/* Partial Copyright (c) Microsoft Corporation. All rights reserved.*/
/* This software is licensed under the Microsoft Software License */
/* Terms for Microsoft Azure RTOS. Full text of the license can be */
/* found in the LICENSE file at [url]https://aka.ms/AzureRTOS_EULA[/url] */
/* and in the root directory of this software. */
/* Partial Copyright (c) STMicroelctronics 2020. All rights reserved */
/* Include necessary system files. */
#include "fx_stm32_sd_driver.h"
#include "fx_api.h"
#include "sdio_sd.h"
#include "usart.h"
UINT _fx_partition_offset_calculate(void *partition_sector, UINT partition, ULONG *partition_start, ULONG *partition_size);
static UINT sd_read_data(FX_MEDIA *media_ptr, ULONG sector, UINT num_sectors, UINT use_scratch_buffer);
static UINT sd_write_data(FX_MEDIA *media_ptr, ULONG sector, UINT num_sectors, UINT use_scratch_buffer);
static TX_SEMAPHORE transfer_semaphore;
static uint8_t is_initialized = 0;
static int32_t check_sd_status()
uint32_t start = tx_time_get();
while (tx_time_get() - start < DEFAULT_TIMEOUT)
if (SD_GetStatus() == SD_TRANSFER_OK)
return 0;
return 1;
* @brief This function is the entry point to the STM32 SDIO disk driver. */
/* It relies on the STM32 peripheral library from ST.
* @param None
* @retval None
VOID fx_stm32_sd_driver(FX_MEDIA *media_ptr)
int32_t status;
ULONG partition_start;
ULONG partition_size;
#if (FX_DRIVER_CALLS_BSP_SD_INIT == 0)
is_initialized = 1; /* the SD was initialized by the application*/
//TX_INTERRUPT_SAVE_AREA
/* before performing any operation, check the status of the SDMMC */
if (is_initialized == 1)
if (check_sd_status() != 0)
media_ptr->fx_media_driver_status = FX_IO_ERROR;
return;
/* Process the driver request specified in the media control block. */
switch(media_ptr->fx_media_driver_request)
case FX_DRIVER_INIT:
#if (FX_DRIVER_CALLS_BSP_SD_INIT == 1)
/* Initialize the SD instance */
if (is_initialized == 0)
status = SD_Init();
if (status == 0)
is_initialized = 1;
/* create a binary semaphore to check the DMA transfer status */
if (tx_semaphore_create(&transfer_semaphore, "sdmmc dma transfer semaphore", 0) != TX_SUCCESS)
media_ptr->fx_media_driver_status = FX_SUCCESS;
case FX_DRIVER_UNINIT:
tx_semaphore_delete(&transfer_semaphore);
SD_DeInit();
is_initialized = 0;
/* Successful driver request. */
case FX_DRIVER_READ:
//TX_DISABLE /* disable interrupts */
if ((ULONG)(media_ptr->fx_media_driver_buffer) & 0x3)
if (sd_read_data(media_ptr, media_ptr->fx_media_driver_logical_sector + media_ptr->fx_media_hidden_sectors,
media_ptr->fx_media_driver_sectors, 1) == FX_SUCCESS)
media_ptr->fx_media_driver_sectors, 0) == FX_SUCCESS)
//TX_RESTORE /* restore interrupts */
case FX_DRIVER_WRITE:
if (sd_write_data(media_ptr, media_ptr->fx_media_driver_logical_sector + media_ptr->fx_media_hidden_sectors,
case FX_DRIVER_FLUSH:
/* Return driver success. */
case FX_DRIVER_ABORT:
case FX_DRIVER_BOOT_READ:
/* the boot sector is the sector 0 */
// status = BSP_SD_ReadBlocks_DMA((uint32_t*)media_ptr->fx_media_driver_buffer, 0, 1);
status = SD_ReadMultiBlocks((uint8_t *)media_ptr->fx_media_driver_buffer, 0, 512, 1);
// status = SD_ReadBlock((uint8_t *)media_ptr->fx_media_driver_buffer, 0, 1);
status = SD_WaitReadOperation();
while(SD_GetStatus() != SD_TRANSFER_OK);
tx_semaphore_put(&transfer_semaphore);
if (status != 0)
if(tx_semaphore_get(&transfer_semaphore, DEFAULT_TIMEOUT) != TX_SUCCESS)
/* Check if the sector 0 is the actual boot sector, otherwise calculate the offset into it.
