查看: 1011|回复: 3
[有问必答] STM32G473的TIM2&TIM5输出异常,怀疑内核问题
发表于 2024-6-24 09:48:08 | 显示全部楼层 |阅读模式
使用STM32F473VET6(M4内核)初始化了8个TIM输出8路PWM,发现TIM2&TIM5重新赋值后使能pwm输出,发现其余6路的PWM会正常输出,而TIM2&TIM5的pwm会延时后(大约15S)输出。
附代码
/* USER CODE BEGIN Header */
  * @file           : main.c
  * @brief          : Main program body
  * @attention
  * Copyright (c) 2024 STMicroelectronics.
  * All rights reserved.
  * This software is licensed under terms that can be found in the LICENSE file
  * in the root directory of this software component.
  * If no LICENSE file comes with this software, it is provided AS-IS.
/* USER CODE END Header */
/* Includes ------------------------------------------------------------------*/
#include "main.h"
#include "tim.h"
#include "usart.h"
#include "gpio.h"
/* Private includes ----------------------------------------------------------*/
/* USER CODE BEGIN Includes */
#include "stdio.h"
/* USER CODE END Includes */
/* Private typedef -----------------------------------------------------------*/
/* USER CODE BEGIN PTD */
/* USER CODE END PTD */
/* Private define ------------------------------------------------------------*/
/* USER CODE BEGIN PD */
/* USER CODE END PD */
/* Private macro -------------------------------------------------------------*/
/* USER CODE BEGIN PM */
/* USER CODE END PM */
/* Private variables ---------------------------------------------------------*/
/* USER CODE BEGIN PV */
/* USER CODE END PV */
/* Private function prototypes -----------------------------------------------*/
void SystemClock_Config(void);
/* USER CODE BEGIN PFP */
void user_debug(void);
/* USER CODE END PFP */
/* Private user code ---------------------------------------------------------*/
/* USER CODE BEGIN 0 */
/* USER CODE END 0 */
  * @brief  The application entry point.
  * @retval int
int main(void)
  /* USER CODE BEGIN 1 */
  /* USER CODE END 1 */
  /* MCU Configuration--------------------------------------------------------*/
  /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
  HAL_Init();
  /* USER CODE BEGIN Init */
  /* USER CODE END Init */
  /* Configure the system clock */
  SystemClock_Config();
  /* USER CODE BEGIN SysInit */
//__disable_irq();
  /* USER CODE END SysInit */
  /* Initialize all configured peripherals */
        #if 1
  MX_GPIO_Init();
  MX_TIM15_Init();
  MX_TIM16_Init();
  MX_TIM17_Init();
  MX_TIM1_Init();
  MX_TIM2_Init();
  MX_TIM3_Init();
  MX_TIM5_Init();
  MX_TIM20_Init();
  MX_USART1_UART_Init();
  /* USER CODE BEGIN 2 */
user_debug();
  TIM15->PSC = 1 - 1;
  TIM15->ARR = 42500 - 1;
  TIM15->CCR1 = 42500 / 2;
  TIM3->PSC = 1 - 1;
  TIM3->ARR = 42500 - 1;
  TIM3->CCR2 = 42500 / 2;
  TIM16->PSC = 1 - 1;
  TIM16->ARR = 42500 - 1;
  TIM16->CCR1 = 42500 / 2;
  TIM17->PSC = 1 - 1;
  TIM17->ARR = 42500 - 1;
  TIM17->CCR1 = 42500 / 2;
  TIM20->PSC = 1 - 1;
  TIM20->ARR = 42500 - 1;
  TIM20->CCR1 = 42500 / 2;
  TIM5->PSC = 1 - 1;
  TIM5->ARR = 42500 - 1;
  TIM5->CCR3 = 42500 / 2;
  TIM1->PSC = 1 - 1;
  TIM1->ARR = 42500 - 1;
  TIM1->CCR2 = 42500 / 2;
  TIM2->PSC = 1 - 1;
  TIM2->ARR = 42500 - 1;
  TIM2->CCR3 = 42500 / 2;
  HAL_TIM_PWM_Start(&htim15, TIM_CHANNEL_1);
  HAL_TIM_PWM_Start(&htim3, TIM_CHANNEL_2);
  HAL_TIM_PWM_Start(&htim16, TIM_CHANNEL_1);
  HAL_TIM_PWM_Start(&htim17, TIM_CHANNEL_1);
  HAL_TIM_PWM_Start(&htim20, TIM_CHANNEL_1);
  HAL_TIM_PWM_Start(&htim5, TIM_CHANNEL_3);
  HAL_TIM_PWM_Start(&htim1, TIM_CHANNEL_2);
  HAL_TIM_PWM_Start(&htim2, TIM_CHANNEL_3);
//  HAL_GPIO_WritePin(Relay_1_GPIO_Port, Relay_1_Pin, GPIO_PIN_SET);
  user_debug();
  HAL_Delay(1000);
  HAL_TIM_PWM_Stop(&htim15, TIM_CHANNEL_1);
  HAL_TIM_PWM_Stop(&htim3, TIM_CHANNEL_2);
  HAL_TIM_PWM_Stop(&htim16, TIM_CHANNEL_1);
  HAL_TIM_PWM_Stop(&htim17, TIM_CHANNEL_1);
  HAL_TIM_PWM_Stop(&htim20, TIM_CHANNEL_1);
  HAL_TIM_PWM_Stop(&htim5, TIM_CHANNEL_3);
