查看: 1538|回复: 1
[开发工具] KEIL MDK5 内嵌汇编报错
发表于 2023-7-20 16:12:03 | 显示全部楼层 |阅读模式
inline int disable_irq(void) {
        int primask;
        __asm volatile("mrs %0, PRIMASK\n"
                                "cpsid i\n" : "=r"(primask));
        return primask & 1;
就是上面这段代码,在编译时报错,也不懂汇编,不知道是哪里的事情?..\src\util.c(32): error:  #18: expected a ")"                                  "cpsid i\n" : "=r"(primask));
发表于 2023-7-20 16:56:27 | 显示全部楼层
AC5:
  \brief   Set Priority Mask
  \details Assigns the given value to the Priority Mask Register.
  \param [in]    priMask  Priority Mask
__STATIC_INLINE void __set_PRIMASK(uint32_t priMask)
  register uint32_t __regPriMask         __ASM("primask");
  __regPriMask = (priMask);
AC6:
__STATIC_FORCEINLINE void __set_PRIMASK(uint32_t priMask)
  __ASM volatile ("MSR primask, %0" : : "r" (priMask) : "memory");
GMT+8, 2025-7-8 18:27 , Processed in 0.306049 second(s), 24 queries .
