查看: 1174|回复: 3
这个buf在调试的时候就只有一个长度,是正常的吗
发表于 2023-7-29 16:01:17 | 显示全部楼层 |阅读模式
usb_sts_type msc_disk_write(uint8_t lun, uint32_t addr, uint8_t *buf, uint32_t len);
  uint32_t flash_addr = addr + USB_FLASH_ADDR_OFFSET;
  uint32_t i = 0, page_len = 2048, tolen = len;
  uint32_t erase_addr = flash_addr;
  switch(lun)
    case 0:
      flash_unlock();
      while(tolen >= page_len)
        flash_sector_erase(erase_addr);
        tolen -= page_len;
        erase_addr += page_len;
      for(i = 0; i < len; i ++)
        flash_byte_program(flash_addr+i, buf[i]);
      flash_lock();
    case 1:
  return USB_OK;
上一级调用
usb_sts_type bot_scsi_write10(void *udev, uint8_t lun)
  usbd_core_type *pudev = (usbd_core_type *)udev;
  msc_type *pmsc = (msc_type *)pudev->class_handler->pdata;
  uint8_t *cmd = pmsc->cbw_struct.CBWCB;
  uint32_t len;
  if(pmsc->msc_state == MSC_STATE_MACHINE_IDLE)
    if((pmsc->cbw_struct.bmCBWFlags & 0x80) == 0x80)
      bot_scsi_sense_code(udev, SENSE_KEY_ILLEGAL_REQUEST, INVALID_COMMAND);
      return USB_FAIL;
    pmsc->blk_addr = cmd[2] << 24 | cmd[3] << 16 | cmd[4] << 8 | cmd[5];
    pmsc->blk_len = cmd[7] << 8 | cmd[8];
    if(bot_scsi_check_address(udev, lun, pmsc->blk_addr, pmsc->blk_len) != USB_OK)
      return USB_FAIL;
    pmsc->blk_addr *= pmsc->blk_size[lun];
    pmsc->blk_len *= pmsc->blk_size[lun];
    if(pmsc->cbw_struct.dCBWDataTransferLength != pmsc->blk_len)
      return USB_FAIL;
    pmsc->msc_state  = MSC_STATE_MACHINE_DATA_OUT;
    len = MIN(pmsc->blk_len, MSC_MAX_DATA_BUF_LEN);
    usbd_ept_recv(pudev, USBD_MSC_BULK_OUT_EPT, (uint8_t *)pmsc->data, len);
    if(msc_disk_write(lun, pmsc->blk_addr, pmsc->data, len) != USB_OK)
      bot_scsi_sense_code(udev, SENSE_KEY_HARDWARE_ERROR, MEDIUM_NOT_PRESENT);
      return USB_FAIL;
    pmsc->blk_addr += len;
    pmsc->blk_len -= len;
    pmsc->csw_struct.dCSWDataResidue -= len;
    if(pmsc->blk_len == 0)
      bot_scsi_send_csw(udev, CSW_BCSWSTATUS_PASS);
  return USB_OK;
  * @brief  clear feature
  * @param  udev: to the structure of usbd_core_type
  * @param  etp_num: endpoint number
  * @retval status of usb_sts_type
理论上写入数据的时候,buf传入的是一个数组的地址,应该可以观察到类似buf[0] buf[1]....的,但是这边怎么就只有 一个buf[0]?
typedef struct
  uint8_t msc_state;
  uint8_t bot_status;
  uint32_t max_lun;
  uint32_t blk_nbr[MSC_SUPPORT_MAX_LUN];
  uint32_t blk_size[MSC_SUPPORT_MAX_LUN];
  uint32_t blk_addr;
  uint32_t blk_len;
  uint32_t data_len;
  uint8_t data[MSC_MAX_DATA_BUF_LEN];
  uint32_t alt_setting;
  cbw_type cbw_struct;
  csw_type csw_struct;
}msc_type;
发表于 2023-7-29 17:51:23 | 显示全部楼层
这几个是函数形参,调试查看不方便,打印出来看下。
 楼主| 发表于 2023-7-29 19:58:25 | 显示全部楼层
论坛怎么图片都不会正常显示呀。另外想看 模拟U盘 的相关教程可以参照之前的哪个教程呀。
发表于 2023-7-29 21:10:10 | 显示全部楼层
论坛的图片复制粘贴插件bug了,需要上传下才行。
模拟U盘的例子做了很多,楼主要看那个ST USB,RL-USB还是USBX
GMT+8, 2025-7-4 18:18 , Processed in 0.323076 second(s), 24 queries .
