查看: 635|回复: 3
[FreeRTOS] 遇到,xtaskincrementtick 跳不出来
发表于 2024-1-16 13:40:18 | 显示全部楼层 |阅读模式
freertos新手,第一次在项目中使用。有大佬提供思路没,或者解决,有偿!
BaseType_t xTaskIncrementTick( void )
TCB_t * pxTCB;
TickType_t xItemValue;
BaseType_t xSwitchRequired = pdFALSE;
	/* Called by the portable layer each time a tick interrupt occurs.
	Increments the tick then checks to see if the new tick value will cause any
	tasks to be unblocked. */
	traceTASK_INCREMENT_TICK( xTickCount );
	if( uxSchedulerSuspended == ( UBaseType_t ) pdFALSE )
		/* Increment the RTOS tick, switching the delayed and overflowed
		delayed lists if it wraps to 0. */
		++xTickCount;
			/* Minor optimisation.  The tick count cannot change in this
			block. */
			const TickType_t xConstTickCount = xTickCount;
			if( xConstTickCount == ( TickType_t ) 0U )
				taskSWITCH_DELAYED_LISTS();
				mtCOVERAGE_TEST_MARKER();
			/* See if this tick has made a timeout expire.  Tasks are stored in
			the	queue in the order of their wake time - meaning once one task
			has been found whose block time has not expired there is no need to
			look any further down the list. */
			if( xConstTickCount >= xNextTaskUnblockTime )
				for( ;; )
					if( listLIST_IS_EMPTY( pxDelayedTaskList ) != pdFALSE )
						/* The delayed list is empty.  Set xNextTaskUnblockTime
						to the maximum possible value so it is extremely
						unlikely that the
						if( xTickCount >= xNextTaskUnblockTime ) test will pass
						next time through. */
						xNextTaskUnblockTime = portMAX_DELAY;
						/* The delayed list is not empty, get the value of the
						item at the head of the delayed list.  This is the time
						at which the task at the head of the delayed list must
						be removed from the Blocked state. */
						pxTCB = ( TCB_t * ) listGET_OWNER_OF_HEAD_ENTRY( pxDelayedTaskList );
						xItemValue = listGET_LIST_ITEM_VALUE( &( pxTCB->xGenericListItem ) );
						if( xConstTickCount < xItemValue )
							/* It is not time to unblock this item yet, but the
							item value is the time at which the task at the head
							of the blocked list must be removed from the Blocked
							state -	so record the item value in
							xNextTaskUnblockTime. */
							xNextTaskUnblockTime = xItemValue;
						/* It is time to remove the item from the Blocked state. */
						( void ) uxListRemove( &( pxTCB->xGenericListItem ) );
						/* Is the task waiting on an event also?  If so remove
						it from the event list. */
						if( listLIST_ITEM_CONTAINER( &( pxTCB->xEventListItem ) ) != NULL )
							( void ) uxListRemove( &( pxTCB->xEventListItem ) );
						/* Place the unblocked task into the appropriate ready
						list. */
						prvAddTaskToReadyList( pxTCB );
						/* A task being unblocked cannot cause an immediate
						context switch if preemption is turned off. */
						#if (  configUSE_PREEMPTION == 1 )
							/* Preemption is on, but a context switch should
							only be performed if the unblocked task has a
							priority that is equal to or higher than the
							currently executing task. */
							if( pxTCB->uxPriority >= pxCurrentTCB->uxPriority )
								xSwitchRequired = pdTRUE;
						#endif /* configUSE_PREEMPTION */
		/* Tasks of equal priority to the currently running task will share
		processing time (time slice) if preemption is on, and the application
		writer has not explicitly turned time slicing off. */
		#if ( ( configUSE_PREEMPTION == 1 ) && ( configUSE_TIME_SLICING == 1 ) )
			if( listCURRENT_LIST_LENGTH( &( pxReadyTasksLists[ pxCurrentTCB->uxPriority ] ) ) > ( UBaseType_t ) 1 )
		#endif /* ( ( configUSE_PREEMPTION == 1 ) && ( configUSE_TIME_SLICING == 1 ) ) */
		#if ( configUSE_TICK_HOOK == 1 )
			/* Guard against the tick hook being called when the pended tick
			count is being unwound (when the scheduler is being unlocked). */
			if( uxPendedTicks == ( UBaseType_t ) 0U )
				vApplicationTickHook();
		#endif /* configUSE_TICK_HOOK */
		++uxPendedTicks;
		/* The tick hook gets called at regular intervals, even if the
		scheduler is locked. */
		if( xYieldPending != pdFALSE )
	return xSwitchRequired;
 楼主| 发表于 2024-1-16 14:06:50 | 显示全部楼层
这是卡死的位置
发表于 2024-1-17 08:58:07 | 显示全部楼层
卡在这个位置,说明你的程序跑飞了,仅开一个任务排查下,逐步开启其它任务,如果一个任务也卡,说明程序移植有问题。
 楼主| 发表于 2024-1-17 10:58:30 | 显示全部楼层
嗯好的我试试
GMT+8, 2024-5-14 15:46 , Processed in 0.809329 second(s), 29 queries .
