查看: 1442|回复: 12
[有问必答] AD7606采集数据要么全是0要么全是-1
发表于 2023-3-16 21:10:32 | 显示全部楼层 |阅读模式
这是我的硬件接线原理图,软件怎么调试采集数据都是全0或者全-1,我移植的站长发布的例程。
 楼主| 发表于 2023-3-16 21:16:02 | 显示全部楼层
希望大家帮我看看我的硬件接线有没有问题,如果没有问题的话我再查找一下软件得问题(新手小白一枚,做本科毕业设计),谢谢大家!
发表于 2023-3-17 12:06:53 | 显示全部楼层
cxrose 发表于 2023-3-16 21:16
希望大家帮我看看我的硬件接线有没有问题,如果没有问题的话我再查找一下软件得问题(新手小白一枚,做本科 ...
务必保证AD7606的5V供电没问题,然后发你的程序代码我看下
 楼主| 发表于 2023-3-17 13:02:47 | 显示全部楼层
5V供电应该是没问题,我测过了,代码如下:
void bsp_TIM4_Configuration(void);
void bsp_spiDelay(void)
        uint32_t i;
        for (i = 0; i < 2; i++);
*        函 数 名: bsp_InitAD7606
*        功能说明: 初始化AD7606 SPI口线
*        形    参:无
*        返 回 值: 无
void bsp_InitAD7606(void)
        GPIO_InitTypeDef  GPIO_InitStructure;
        SPI_InitTypeDef   SPI_InitStructure;
        /* AD_SPI_CS_GPIO, AD_SPI_MOSI_GPIO, AD_SPI_MISO_GPIO, AD_SPI_DETECT_GPIO
           and AD_SPI_SCK_GPIO Periph clock enable */
        RCC_APB2PeriphClockCmd(AD_CS_GPIO_CLK | AD_SPI_MISO_GPIO_CLK | AD_SPI_SCK_GPIO_CLK
                        , ENABLE);
        /* AD_SPI Periph clock enable */
        RCC_APB1PeriphClockCmd(AD_SPI_CLK, ENABLE);
        /* Configure AD_SPI pins: SCK */
        GPIO_InitStructure.GPIO_Pin = AD_SPI_SCK_PIN;
        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
        GPIO_Init(AD_SPI_SCK_GPIO_PORT, &GPIO_InitStructure);
        /* Configure AD_SPI pins: MISO */
        GPIO_InitStructure.GPIO_Pin = AD_SPI_MISO_PIN;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
        GPIO_Init(AD_SPI_MISO_GPIO_PORT, &GPIO_InitStructure);
        GPIO_InitStructure.GPIO_Pin = AD_CS_PIN;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
        GPIO_Init(AD_CS_GPIO_PORT, &GPIO_InitStructure);
        /* AD_SPI Config */
        SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
        //SPI_InitStructure.SPI_Direction = SPI_Direction_1Line_Rx;
        SPI_InitStructure.SPI_Mode = SPI_Mode_Master;
        SPI_InitStructure.SPI_DataSize = SPI_DataSize_16b;
        SPI_InitStructure.SPI_CPOL = SPI_CPOL_High;
        SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge;
        SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;
        SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_8;
        SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
        SPI_InitStructure.SPI_CRCPolynomial = 7;
        SPI_Init(AD_SPI, &SPI_InitStructure);
        SPI_Cmd(AD_SPI, ENABLE); /* AD_SPI enable */
        /* 配置其它的GPIO */
        /* 使能GPIO时钟 */
        RCC_APB2PeriphClockCmd(AD_RESET_GPIO_CLK | AD_CONVST_GPIO_CLK | AD_OS0_GPIO_CLK
                | AD_OS1_GPIO_CLK | AD_OS2_GPIO_CLK, ENABLE);
        /* 配置RESET GPIO */
        GPIO_InitStructure.GPIO_Pin = AD_RESET_PIN;
        GPIO_Init(AD_RESET_GPIO_PORT, &GPIO_InitStructure);
        /* 配置CONVST GPIO */
        GPIO_InitStructure.GPIO_Pin = AD_CONVST_PIN;
        GPIO_Init(AD_CONVST_GPIO_PORT, &GPIO_InitStructure);
        /* 配置OS0-2 GPIO */
