查看: 1088|回复: 6
[J-Link] eclipse+jlink在RAM中调试代码
发表于 2023-12-4 14:29:36 | 显示全部楼层 |阅读模式
使用eclipse+jlink下载到flash中调试stm32g0已经可以,现在想把代码放到RAM中调试,改了3个地方,但失败了,请问有研究过的小伙伴吗?网上资料都查不到
1、定义VECT_TAB_SRAM宏定义
2、修改脚本文件,代码都映射到RAM中
3、修改Debug配置选项
修改的脚本文件
/* Entry Point */
ENTRY(Reset_Handler)
/* Highest address of the user mode stack */
_estack = 0x20009000;    /* end of RAM */
/* Generate a link error if heap and stack don't fit into RAM */
_Min_Heap_Size = 0x200;      /* required amount of heap  */
_Min_Stack_Size = 0x400; /* required amount of stack */
/* Specify the memory areas */
MEMORY
RAM (xrw)      : ORIGIN = 0x20004000, LENGTH = 20K
FLASH (rx)      : ORIGIN = 0x20000000, LENGTH = 16K
/* Define output sections */
SECTIONS
  /* The startup code goes first into FLASH */
  .isr_vector :
    . = ALIGN(4);
    KEEP(*(.isr_vector)) /* Startup code */
    . = ALIGN(4);
  } >FLASH
  /* The program code and other data goes into FLASH */
  .text :
    . = ALIGN(4);
    *(.text)           /* .text sections (code) */
    *(.text*)          /* .text* sections (code) */
    *(.glue_7)         /* glue arm to thumb code */
    *(.glue_7t)        /* glue thumb to arm code */
    *(.eh_frame)
    KEEP (*(.init))
    KEEP (*(.fini))
    . = ALIGN(4);
    _etext = .;        /* define a global symbols at end of code */
  } >FLASH
  /* Constant data goes into FLASH */
  .rodata :
    . = ALIGN(4);
    *(.rodata)         /* .rodata sections (constants, strings, etc.) */
    *(.rodata*)        /* .rodata* sections (constants, strings, etc.) */
    . = ALIGN(4);
  } >FLASH
  .ARM.extab   : { *(.ARM.extab* .gnu.linkonce.armextab.*) } >FLASH
  .ARM : {
    __exidx_start = .;
    *(.ARM.exidx*)
    __exidx_end = .;
  } >FLASH
  .preinit_array     :
    PROVIDE_HIDDEN (__preinit_array_start = .);
    KEEP (*(.preinit_array*))
    PROVIDE_HIDDEN (__preinit_array_end = .);
  } >FLASH
  .init_array :
    PROVIDE_HIDDEN (__init_array_start = .);
    KEEP (*(SORT(.init_array.*)))
    KEEP (*(.init_array*))
    PROVIDE_HIDDEN (__init_array_end = .);
  } >FLASH
  .fini_array :
    PROVIDE_HIDDEN (__fini_array_start = .);
    KEEP (*(SORT(.fini_array.*)))
    KEEP (*(.fini_array*))
    PROVIDE_HIDDEN (__fini_array_end = .);
  } >FLASH
  /* used by the startup to initialize data */
  _sidata = LOADADDR(.data);
  /* Initialized data sections goes into RAM, load LMA copy after code */
  .data :
    . = ALIGN(4);
    _sdata = .;        /* create a global symbol at data start */
    *(.data)           /* .data sections */
    *(.data*)          /* .data* sections */
    . = ALIGN(4);
    _edata = .;        /* define a global symbol at data end */
  } >RAM AT> FLASH
  /* Uninitialized data section */
  . = ALIGN(4);
  .bss :
    /* This is used by the startup in order to initialize the .bss secion */
    _sbss = .;         /* define a global symbol at bss start */
    __bss_start__ = _sbss;
    *(.bss)
    *(.bss*)
    *(COMMON)
    . = ALIGN(4);
    _ebss = .;         /* define a global symbol at bss end */
    __bss_end__ = _ebss;
  } >RAM
  /* User_heap_stack section, used to check that there is enough RAM left */
  ._user_heap_stack :
    . = ALIGN(4);
    PROVIDE ( end = . );
    PROVIDE ( _end = . );
    . = . + _Min_Heap_Size;
    . = . + _Min_Stack_Size;
    . = ALIGN(4);
  } >RAM
  /* Remove information from the standard libraries */
  /DISCARD/ :
    libc.a ( * )
    libm.a ( * )
    libgcc.a ( * )
  .ARM.attributes 0 : { *(.ARM.attributes) }
发表于 2023-12-4 15:44:32 | 显示全部楼层
帮顶,没在eclipse上设置过RAM调试。
 楼主| 发表于 2023-12-4 16:29:34 | 显示全部楼层
如果只把某个函数放到RAM中运行呢?硬汉有接触过吗?我改了也不成功
More we do, more we can do.
发表于 2023-12-4 18:39:58 | 显示全部楼层
发表于 2023-12-4 19:41:51 | 显示全部楼层
了解下data段数据在main之前的处理过程
 楼主| 发表于 2023-12-5 10:28:40 | 显示全部楼层
emwin 发表于 2023-12-4 18:39
参考文章:HOWTO: Execute a library function from RAM memory ... - NXP Community
感谢分享,能把函数放到RAM里执行了,还是想实现整个代码放到RAM里执行,MDK就可以,eclipse不知道少了哪步
 楼主| 发表于 2023-12-5 11:34:39 | 显示全部楼层
我的步骤是正确的,犯了低级错误,工程选择核的时候选了M3,改成M0就可以了
GMT+8, 2025-4-29 01:56 , Processed in 0.231927 second(s), 27 queries .
