriphCLKConfig(&PeriphClkInitStruct) != HAL_OK)
    /* USART1 clock enable */
    __HAL_RCC_USART1_CLK_ENABLE();
    __HAL_RCC_GPIOA_CLK_ENABLE();
    GPIO_InitStruct.Pin = GPIO_PIN_10|GPIO_PIN_9;
    GPIO_InitStruct.Pull = GPIO_PULLUP;
    GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_VERY_HIGH;
    GPIO_InitStruct.Alternate = GPIO_AF7_USART1;
    HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
    /* USART1 DMA Init */
    __HAL_RCC_DMA1_CLK_ENABLE();
    /* USART1_RX Init */
    hdma_usart1_rx.Instance = DMA1_Stream0;
    hdma_usart1_rx.Init.Request = DMA_REQUEST_USART1_RX;
    hdma_usart1_rx.Init.Direction = DMA_PERIPH_TO_MEMORY;
    hdma_usart1_rx.Init.PeriphInc = DMA_PINC_DISABLE;
    hdma_usart1_rx.Init.MemInc = DMA_MINC_ENABLE;
    hdma_usart1_rx.Init.PeriphDataAlignment = DMA_PDATAALIGN_BYTE;
    hdma_usart1_rx.Init.MemDataAlignment = DMA_MDATAALIGN_BYTE;
    hdma_usart1_rx.Init.Mode = DMA_CIRCULAR;
    hdma_usart1_rx.Init.Priority = DMA_PRIORITY_LOW;
    hdma_usart1_rx.Init.FIFOMode = DMA_FIFOMODE_DISABLE;
    if (HAL_DMA_Init(&hdma_usart1_rx) != HAL_OK)
    __HAL_LINKDMA(uartHandle,hdmarx,hdma_usart1_rx);
    /* USART1_TX Init */
    hdma_usart1_tx.Instance = DMA1_Stream1;
    hdma_usart1_tx.Init.Request = DMA_REQUEST_USART1_TX;
    hdma_usart1_tx.Init.Direction = DMA_MEMORY_TO_PERIPH;
    hdma_usart1_tx.Init.PeriphInc = DMA_PINC_DISABLE;
    hdma_usart1_tx.Init.MemInc = DMA_MINC_ENABLE;
    hdma_usart1_tx.Init.PeriphDataAlignment = DMA_PDATAALIGN_BYTE;
    hdma_usart1_tx.Init.MemDataAlignment = DMA_MDATAALIGN_BYTE;
    hdma_usart1_tx.Init.Mode = DMA_NORMAL;
    hdma_usart1_tx.Init.Priority = DMA_PRIORITY_LOW;
    hdma_usart1_tx.Init.FIFOMode = DMA_FIFOMODE_DISABLE;
    if (HAL_DMA_Init(&hdma_usart1_tx) != HAL_OK)
    __HAL_LINKDMA(uartHandle,hdmatx,hdma_usart1_tx);
    /* DMA1_Stream0_IRQn interrupt configuration */
    HAL_NVIC_SetPriority(DMA1_Stream0_IRQn, 1, 0);
    HAL_NVIC_EnableIRQ(DMA1_Stream0_IRQn);
    /* DMA1_Stream1_IRQn interrupt configuration */
    HAL_NVIC_SetPriority(DMA1_Stream1_IRQn, 1, 0);
    HAL_NVIC_EnableIRQ(DMA1_Stream1_IRQn);
    /* USART1 interrupt Init */
    HAL_NVIC_SetPriority(USART1_IRQn, 1, 0);
    HAL_NVIC_EnableIRQ(USART1_IRQn);
void HAL_UART_MspDeInit(UART_HandleTypeDef* uartHandle)
    __HAL_RCC_USART1_CLK_DISABLE();
    HAL_GPIO_DeInit(GPIOA, GPIO_PIN_10|GPIO_PIN_9);
    HAL_DMA_DeInit(uartHandle->hdmarx);
    HAL_DMA_DeInit(uartHandle->hdmatx);
    HAL_NVIC_DisableIRQ(USART1_IRQn);
void DMA1_Stream0_IRQHandler(void)
  HAL_DMA_IRQHandler(&hdma_usart1_rx);
void DMA1_Stream1_IRQHandler(void)
  HAL_DMA_IRQHandler(&hdma_usart1_tx);
void USART1_IRQHandler(void)
  if(__HAL_UART_GET_FLAG(&huart1,UART_FLAG_IDLE)==SET)
    __HAL_UART_CLEAR_IDLEFLAG(&huart1);
    HAL_UART_DMAStop(&huart1);
    RxNum = 512 - __HAL_DMA_GET_COUNTER(&hdma_usart1_rx);
    CmdPickUp(RxBuff,RxNum);  //用户程序
    memset(RxBuff,0,512);
    HAL_UART_Receive_DMA(&huart1,RxBuff,512);
  HAL_UART_IRQHandler(&huart1);
/* USER CODE BEGIN 1 */
void HAL_UART_TxCpltCallback(UART_HandleTypeDef *huart)
  if(huart->Instance==USART1)
/***************************** 安富莱电子 [url=http://www.armfly.com]www.armfly.com[/url] (END OF FILE) *********************************/
安富莱DemoNew-20230228.zip
26.53 MB, 下载次数: 3
发表于 2023-3-13 16:33:45 | 显示全部楼层
楼主的问题描述是不是忘了写了。
 楼主| 发表于 2023-3-14 08:23:50 | 显示全部楼层
eric2013 发表于 2023-3-13 16:33
楼主的问题描述是不是忘了写了。
不好意思啊,以为附件上传成功了。我的问题是移植了串口不定长收发后,初始化的时候会打印串口缓冲区长度的0.找不到问题
 楼主| 发表于 2023-3-14 08:24:48 | 显示全部楼层
工程附上,用的是安富莱V7评估的
26.53 MB, 下载次数: 1
发表于 2023-3-14 12:06:23 | 显示全部楼层
YYY13941 发表于 2023-3-14 08:24
工程附上,用的是安富莱V7评估的
这个是坛友分享的基于V7板子的,可以使用,你测试对比下
STM32H7基于STM32CubeMX的串口DMA+空闲中断接收不定长数据实现(HAL库1.9.0自带函数实现)
https://www.armbbs.cn/forum.php? ... 8553&fromuid=58
发表于 2023-3-14 18:50:37 | 显示全部楼层
工程附上,用的是安富莱V7评估的
你是开了cache和MPU的,我的代码是关闭了的,今天回去打算研究下MPU,之前实现成功了,忘了代码在哪里了
发表于 2023-3-14 21:52:49 | 显示全部楼层
研究了下MPU和DCache的代码已经实现了,还有些疑问验证下
发表于 2023-3-15 00:34:01 | 显示全部楼层
这个没关系,他是这种定义方式,直接让他关闭即可。
GMT+8, 2025-7-8 20:34 , Processed in 0.369309 second(s), 27 queries .
