查看: 1087|回复: 10
[emWin] emwin小白求助
发表于 2024-1-2 10:47:00 | 显示全部楼层 |阅读模式
小白求助,我之前使用新唐的N9H20K31开发一个项目,使用emwin的版本是V6.34,搭配AppWizard V140b_634a开发了一个HMI界面。但是新唐的mcu太贵了,现在打算换成全志的F1C100S作为驱动MCU,将APPWIZARD生成的工程移植过去全志的程序之后出现报错,请问有没有解决办法。
.\Temp\Obj\Blinky.axf: Error: L6218E: Undefined symbol APPW_SetData(referred from appwconf.o).
\Temp\Obj\Blinky.axf: Error: L6218E:Undefined symbolAPPW SetSupportScroller (referred from appwconf.o).
\Temp\Obj\Blinky.axf: Error: 6218E:Undefined symbol APPW_SetpfInitText (referred from appwconf.o).
\Temp\Obj\Blinky.axf: Error6218E:Undefined APPW_TextInitMem (referred from appwconf.o).
\Temp\Obj\Blinky.axf:Error6218E:Undefined symbol GUI_ShowMissingCharacters(referred from appwconf.o).
\Temp\Obj\Blinky.axf:Error6218E:Undefined symbol APPWCompareIsEqual(referred from id screen main.o).
\Temp\Obj\Blinky.axf:Error6218E:Undefined symbol WM_OBJECT_BOX_Create (referred from id_screen_main.o).
\Temp\Obj\B1inky.axf: Error: L6218E:Undefined symbol WM_OBJECT_BUTTON_Create (referred from id_screen_main.o).
.\Temp\Obj\Blinky.axf: Error: L6218E: Undefined symbol WM OBJECT GAUGE Create
.\Temp\Obj\Blinky.axf: Error: L6218E: Undefined symbol WM OBJECT IMAGE Create
.\Temp\Obj\Blinky.axf: Error: L6218E: Undefined symbol WM_OBJECT_ROTARY_Create (referred from id_screen_main.o).
.\Temp\Obj\B1inky.axf: Error: L6218E:Undefined symbol WM OBJECT TEXT Create (referred from id screen main.o).
WM OBJECT WINDOW Create (referred from id_screen_main.o).
\Temp\Obj\B1inky.axf: Error: L6218E:Undefined symbol APPWCompareIsGreaterOrEqual(referred from id screen warning.o
\Temp\Obj\B1inky.axf: Error: L6218E:Undefined symbol APeW
CompareIsLessOrEqual(referred from id screen_warning.o).
.\Temp\Obj\B1inky.axf: Error: L6218E: Undefined symbol APPW_CreatePersistentScreens (referred from appw_maintask.o).
.\Temp\Obj\Blinky.axf: Error: L6218E:Undefined symbol APPW_CreateRoot (referred from appw_maintask.o).
.\Temp\Obj\Blinky.axf: Error: L6218E:Undefined symbol APPW_Exec (referred from appw_maintask.o).
.\Temp\0bj\Blinky.axf: Error: L6218E: Undefined symbol APpW_Init (referred from appw_maintask.o).
 楼主| 发表于 2024-1-2 10:49:28 | 显示全部楼层
\Temp\Obj\Blinky.axf: Error: L6218E:Undefined symbol APPW SetSupportScroller (referred from appwconf.o).
\Temp\Obj\Blinky.axf: Error6218E:Undefined symbol APPW_TextInitMem (referred from appwconf.o).
\Temp\Obj\Blinky.axf:Error6218E:Undefined symbol APPW CompareIsEqual(referred from id screen main.o).
.\Temp\Obj\Blinky.axf: Error: L6218E: Undefined symbol WM OBJECT GAUGE Create (referred from id screen main.o).
.\Temp\Obj\Blinky.axf: Error: L6218E: Undefined symbol WM OBJECT IMAGE Create(referred from id screen main.o).
\Temp\Obj\B1inky.axf: Error: L6218E:Undefined symbolWM OBJECT WINDOW Create (referred from id_screen_main.o).
\Temp\Obj\B1inky.axf: Error: L6218E:Undefined symbol APPWCompareIsLessOrEqual(referred from id screen_warning.o).
发表于 2024-1-2 11:15:05 | 显示全部楼层
 楼主| 发表于 2024-1-2 11:28:39 | 显示全部楼层
eric2013 发表于 2024-1-2 11:15
教程第34章要看下
https://www.armbbs.cn/forum.php?mod=viewthread&tid=98429
看了一下34章,只说了移植方案,我已经按照教程方法将所有的Private.h 文件移植到工程,但是依然会有报错出现
发表于 2024-1-2 11:51:37 | 显示全部楼层
O513 发表于 2024-1-2 11:28
看了一下34章,只说了移植方案,我已经按照教程方法将所有的Private.h 文件移植到工程,但是依然会有报错 ...
那就先用跟我一样的版本吧,新版的,后面我试试,最近一直忙别的,还没有顾上测试最新版
 楼主| 发表于 2024-1-3 09:18:36 | 显示全部楼层
使用了一样的版本,但是依然会报错,是不是因为AMR9的.lib库不支持这些指令?
发表于 2024-1-10 14:52:59 | 显示全部楼层
你好,
这个 emwin的版本是V6.34 版本的能否发上来共享一下哈 ?
发表于 2024-1-11 10:17:04 | 显示全部楼层
ARM9的话,使用M3的库试试,不要使用M4的库。
发表于 2024-1-11 10:18:02 | 显示全部楼层
hpdell 发表于 2024-1-10 14:52
你好,
还没有6.34的单片机版。
发表于 2024-1-11 11:49:56 | 显示全部楼层
eric2013 发表于 2024-1-11 10:18
还没有6.34的单片机版。
appWizard 发布产品也不搞个全套的,
 楼主| 发表于 2024-1-11 16:44:51 | 显示全部楼层
使用M3的库报错很多
Object wm_setscrollbar.o contains Build Attributes that are incompatible with the provided attributes.
    Tag_CPU_arch = ARM v7 (=10)
    Tag_CPU_arch_profile = The microcontroller profile 'M' (e.g. for Cortex M3) (=77)
    Tag_THUMB_ISA_use = Thumb2 instructions were permitted (implies Thumb instructions permitted) (=2)
    Tag_ARM_ISA_use = No ARM instructions were permitted to be used (=0)
.\Temp\Obj\Blinky.axf: Error: L6242E: Cannot link object wm_setscrollbar.o as its attributes are incompatible with the image attributes.
   ... arm-isa clashes with m-profile.
.\Temp\Obj\Blinky.axf: Error: L6367E: wm_setscrollbar.o(.ARM.RL_ARM6) attributes are not compatible with the provided attributes .
Not enough information to produce a FEEDBACK file.
Not enough information to list image symbols.
Not enough information to list the image map.
Finished: 40647 information, 0 warning and 13548 error messages.
".\Temp\Obj\Blinky.axf" - 13548 Error(s), 8 Warning(s).
GMT+8, 2025-5-25 12:36 , Processed in 0.429406 second(s), 24 queries .
