查看: 856|回复: 1
[有问必答] 这个链表是正常的吗?
发表于 2023-5-24 17:17:19 | 显示全部楼层 |阅读模式
#include "list_menu.h"
Node_T *head, *son,*bro,*temp,*dirnow;
Node_T *creat_father(uint8_t *str,void (*f)(void))
    Node_T *temp = NULL;
    temp = (Node_T *)malloc(sizeof(Node_T));
    if (temp == NULL)
        return NULL;
    // temp->father = temp;
    temp->father = NULL;
    temp->brother_up = NULL;
    temp->brother_dw = NULL;
    temp->son = NULL;
    temp->str = str;
    temp->f=f;
//    printf("creat_father succeed\r\n");
//    printf("%s\t\t%x\r\n", temp->str, temp);
    return temp;
Node_T *creat_brother(Node_T *brother, uint8_t *str,void (*f)(void))
    Node_T *temp_1 = brother;
    if (temp == NULL)
        return NULL;
    temp->father = temp_1->father;
    while (temp_1->brother_dw != NULL)
        temp_1 = temp_1->brother_dw;
    temp_1->brother_dw = temp;
    temp->brother_up = temp_1;
    temp->son = NULL;
    temp->str = str;
    temp->f=f;
//    printf("creat_brother succeed\r\n");
    return temp;
Node_T *creat_son(Node_T *father, uint8_t *str,void (*f)(void))
    Node_T *temp_1 = father;
    if (temp == NULL)
        return NULL;
    temp->father = temp_1;
    temp_1->son = temp;
    temp->son = NULL;
    temp->str = str;
    temp->f=f;
//    printf("creat_son succeed\r\n");
    return temp;
void list_menu_int(void)
	head=creat_father("menu",NULL);
	son=creat_son(head,"item-1",NULL);
	bro=creat_brother(son,"item-2",NULL);
	creat_brother(bro,"item-3",NULL);
	creat_son(son,"item1-1-1",NULL);
typedef struct Node
    struct Node *father;
    struct Node *brother_up;
    struct Node *brother_dw;
    struct Node *son;
    char *str;
    void (*f)(void);
} Node_T;
按上述进行初始化后,在MDK变量观察到每个节点的结构都像第一张图一样,有多个成员。
发表于 2023-5-28 10:17:12 | 显示全部楼层
帮顶。
GMT+8, 2025-5-12 16:21 , Processed in 0.319780 second(s), 24 queries .
