查看: 1104|回复: 4
[RTOS Trace] H7-TOOL的RTOS Trace增加uCOS-II Trace支持,预计本周完成,同时更新FreeRTOS Trace用户手头添加变量地址玩法(2023-05-24)
发表于 2023-5-17 06:02:10 | 显示全部楼层 |阅读模式
当前Trace功能已经支持uCOS-III,RTX5和ThreadX,本周开始增加下uCOS-II的Trace支持,另外FreeRTOS也发布临时玩法会大家。
 楼主| 发表于 2023-5-18 09:05:57 | 显示全部楼层
2023-05-18
先用最新的uCOS-II V2.93.00测试
 楼主| 发表于 2023-5-21 01:25:24 | 显示全部楼层
2023-05-21
关键代码记录:
*                                              uC/OS-II
*                                        The Real-Time Kernel
*                    Copyright 1992-2020 Silicon Laboratories Inc. [url=http://www.silabs.com]www.silabs.com[/url]
*                                 SPDX-License-Identifier: APACHE-2.0
*               This software is subject to an open source license and is distributed by
*                Silicon Laboratories Inc. pursuant to the terms of the Apache License,
*                    Version 2.0 available at [url=http://www.apache.org/licenses/LICENSE-2.0.]www.apache.org/licenses/LICENSE-2.0.[/url]
*                                          DEBUGGER CONSTANTS
* Filename : os_dbg_r.c
* Version  : V2.93.00
#define  MICRIUM_SOURCE
#include <ucos_ii.h>
*                                             DEBUG DATA
INT16U  const  OSDebugEn             = OS_DEBUG_EN;             /* Debug constants are defined below   */
#if OS_DEBUG_EN > 0u
INT32U  const  OSEndiannessTest      = 0x12345678uL;            /* Variable to test CPU endianness     */
INT16U  const  OSEventEn             = OS_EVENT_EN;
INT16U  const  OSEventMax            = OS_MAX_EVENTS;           /* Number of event control blocks      */
INT16U  const  OSEventNameEn         = OS_EVENT_NAME_EN;
#if (OS_EVENT_EN) && (OS_MAX_EVENTS > 0u)
INT16U  const  OSEventSize           = sizeof(OS_EVENT);        /* Size in Bytes of OS_EVENT           */
INT16U  const  OSEventTblSize        = sizeof(OSEventTbl);      /* Size of OSEventTbl[] in bytes       */
#else
INT16U  const  OSEventSize           = 0u;
INT16U  const  OSEventTblSize        = 0u;
INT16U  const  OSEventMultiEn        = OS_EVENT_MULTI_EN;
INT16U  const  OSFlagEn              = OS_FLAG_EN;
#if (OS_FLAG_EN > 0u) && (OS_MAX_FLAGS > 0u)
INT16U  const  OSFlagGrpSize         = sizeof(OS_FLAG_GRP);     /* Size in Bytes of OS_FLAG_GRP        */
INT16U  const  OSFlagNodeSize        = sizeof(OS_FLAG_NODE);    /* Size in Bytes of OS_FLAG_NODE       */
INT16U  const  OSFlagWidth           = sizeof(OS_FLAGS);        /* Width (in bytes) of OS_FLAGS        */
#else
INT16U  const  OSFlagGrpSize         = 0u;
INT16U  const  OSFlagNodeSize        = 0u;
INT16U  const  OSFlagWidth           = 0u;
INT16U  const  OSFlagMax             = OS_MAX_FLAGS;
INT16U  const  OSFlagNameEn          = OS_FLAG_NAME_EN;
INT16U  const  OSLowestPrio          = OS_LOWEST_PRIO;
INT16U  const  OSMboxEn              = OS_MBOX_EN;
INT16U  const  OSMemEn               = OS_MEM_EN;
INT16U  const  OSMemMax              = OS_MAX_MEM_PART;         /* Number of memory partitions         */
INT16U  const  OSMemNameEn           = OS_MEM_NAME_EN;
#if (OS_MEM_EN > 0u) && (OS_MAX_MEM_PART > 0u)
INT16U  const  OSMemSize             = sizeof(OS_MEM);          /* Mem. Partition header sine (bytes)  */
INT16U  const  OSMemTblSize          = sizeof(OSMemTbl);
#else
INT16U  const  OSMemSize             = 0u;
INT16U  const  OSMemTblSize          = 0u;
INT16U  const  OSMutexEn             = OS_MUTEX_EN;
INT16U  const  OSPtrSize             = sizeof(void *);          /* Size in Bytes of a pointer          */
INT16U  const  OSQEn                 = OS_Q_EN;
INT16U  const  OSQMax                = OS_MAX_QS;               /* Number of queues                    */
#if (OS_Q_EN > 0u) && (OS_MAX_QS > 0u)
INT16U  const  OSQSize               = sizeof(OS_Q);            /* Size in bytes of OS_Q structure     */
#else
INT16U  const  OSQSize               = 0u;
INT16U  const  OSRdyTblSize          = OS_RDY_TBL_SIZE;         /* Number of bytes in the ready table  */
INT16U  const  OSSemEn               = OS_SEM_EN;
INT16U  const  OSStkWidth            = sizeof(OS_STK);          /* Size in Bytes of a stack entry      */
INT16U  const  OSTaskCreateEn        = OS_TASK_CREATE_EN;
INT16U  const  OSTaskCreateExtEn     = OS_TASK_CREATE_EXT_EN;
INT16U  const  OSTaskDelEn           = OS_TASK_DEL_EN;
INT16U  const  OSTaskIdleStkSize     = OS_TASK_IDLE_STK_SIZE;
INT16U  const  OSTaskProfileEn       = OS_TASK_PROFILE_EN;
INT16U  const  OSTaskMax             = OS_MAX_TASKS + OS_N_SYS_TASKS; /* Total max. number of tasks    */
