查看: 824|回复: 0
LPython:新颖、快速、可重定向的 Python 编译器
发表于 2023-8-15 03:00:57 | 显示全部楼层 |阅读模式
https://github.com/lcompilers/lpython
https://lpython.org/blog/2023/07/lpython-novel-fast-retargetable-python-compiler/
LPython是一个Python编译器,可以将type annotated 动态类型的Python代码编译为优化的机器代码。LPython提供了几个后端,如LLVM,C,C++,WASM,Julia和x86。LPython 具有快速编译和运行时性能。LPython还提供即时(JIT)编译以及与CPython的无缝互操作性。
测试代码:
from lpython import i32
def main():
    x: i32
    x = (2+3)*5
    print(x)
main()
生成C和LLVM
$ lpython examples/expr2.py --show-c
#include <inttypes.h>
#include <stdlib.h>
#include <stdbool.h>
#include <stdio.h>
#include <string.h>
#include <lfortran_intrinsics.h>
void main0();
void __main____global_statements();
// Implementations
void main0()
    int32_t x;
    x = (2 + 3)*5;
    printf("%d\n", x);
    main0();
int main(int argc, char* argv[])
    _lpython_set_argv(argc, argv);
    return 0;
$ lpython examples/expr2.py --show-llvm
; ModuleID = 'LFortran'
source_filename = "LFortran"
@0 = private unnamed_addr constant [2 x i8] c" \00", align 1
@1 = private unnamed_addr constant [2 x i8] c"\0A\00", align 1
@2 = private unnamed_addr constant [5 x i8] c"%d%s\00", align 1
define void @__module___main_____main____global_statements() {
.entry:
  call void @__module___main___main0()
  br label %return
return:                                           ; preds = %.entry
  ret void
define void @__module___main___main0() {
.entry:
  %x = alloca i32, align 4
  store i32 25, i32* %x, align 4
  %0 = load i32, i32* %x, align 4
  call void (i8*, ...) @_lfortran_printf(i8* getelementptr inbounds ([5 x i8], [5 x i8]* @2, i32 0, i32 0), i32 %0, i8* getelementptr inbounds ([2 x i8], [2 x i8]* @1, i32 0, i32 0))
  br label %return
  ret void
declare void @_lfortran_printf(i8*, ...)
define i32 @main(i32 %0, i8** %1) {
.entry:
  call void @_lpython_set_argv(i32 %0, i8** %1)
  call void @__module___main_____main____global_statements()
  ret i32 0
declare void @_lpython_set_argv(i32, i8**)
GMT+8, 2024-5-14 22:09 , Processed in 0.236237 second(s), 25 queries .
