换了新电脑Jlink没法擦除跟烧录了,换回以前电脑就正常,是不是要License,擦除时显示CPUWARNING: CPU could not be halted
J-Link>Info: Device "MK10DX256XXX10" selected (512 KB flash, 64 KB RAM).
Reconnecting to target...
Info: TotalIRLen = 4, IRPrint = 0x01
Info: Found Cortex-M4 r0p1, Little endian.
Info: FPUnit: 6 code (BP) slots and 2 literal slots
Info: TPIU fitted.
Info: ETM fitted.
Info: ETB present.
Info: CSTF present.
J-Link>Found SWD-DP with ID 0x2BA01477
Unlocking device...O.K.
J-Link>Info: Found SWD-DP with ID 0x2BA01477
Info: TPIU fitted.
Info: ETM fitted.
Info: ETB present.
Info: CSTF present.
Erasing device (MK10DX256xxx10)...
Info: J-Link: Flash download: Total time needed: 0.942s (Prepare: 0.339s, Compare: 0.000s, Erase: 0.592s, Program: 0.000s, Verify: 0.000s, Restore: 0.010s)
ERROR: Erase returned with error code -5.
J-Link>Reset delay: 0 ms
Reset type NORMAL: Resets core & peripherals via SYSRESETREQ & VECTRESET bit.
Info: SYSRESETREQ has confused core. Trying to reconnect and use VECTRESET.
WARNING: Failed to reset CPU. VECTRESET has confused core.
WARNING: CPU did not halt after reset.
Info: Core did not halt after reset, trying to disable WDT.
WARNING: Could not set S_RESET_ST
****** Error: Error while identifying Cortex-M core.
J-Link>