INT16U  const  OSTaskNameEn          = OS_TASK_NAME_EN;
INT16U  const  OSTaskStatEn          = OS_TASK_STAT_EN;
INT16U  const  OSTaskStatStkSize     = OS_TASK_STAT_STK_SIZE;
INT16U  const  OSTaskStatStkChkEn    = OS_TASK_STAT_STK_CHK_EN;
INT16U  const  OSTaskSwHookEn        = OS_TASK_SW_HOOK_EN;
INT16U  const  OSTaskRegTblSize      = OS_TASK_REG_TBL_SIZE;
INT16U  const  OSTCBPrioTblMax       = OS_LOWEST_PRIO + 1u;     /* Number of entries in OSTCBPrioTbl[] */
INT16U  const  OSTCBSize             = sizeof(OS_TCB);          /* Size in Bytes of OS_TCB             */
INT16U  const  OSTicksPerSec         = OS_TICKS_PER_SEC;
INT16U  const  OSTimeTickHookEn      = OS_TIME_TICK_HOOK_EN;
INT16U  const  OSVersionNbr          = OS_VERSION;
#if OS_TASK_CREATE_EXT_EN > 0u
#if defined(OS_TLS_TBL_SIZE) && (OS_TLS_TBL_SIZE > 0u)
INT16U  const  OS_TLS_TblSize        = OS_TLS_TBL_SIZE * sizeof(OS_TLS);
#else
INT16U  const  OS_TLS_TblSize        = 0u;
INT16U  const  OSTmrEn               = OS_TMR_EN;
INT16U  const  OSTmrCfgMax           = OS_TMR_CFG_MAX;
INT16U  const  OSTmrCfgNameEn        = OS_TMR_CFG_NAME_EN;
INT16U  const  OSTmrCfgWheelSize     = OS_TMR_CFG_WHEEL_SIZE;
INT16U  const  OSTmrCfgTicksPerSec   = OS_TMR_CFG_TICKS_PER_SEC;
#if (OS_TMR_EN > 0u) && (OS_TMR_CFG_MAX > 0u)
INT16U  const  OSTmrSize             = sizeof(OS_TMR);
INT16U  const  OSTmrTblSize          = sizeof(OSTmrTbl);
INT16U  const  OSTmrWheelSize        = sizeof(OS_TMR_WHEEL);
INT16U  const  OSTmrWheelTblSize     = sizeof(OSTmrWheelTbl);
#else
INT16U  const  OSTmrSize             = 0u;
INT16U  const  OSTmrTblSize          = 0u;
INT16U  const  OSTmrWheelSize        = 0u;
INT16U  const  OSTmrWheelTblSize     = 0u;
*                                             DEBUG DATA
*                            TOTAL DATA SPACE (i.e. RAM) USED BY uC/OS-II
INT16U  const  OSDataSize = sizeof(OSCtxSwCtr)
                          + sizeof(OSEventFreeList)
                          + sizeof(OSEventTbl)
                          + sizeof(OSFlagTbl)
                          + sizeof(OSFlagFreeList)
#if OS_TASK_STAT_EN > 0u
                          + sizeof(OSCPUUsage)
                          + sizeof(OSIdleCtrMax)
                          + sizeof(OSIdleCtrRun)
                          + sizeof(OSStatRdy)
                          + sizeof(OSTaskStatStk)
#if OS_TICK_STEP_EN > 0u
                          + sizeof(OSTickStepState)
                          + sizeof(OSMemFreeList)
                          + sizeof(OSMemTbl)
#ifdef OS_SAFETY_CRITICAL_IEC61508
                          + sizeof(OSSafetyCriticalStartFlag)
                          + sizeof(OSQFreeList)
                          + sizeof(OSQTbl)
#if OS_TASK_REG_TBL_SIZE > 0u
                          + sizeof(OSTaskRegNextAvailID)
#if OS_TIME_GET_SET_EN > 0u
                          + sizeof(OSTime)
                          + sizeof(OSTmrFree)
                          + sizeof(OSTmrUsed)
                          + sizeof(OSTmrTime)
                          + sizeof(OSTmrSem)
                          + sizeof(OSTmrSemSignal)
                          + sizeof(OSTmrTbl)
                          + sizeof(OSTmrFreeList)
                          + sizeof(OSTmrTaskStk)
                          + sizeof(OSTmrWheelTbl)
                          + sizeof(OSIntNesting)
                          + sizeof(OSLockNesting)
                          + sizeof(OSPrioCur)
                          + sizeof(OSPrioHighRdy)
                          + sizeof(OSRdyGrp)
                          + sizeof(OSRdyTbl)
                          + sizeof(OSRunning)
                          + sizeof(OSTaskCtr)
                          + sizeof(OSIdleCtr)
                          + sizeof(OSTaskIdleStk)
                          + sizeof(OSTCBCur)
                          + sizeof(OSTCBFreeList)
                          + sizeof(OSTCBHighRdy)
                          + sizeof(OSTCBList)
                          + sizeof(OSTCBPrioTbl)
                          + sizeof(OSTCBTbl);
*                                       OS DEBUG INITIALIZATION
* Description: This function is used to make sure that debug variables that are unused in the application
*              are not optimized away.  This function might not be necessary for all compilers.  In this
*              case, you should simply DELETE the code in this function while still leaving the declaration
*              of the function itself.