Please note that this should belong to higher level of MW to do this check and it is here
as a temporary work solution */
partition_start = 0;
status = _fx_partition_offset_calculate(media_ptr -> fx_media_driver_buffer, 0,
&partition_start, &partition_size);
/* Check partition read error. */
if (status)
/* Unsuccessful driver request. */
media_ptr -> fx_media_driver_status = FX_IO_ERROR;
return;
/* Now determine if there is a partition... */
if (partition_start)
return;
/* Yes, now lets read the actual boot record. */
// status = BSP_SD_ReadBlocks_DMA((uint32_t*)media_ptr -> fx_media_driver_buffer, partition_start , 1);
/* Check status of SDIO Read. */
if (status != 0)
return;
/* Wait for Rx Transfer completion */
media_ptr -> fx_media_driver_status = FX_SUCCESS;
case FX_DRIVER_BOOT_WRITE:
// status = BSP_SD_WriteBlocks_DMA((uint32_t*)media_ptr->fx_media_driver_buffer, 0, 1);
status = SD_WriteMultiBlocks((uint8_t *)media_ptr->fx_media_driver_buffer, 0, 512, 1);
// status = SD_WriteBlock((uint8_t *)media_ptr->fx_media_driver_buffer, 0, 1);
if (status == 0)
if(tx_semaphore_get(&transfer_semaphore, DEFAULT_TIMEOUT) == TX_SUCCESS)
default:
* @brief BSP Tx Transfer completed callbacks
* @param Instance the SD instance
* @retval None
//void BSP_SD_WriteCpltCallback()
// tx_semaphore_put(&transfer_semaphore);
// * @brief BSP Rx Transfer completed callbacks
// * @param Instance the sd instance
// * @retval None
//void BSP_SD_ReadCpltCallback()
* @brief Read buffer using BSP SD API taking into account the scratch buffer
* @param FX_MEDIA *media_ptr a pointer the main FileX structure
* @param ULONG start_sector first sector to start reading from
* @param UINT num_sectors number of sectors to be read
* @param UINT use_scratch_buffer to enable scratch buffer usage or not.
* @retval FX_SUCCESS on success FX_BUFFER_ERROR otherwise
static UINT sd_read_data(FX_MEDIA *media_ptr, ULONG start_sector, UINT num_sectors, UINT use_scratch_buffer)
UINT status;
//status = BSP_SD_ReadBlocks_DMA((uint32_t*)media_ptr->fx_media_driver_buffer, start_sector, num_sectors);
status = SD_ReadMultiBlocks((uint8_t *)media_ptr->fx_media_driver_buffer, start_sector, 512, num_sectors);
if (status == 0)
status = FX_BUFFER_ERROR;
return status;
* @brief write buffer using BSP SD API taking into account the scratch buffer
* @param ULONG start_sector first sector to start writing from
* @param UINT num_sectors number of sectors to be written
static UINT sd_write_data(FX_MEDIA *media_ptr, ULONG start_sector, UINT num_sectors, UINT use_scratch_buffer)
UINT status;
//BSP_SD_WriteBlocks_DMA(uint32_t *pData, uint32_t WriteAddr, uint32_t NumOfBlocks)
// BSP_SD_WriteBlocks_DMA((uint32_t*)media_ptr->fx_media_driver_buffer, start_sector, num_sectors);
status = SD_WriteMultiBlocks((uint8_t *)media_ptr->fx_media_driver_buffer, start_sector, 512, num_sectors);
if (status == 0)
return status;
