查看: 1342|回复: 6
[μCOS-III] 最新Cs/OS3 V3.09.02
发表于 2023-8-19 14:36:12 | 显示全部楼层 |阅读模式
如题,有没有相应开源版本的uCOS III ?好像添加了不少实用的新特性
发表于 2023-8-19 15:25:45 | 显示全部楼层
看了下,没有大的更新,都是微更新
https://www.weston-embedded.com/ ... s-os3-release-notes
Version 3.09.02
Release Date
June 23, 2023
Changelog
Bugfix: Fixed mutex corruption owner corruption with deleting a task.
Updated version checks to reflect initial Cesium Releases.
Bugfix: Fixed pendlist corruption issue when deleting tasks with TLS enabled.
RISC-V: Added IAR port for the RV32 architecture.
ARMv8-M: Added option to disable non kernel-aware ISR support by setting the IPL Boundary to 0.
Reworked the Periodic Delay feature to provide proper wallclock functionality.
Bugfix: Fixed build errors in os_data.c when building in a C++ environment.
Version 3.09.01
Release Date
December 21, 2022
Changelog
Added TLS Port for IAR EWARMv8 and above.
Added FIFO-Order pending feature to Semaphores, Mutexes, Queues, and Data Queues.
Extended create APIs have been added for the application to specify Priority-order or FIFO-order pending.
ARMv7-M: Added option to disable non kernel-aware ISR support by setting the IPL Boundary to 0.
Bugfix: Pendlist corruption occurred when Tasks pending on a Data Queue were deleted or had their priority changed.
Version 3.09.00
Release Date
June 27, 2022
Changelog
Added OS_DATA API: A Thread-Safe method for copying data between tasks.
Added support for ARM and GNU toolchains to the ARMv8-M port.
New option: OS_CFG_CALLED_FROM_TMR_CHK_EN - Prevent pends from OS_TMRs by returning an error.
Added missing checks for OS_CFG_TS_EN to OSFlagPend().
Added missing Debug Variables for compile-time options to os_dbg.c.
Fixed ARMv7m and ARMv6-M GNU ports having a hard fault due to a missing .thumb_func before PendSV_Handler.
Version 3.08.03
Release Date
October 22, 2021
Changelog
Added ARM-Cortex-M/ARMv8-M port for EWARM.
Fixed bug in OS_FlagTaskRdy which fails to remove TCB from the tick list if task state is OS_TASK_STATE_PEND_TIMEOUT_SUSPENDED.
Fixed bug in OS_TaskChangePrio which incorrectly lowers the priority of a high-priority task which is holding a mutex if a low-priority task blocking on the same mutex has its priority lowered.
 楼主| 发表于 2023-8-19 15:29:39 | 显示全部楼层
这个:
看起来很实用,逻辑上很明确:先来先得
还有TLS支持,往C11标准实现更近一步
发表于 2023-8-19 15:45:41 | 显示全部楼层
h_007 发表于 2023-8-19 15:29
这个:
Extended  ...
消息优先级问题,这个CMSIS-RTOS V2封装层有,实际上很少用。
发表于 2023-8-29 16:47:01 | 显示全部楼层
eric2013 发表于 2023-8-19 15:25
看了下,没有大的更新,都是微更新
这个 ucos3   v3.9.2 哪里可以下载啊 ?
发表于 2023-8-30 11:06:38 | 显示全部楼层
现在还没有下载。
发表于 2023-8-30 12:04:54 | 显示全部楼层
eric2013 发表于 2023-8-30 11:06
现在还没有下载。
感觉现在下载 ucos 会狠麻烦, 现在不像以前下载那么方面了 吧 ??
GMT+8, 2025-5-24 22:30 , Processed in 0.283331 second(s), 27 queries .
