查看: 1901|回复: 6
[Source Insight] Source Insight发布更新V4.0.0132
More we do, more we can do.
发表于 2023-10-31 08:38:13 | 显示全部楼层 |阅读模式
New: There is a new Project > Recent Projects menu item so you can easily re-open a recently opened project. The Recent Projects menu item also appears in the right-click context menu if you click in the frame of the program.
New: The File > Recent Files list was increased from 20 to 30 files. You can also remove a file from the Recent Files list by holding down CTRL while selecting the file on the menu.
New: Zoom In (CTRL+SHIFT+>) and Zoom Out (CTRL+SHIFT+<) commands so you can increase or decrease the font size with a keystroke.
Fix: Token macros (preprocessor macros) were not expanded and applied when evaluating expressions in #if, #ifdef, #ifndef, or #elif preprocessor statements.
Fix: FTP panel was not listing files for some versions of the Microsoft IIS FTP server.
Fix: C++: The types implied by some smart ptr types were not being resolved correctly.
Change: Updated the code signing certificate.
Version 4.0.0131 Changes
New: Toggle Comment Lines command added (menu Edit > Special Edit > Toggle Comment Lines). The default keystroke is CTRL+7. This toggles the comment state of a selected block of lines. The block is considered commented if ALL lines in the block are already commented out.
Fix: Relation Window was always showing items for extern declarations of variables, even though the "External Variable" type was disabled in the Relation window symbol type setting.
Fix: C# ref struct was not parsed correctly.
Fix: Added support for old-style C function parameter declarations where function parameters are declared below the parameter list and before the opening curly brace. This is an option that is enabled by default. You can control it in Options > Preferences > Languages > Special.
发表于 2023-10-31 08:52:16 | 显示全部楼层
这个更新毫无新意
发表于 2023-10-31 09:22:50 | 显示全部楼层
能查最近打开的工程还是挺好的
发表于 2023-10-31 13:46:01 | 显示全部楼层
单行切换注释和最近功能不错哇,终于有这个功能了
发表于 2023-11-1 14:04:53 | 显示全部楼层
不晓得可以支持astyle在中文路径了没,之前si3是可以,,,一直等si4的支持
发表于 2023-11-1 16:59:28 | 显示全部楼层
很好,以前的破解还能用!
发表于 2023-11-2 11:25:49 | 显示全部楼层
上传共享一下
sourceinsight40132_5878-setup.exe
20.34 MB, 下载次数: 61
GMT+8, 2025-4-29 02:10 , Processed in 0.243191 second(s), 26 queries .