        GPIO_InitStructure.GPIO_Pin = AD_OS0_PIN;
        GPIO_Init(AD_OS0_GPIO_PORT, &GPIO_InitStructure);
        GPIO_InitStructure.GPIO_Pin = AD_OS1_PIN;
        GPIO_Init(AD_OS1_GPIO_PORT, &GPIO_InitStructure);
        GPIO_InitStructure.GPIO_Pin = AD_OS2_PIN;
        GPIO_Init(AD_OS2_GPIO_PORT, &GPIO_InitStructure);
        AD_STBY_GPIO_PORT->BSRR = AD_STBY_PIN;
        /* 设置过采样模式 */
        ad7606_SetOS(0);
        /* 设置GPIO的初始状态 */
        ad7606_Reset();                                /* 硬件复位复AD7606 */
        AD_CONVST_HIGH();                        /* CONVST脚设置为高电平 */
        bsp_TIM4_Configuration();        /* 配置TIM4定时中断 */
*        函 数 名: ad7606_Reset
*        功能说明: 硬件复位AD7606
*        形    参:无
*        返 回 值: 无
void ad7606_Reset(void)
        /* AD7606是高电平复位,要求最小脉宽50ns */
        AD_CS_LOW();
        AD_RESET_LOW();
        AD_RESET_HIGH();
        AD_RESET_HIGH();
        AD_RESET_HIGH();
        AD_RESET_HIGH();
        AD_RESET_LOW();
*        函 数 名: ad7606_SetOS
*        功能说明: 设置过采样模式(数字滤波,硬件求平均值)
*        形    参:_ucMode : 0-6  0表示无过采样,1表示2倍,2表示4倍,3表示8倍,4表示16倍
*                                5表示32倍,6表示64倍
*        返 回 值: 无
void ad7606_SetOS(uint8_t _ucMode)
        if (_ucMode == 1)
                AD_OS2_0();
                AD_OS1_0();
                AD_OS0_1();
        else if (_ucMode == 2)
                AD_OS2_0();
                AD_OS1_1();
                AD_OS0_0();
        else if (_ucMode == 3)
                AD_OS2_0();
                AD_OS1_1();
                AD_OS0_1();
        else if (_ucMode == 4)
                AD_OS2_1();
                AD_OS1_0();
                AD_OS0_0();
        else if (_ucMode == 5)
                AD_OS2_1();
                AD_OS1_0();
                AD_OS0_1();
        else if (_ucMode == 6)
                AD_OS2_1();
                AD_OS1_1();
                AD_OS0_0();
        else        /* 按0处理 */
                AD_OS2_0();
                AD_OS1_0();
                AD_OS0_0();
*        函 数 名: ad7606_StartConv
*        功能说明: 启动AD7606的ADC转换
*        形    参:无
*        返 回 值: 无
void ad7606_StartConv(void)
        /* 上升沿开始转换,低电平持续时间至少25ns  */
        AD_CONVST_LOW();
        AD_CONVST_LOW();
        AD_CONVST_LOW();        /* 连续执行2次,低电平约50ns */
        AD_CONVST_HIGH();
*        函 数 名: bsp_TIM4_Configuration
*        功能说明: 配置TIM4定时器
*        形    参:无
*        返 回 值: 无
        NVIC_InitTypeDef NVIC_InitStructure;
        /* TIM2 clock enable */
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM4, ENABLE);
        /* Configure the NVIC Preemption Priority Bits[配置优先级组] */
        NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);
        /* Enable the TIM4 gloabal Interrupt [允许TIM4全局中断]*/
        NVIC_InitStructure.NVIC_IRQChannel = TIM4_IRQn;
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
        NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
        NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
        NVIC_Init(&NVIC_InitStructure);
*        函 数 名: bsp_SET_TIM4_FREQ
*        功能说明: 设置TIM4定时器频率
*        形    参:_ulFreq : 采样频率,单位Hz,
*        返 回 值: 无
void bsp_SET_TIM4_FREQ(uint32_t _ulFreq)
        TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
        uint16_t usPrescaler;
        uint16_t usPeriod;
        TIM_DeInit(TIM4);        /* 复位TIM4定时器 */
        /* TIM4 configuration
                TIM4CLK = 36 MHz
        if (_ulFreq == 0)
                return;                /* 采样频率为0,停止采样 */
        else if (_ulFreq <= 100)   /* 采样频率小于100Hz */
                usPrescaler = 36000;                /* TM4CLK = 72 000 000/36000 = 2000 */
                usPeriod = 2000 / _ulFreq;
        else if (_ulFreq <= 200000)        /* 采样频率 :100Hz - 200kHz */
                usPrescaler = 36 - 1;                /* TM4CLK = 36 000 000/36 = 2 000 000 */
                usPeriod = 2000000 / _ulFreq;
        else        /* 采样频率大于 200kHz */
                return;
        TIM_TimeBaseStructure.TIM_Period = usPeriod - 1;                 /* 计数周期 */
        TIM_TimeBaseStructure.TIM_Prescaler = usPrescaler;        /* 分频系数 */
        TIM_TimeBaseStructure.TIM_ClockDivision = 0x0;                 /* */
        TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;  //计数方向向上计数
        TIM_TimeBaseInit(TIM4, &TIM_TimeBaseStructure);
        /* Clear TIM4 update pending flag[清除TIM4溢出中断标志] */
        TIM_ClearFlag(TIM4, TIM_FLAG_Update);
        TIM_SetCounter(TIM4, 0);
        /* Enable TIM2 Update interrupt [TIM4溢出中断允许]*/
        TIM_ITConfig(TIM4, TIM_IT_Update, ENABLE);
        /* TIM2 enable counter [允许TIM4计数]*/
        TIM_Cmd(TIM4, ENABLE);
*        函 数 名: ad7606_ReadBytes
*        功能说明: 读取AD7606的采样结果
*        形    参:
*        返 回 值: 无
uint16_t ad7606_ReadBytes(void)
  uint16_t usData = 0;
  /* Wait until the transmit buffer is empty */
  while (SPI_I2S_GetFlagStatus(AD_SPI, SPI_I2S_FLAG_TXE) == RESET)
  /* Send the byte */
  SPI_I2S_SendData(AD_SPI, 0xFFFF);
  /* Wait until a data is received */
  while (SPI_I2S_GetFlagStatus(AD_SPI, SPI_I2S_FLAG_RXNE) == RESET)
  /* Get the received data */
  usData = SPI_I2S_ReceiveData(AD_SPI);
  /* Return the shifted data */
  return usData;
*        函 数 名: bsp_spiRead1
*        功能说明: 从SPI总线接收8个bit数据。  SCK上升沿采集数据, SCK空闲时为高电平
*        形    参: 无
*        返 回 值: 无
#define SOFT_SPI                /* 定义此行表示使用GPIO模拟SPI接口 */
uint8_t bsp_spiRead1(void)
#ifdef SOFT_SPI                /* 软件SPI */
        uint8_t i;
        uint8_t read = 0;
        for (i = 0; i < 8; i++)
                SCK_0();
                bsp_spiDelay();
                read = read << 1;
                if (MISO_IS_HIGH())
                        read++;
                SCK_1();
                bsp_spiDelay();
        return read;
*        函 数 名: AD7606_scan
*        功能说明: 扫描调用本函数,用于读取AD转换器数据
*        形    参:无
*        返 回 值: 无
void AD7606_Scan(void)