* Arguments  : none
* Returns    : none
* Note(s)    : (1) This code doesn't do anything, it simply prevents the compiler from optimizing out
*                  the 'const' variables which are declared in this file.
*              (2) You may decide to 'compile out' the code (by using #if 0/#endif) INSIDE the function
*                  if your compiler DOES NOT optimize out the 'const' variables above.
void  OSDebugInit (void)
    void  const  *ptemp;
    ptemp = (void const *)&OSDebugEn;
    ptemp = (void const *)&OSEndiannessTest;
    ptemp = (void const *)&OSEventMax;
    ptemp = (void const *)&OSEventNameEn;
    ptemp = (void const *)&OSEventEn;
    ptemp = (void const *)&OSEventSize;
    ptemp = (void const *)&OSEventTblSize;
    ptemp = (void const *)&OSEventMultiEn;
    ptemp = (void const *)&OSFlagEn;
    ptemp = (void const *)&OSFlagGrpSize;
    ptemp = (void const *)&OSFlagNodeSize;
    ptemp = (void const *)&OSFlagWidth;
    ptemp = (void const *)&OSFlagMax;
    ptemp = (void const *)&OSFlagNameEn;
    ptemp = (void const *)&OSLowestPrio;
    ptemp = (void const *)&OSMboxEn;
    ptemp = (void const *)&OSMemEn;
    ptemp = (void const *)&OSMemMax;
    ptemp = (void const *)&OSMemNameEn;
    ptemp = (void const *)&OSMemSize;
    ptemp = (void const *)&OSMemTblSize;
    ptemp = (void const *)&OSMutexEn;
    ptemp = (void const *)&OSPtrSize;
    ptemp = (void const *)&OSQEn;
    ptemp = (void const *)&OSQMax;
    ptemp = (void const *)&OSQSize;
    ptemp = (void const *)&OSRdyTblSize;
    ptemp = (void const *)&OSSemEn;
    ptemp = (void const *)&OSStkWidth;
    ptemp = (void const *)&OSTaskCreateEn;
    ptemp = (void const *)&OSTaskCreateExtEn;
    ptemp = (void const *)&OSTaskDelEn;
    ptemp = (void const *)&OSTaskIdleStkSize;
    ptemp = (void const *)&OSTaskProfileEn;
    ptemp = (void const *)&OSTaskMax;
    ptemp = (void const *)&OSTaskNameEn;
    ptemp = (void const *)&OSTaskStatEn;
    ptemp = (void const *)&OSTaskStatStkSize;
    ptemp = (void const *)&OSTaskStatStkChkEn;
    ptemp = (void const *)&OSTaskSwHookEn;
    ptemp = (void const *)&OSTCBPrioTblMax;
    ptemp = (void const *)&OSTCBSize;
    ptemp = (void const *)&OSTicksPerSec;
    ptemp = (void const *)&OSTimeTickHookEn;
#if OS_TMR_EN > 0u
    ptemp = (void const *)&OSTmrTbl[0];
    ptemp = (void const *)&OSTmrWheelTbl[0];
    ptemp = (void const *)&OSTmrEn;
    ptemp = (void const *)&OSTmrCfgMax;
    ptemp = (void const *)&OSTmrCfgNameEn;
    ptemp = (void const *)&OSTmrCfgWheelSize;
    ptemp = (void const *)&OSTmrCfgTicksPerSec;
    ptemp = (void const *)&OSTmrSize;
    ptemp = (void const *)&OSTmrTblSize;
    ptemp = (void const *)&OSTmrWheelSize;
    ptemp = (void const *)&OSTmrWheelTblSize;
    ptemp = (void const *)&OSVersionNbr;
    ptemp = (void const *)&OSDataSize;
    ptemp = ptemp;                             /* Prevent compiler warning for 'ptemp' not being used! */
 楼主| 发表于 2023-5-22 02:53:48 | 显示全部楼层
2023-05-22
可以识别了
 楼主| 发表于 2023-5-24 01:22:25 | 显示全部楼层
2023-05-24
GMT+8, 2025-6-3 07:31 , Processed in 0.243500 second(s), 27 queries .
