查看: 1181|回复: 1
int square(volatile int* &ptr)和int square(volatile int*ptr)两个传参到底有什么区别?
发表于 2023-7-5 10:28:39 | 显示全部楼层 |阅读模式
发表于 2023-7-5 12:00:45 | 显示全部楼层
int square(volatile int*ptr) //passed by value
   ptr++; // change will be discarded once function returns
int square(volatile int* &ptr) //passed by reference
   ptr++; // change will persist when function returns
GMT+8, 2025-4-26 19:14 , Processed in 0.311434 second(s), 24 queries .