  HAL_TIM_PWM_Stop(&htim1, TIM_CHANNEL_2);
  HAL_TIM_PWM_Stop(&htim2, TIM_CHANNEL_3);
//  HAL_GPIO_WritePin(Relay_1_GPIO_Port, Relay_1_Pin, GPIO_PIN_RESET);
  HAL_Delay(1000);
  user_debug();
// /* USER CODE BEGIN WHILE */
  TIM5->PSC = 1 - 1;
  TIM5->ARR = 11333 - 1;
  TIM5->CCR3 = 11333 / 2;
  TIM2->PSC = 1 - 1;
  TIM2->ARR = 11333 - 1;
  TIM2->CCR3 = 11333 / 2;
  /*TIM2和TIM5重新赋值后 启动8路PWM输出 TIM2和TIM5大约会延时15s后输出 (对其余6个定时器重新赋值没有影响)*/
  /* USER CODE END 2 */
  /* Infinite loop */
  while (1)
    /* USER CODE END WHILE */
    /* USER CODE BEGIN 3 */
  /* USER CODE END 3 */
  * @brief System Clock Configuration
  * @retval None
  RCC_OscInitTypeDef RCC_OscInitStruct = {0};
  RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
  /** Configure the main internal regulator output voltage
  HAL_PWREx_ControlVoltageScaling(PWR_REGULATOR_VOLTAGE_SCALE1_BOOST);
  /** Initializes the RCC Oscillators according to the specified parameters
  * in the RCC_OscInitTypeDef structure.
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
  RCC_OscInitStruct.HSEState = RCC_HSE_ON;
  RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
  RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
  RCC_OscInitStruct.PLL.PLLM = RCC_PLLM_DIV6;
  RCC_OscInitStruct.PLL.PLLN = 85;
  RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV2;
  RCC_OscInitStruct.PLL.PLLQ = RCC_PLLQ_DIV2;
  RCC_OscInitStruct.PLL.PLLR = RCC_PLLR_DIV2;
  if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
    Error_Handler();
  /** Initializes the CPU, AHB and APB buses clocks
  RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
                              |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
  RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
  RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
  RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1;
  RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
  if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_4) != HAL_OK)
    Error_Handler();
/* USER CODE BEGIN 4 */
void HAL_IncTick(void)
  uwTick += uwTickFreq;
int fputc(int ch, FILE *f)
  HAL_UART_Transmit(&huart1, (uint8_t *)&ch, 1, 1000);
  return (ch);
  uint32_t CPU_Sn0, CPU_Sn1, CPU_Sn2;
  CPU_Sn0 = *(__IO uint32_t *)(0x1FFF7590);
  CPU_Sn1 = *(__IO uint32_t *)(0x1FFF7590 + 4);
  CPU_Sn2 = *(__IO uint32_t *)(0x1FFF7590 + 8);
  printf("CPU : STM32G473VET6, LQFP100, Fre: %dMHz\r\n", SystemCoreClock / 1000000);
  printf("UID = %08X %08X %08X\n\r", CPU_Sn2, CPU_Sn1, CPU_Sn0);
/* USER CODE END 4 */
  * @brief  This function is executed in case of error occurrence.
  * @retval None
void Error_Handler(void)
  /* USER CODE BEGIN Error_Handler_Debug */
  /* User can add his own implementation to report the HAL error return state */
  __disable_irq();
  while (1)
  /* USER CODE END Error_Handler_Debug */
#ifdef  USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *         where the assert_param error has occurred.
  * @param  file: pointer to the source file name
  * @param  line: assert_param error line source number
  * @retval None
void assert_failed(uint8_t *file, uint32_t line)
  /* USER CODE BEGIN 6 */
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* USER CODE END 6 */
#endif /* USE_FULL_ASSERT */
TIM2&TIM5刚好挂在一起
TIM2&TIM5刚好挂在一起
 楼主| 发表于 2024-6-24 09:55:03 | 显示全部楼层
在mdk dubug 使能定时器后CEN都正常置1,计数器正常计数,但是无PWM输出
发表于 2024-6-25 15:03:28 | 显示全部楼层
注意TIM2和TIM5是32bit定时器。其他都是16bit的
发表于 2024-9-6 22:23:57 | 显示全部楼层
你写的ARR和CCR都是写在了预装寄存器里,而不是反应到真正起作用的影子寄存器上,要到下一次更新事件(UEV: update event)才刷进去。
下一次更新要等CNT>=ARR溢出。32溢出很慢,16位溢出很快,所以你的所有写设置,实际上都是在TIMx下一次溢出才起作用的。
如何直接操作影子寄存器?PSC没法子只能等UEV,ARR可以设CR1的ARPE=0取消预装功能。通道的CCRx也是:CCMRx的OCxPE=0取消预装功能,直接操作CCRx影子寄存器。
还有一个方法:你设置完成准备开动时,强制TIMx的UG=1,也就是强行发出一个UEV事件,也能立刻更新你的配置到影子寄存器。
GMT+8, 2025-4-28 15:11 , Processed in 0.438901 second(s), 28 queries .
