查看: 2312|回复: 0
[LVGL] 找到LVGL滑动卡顿的根本原因
发表于 2023-7-17 02:40:29 | 显示全部楼层 |阅读模式
运行的案例Widgets demo,测试了H7和F429,800*480分辨率,硬件双缓冲,均会有卡顿现象。
最终LVGL的配置文件里面有个动态内存分配开小了,我直接使用AXI SRAM开了400KB,流畅了很多:
/*1: use custom malloc/free, 0: use the built-in `lv_mem_alloc()` and `lv_mem_free()`*/
#define LV_MEM_CUSTOM 0
#if LV_MEM_CUSTOM == 0
    /*Size of the memory available for `lv_mem_alloc()` in bytes (>= 2kB)*/
    #define LV_MEM_SIZE (400* 1024U)          /*[bytes]*/
    /*Set an address for the memory pool instead of allocating it as a normal array. Can be in external SRAM too.*/
    #define LV_MEM_ADR 0     /*0: unused*/
    /*Instead of an address give a memory allocator that will be called to get a memory pool for LVGL. E.g. my_malloc*/
    #if LV_MEM_ADR == 0
        #undef LV_MEM_POOL_INCLUDE
        #undef LV_MEM_POOL_ALLOC
#else       /*LV_MEM_CUSTOM*/
    #define LV_MEM_CUSTOM_INCLUDE <stdlib.h>   /*Header for the dynamic memory function*/
    #define LV_MEM_CUSTOM_ALLOC   malloc
    #define LV_MEM_CUSTOM_FREE    free
    #define LV_MEM_CUSTOM_REALLOC realloc
#endif     /*LV_MEM_CUSTOM*/
GMT+8, 2025-5-24 22:31 , Processed in 0.255069 second(s), 24 queries .