        uint8_t i;
        /* BUSY = 0 时.ad7606处于空闲状态ad转换结束 */
        if (BUSY_IS_LOW())
                AD_CS_LOW(); /* SPI片选 = 0 */
                for (i = 0; i < CH_NUM; i++)
                        s_adc_now = bsp_spiRead1();
                        s_adc_now = s_adc_now * 256 + bsp_spiRead1(); /* 读数据 */
                AD_CS_HIGH(); /* SPI片选 = 1 */
                ad7606_StartConv();        /* 给开始信号 */
*        函 数 名: ad7606_StartRecord
*        功能说明: 开始采集
*        形    参:_ulFreq : 采样频率, 单位 HZ
*        返 回 值: 无
void ad7606_StartRecord(uint32_t _ulFreq)
        //ad7606_Reset();        /* 复位硬件 */
        ad7606_StartConv();                                /* 启动采样,避免第1组数据全0的问题 */
        g_tAD.usRead = 0;                                /* 必须在开启TIM4之前清0 */
        g_tAD.usWrite = 0;
        bsp_SET_TIM4_FREQ(_ulFreq);                /* 设置采样频率, 并使能TIM4定时采样中断 */
*        函 数 名: ad7606_StopRecord
*        功能说明: 停止采集
*        形    参:无
*        返 回 值: 无
void ad7606_StopRecord(void)
        /* TIM4 disable counter [不允许tim4计数]*/
        TIM_Cmd(TIM4, DISABLE);
*        函 数 名: GetAdcFormFifo
*        功能说明: 从FIFO中读取一个ADC值
*        形    参:_usReadAdc : 存放ADC结果的变量指针
*        返 回 值: 1 表示OK,0表示暂无数据
int16_t AD7606_ReadAdc(uint8_t _ch)
        int16_t sAdc;
        DISABLE_INT();
        sAdc = s_adc_now[_ch];
        ENABLE_INT();
        return sAdc;
*        函 数 名: AD7606_Mak
*        功能说明: 处理采样后的数据
*        形    参:无
*        返 回 值: 无
void AD7606_Mak(void)
        uint8_t i;
        int16_t adc;
        for (i = 0;i < CH_NUM; i++)
                s_dat = AD7606_ReadAdc(i);
                32767 = 5V , 这是理论值,实际可以根据5V基准的实际值进行公式矫正
                volt = ((int16_t)dat * 5000) / 32767;        计算实际电压值(近似估算的),如需准确,请进行校准
                volt = dat * 0.3051850947599719
                adc = s_dat;
                s_resistor = 100*(adc*10*0.000152-1);
void TIM4_IRQHandler(void)
        AD7606_Scan();
        AD7606_Mak();
        TIM_ClearITPendingBit(TIM4,TIM_IT_Update);
 楼主| 发表于 2023-3-18 11:29:43 | 显示全部楼层
另外,我测试的时候发现AD7606芯片很烫手,正常吗?
 楼主| 发表于 2023-3-18 15:12:19 | 显示全部楼层
您好,我已将代码粘贴在评论区,您有时间帮看一下,谢谢!
发表于 2023-3-18 20:27:14 | 显示全部楼层
发烫说明芯片已经坏掉
More we do, more we can do.
发表于 2023-3-18 22:22:47 | 显示全部楼层
发表于 2023-3-19 10:58:49 | 显示全部楼层
不正常,烫手有损坏的问题。
发表于 2023-3-19 11:01:57 | 显示全部楼层
void bsp_spiDelay(vo ...
SPI接线方式的话,注意我这个帖子说明
STM32F407板子SPI接口方式AD7606接线说明(2021-12-15)
https://www.armbbs.cn/forum.php?mod=viewthread&tid=110114
发表于 2023-3-19 11:02:19 | 显示全部楼层
emwin 发表于 2023-3-18 22:22
ADI官方驱动代码:https://wiki.analog.com/resources/tools-software/uc-drivers/ad7606
好帖,谢谢分享
 楼主| 发表于 2023-4-7 17:09:17 | 显示全部楼层
您好,我在更换了芯片之后发现芯片不发烫了,但是采集还是不正常,经过检查之后我发现我的原理图中VDRIVE引脚忘记接电源了处于悬空状态,但我测得电压大概在4.3V左右,我看了芯片手册但是不太理解手册里说的话,想问一下您这个引脚是什么作用呢?
发表于 2023-4-8 02:03:43 | 显示全部楼层
cxrose 发表于 2023-4-7 17:09
您好,我在更换了芯片之后发现芯片不发烫了,但是采集还是不正常,经过检查之后我发现我的原理图中VDRIVE ...
GMT+8, 2024-5-30 22:36 , Processed in 0.319878 second(s), 28 queries .
