查看: 769|回复: 4
[GUI] 【求助】GUIX屏幕闪烁,点击按钮显示残影
发表于 2024-8-15 06:43:21 | 显示全部楼层 |阅读模式
我使用STM32H750,一直GUIX,静态显示正常,点击按钮后显示有问题。
RGB屏:1024*600
SDRAM: 32M,带宽16位
LTDC配置:
hltdc.Instance = LTDC;
  hltdc.Init.HSPolarity = LTDC_HSPOLARITY_AL;
  hltdc.Init.VSPolarity = LTDC_VSPOLARITY_AL;
  hltdc.Init.DEPolarity = LTDC_DEPOLARITY_AL;
  hltdc.Init.PCPolarity = LTDC_PCPOLARITY_IPC;
  hltdc.Init.HorizontalSync = 0;
  hltdc.Init.VerticalSync = 0;
  hltdc.Init.AccumulatedHBP = 160;
  hltdc.Init.AccumulatedVBP = 23;
  hltdc.Init.AccumulatedActiveW = 1184;
  hltdc.Init.AccumulatedActiveH = 623;
  hltdc.Init.TotalWidth = 1200;
  hltdc.Init.TotalHeigh = 624;
  hltdc.Init.Backcolor.Blue = 0;
  hltdc.Init.Backcolor.Green = 0;
  hltdc.Init.Backcolor.Red = 0;
  if (HAL_LTDC_Init(&hltdc) != HAL_OK)
    Error_Handler();
  pLayerCfg.WindowX0 = 0;
  pLayerCfg.WindowX1 = 1024;
  pLayerCfg.WindowY0 = 0;
  pLayerCfg.WindowY1 = 600;
  pLayerCfg.PixelFormat = LTDC_PIXEL_FORMAT_RGB888;
  pLayerCfg.Alpha = 255;
  pLayerCfg.Alpha0 = 255;
  pLayerCfg.BlendingFactor1 = LTDC_BLENDING_FACTOR1_CA;
  pLayerCfg.BlendingFactor2 = LTDC_BLENDING_FACTOR2_CA;
  pLayerCfg.FBStartAdress = 0xD0000000;
  pLayerCfg.ImageWidth = 1024;
  pLayerCfg.ImageHeight = 600;
  pLayerCfg.Backcolor.Blue = 0;
  pLayerCfg.Backcolor.Green = 0;
  pLayerCfg.Backcolor.Red = 0;
  if (HAL_LTDC_ConfigLayer(&hltdc, &pLayerCfg, 0) != HAL_OK)
    Error_Handler();
使用gx_display_driver_stm32h7_24xrgb.c
static void stm32h7_24xrgb_buffer_toggle(GX_CANVAS *canvas, GX_RECTANGLE *dirty)
        GX_RECTANGLE    Limit;
//        GX_RECTANGLE    Copy;
        ULONG           offset;
        INT             copy_width;
        INT             copy_height;
#if !defined(GX_CHROMEART_ENABLE)
        INT             row;
        INT             src_stride_ulongs;
        INT             dest_stride_ulongs;
        ULONG *get;
        ULONG *put;
        gx_utility_rectangle_define(&Limit, 0, 0,
                                                canvas->gx_canvas_x_resolution - 1,
                                                canvas->gx_canvas_y_resolution - 1);
        if (gx_utility_rectangle_overlap_detect(&Limit, dirty, dirty))
                copy_width = dirty->gx_rectangle_right - dirty->gx_rectangle_left;
                copy_height = dirty->gx_rectangle_bottom - dirty->gx_rectangle_top;
                /* 从canvas读取更新区 */
                offset = dirty->gx_rectangle_top * canvas->gx_canvas_x_resolution + dirty->gx_rectangle_left;
                get = canvas ->gx_canvas_memory + offset;
                /* 从LCD显存读取要更新的区域,将canvas更新的数据复制进来 */
                put = (ULONG *) FrameBufer;
                offset = (canvas->gx_canvas_display_offset_y + dirty->gx_rectangle_top)* g_LcdWidth;
                offset += canvas->gx_canvas_display_offset_x + dirty->gx_rectangle_left;
                put += offset;
                src_stride_ulongs = canvas ->gx_canvas_x_resolution;
                dest_stride_ulongs = g_LcdWidth;
                for(row = 0; row < copy_height; row++)
                        memcpy(put, get, copy_width * 4);
                        put += dest_stride_ulongs;
                        get += src_stride_ulongs;
#else
          DMA2D->CR &= ~(DMA2D_CR_START);
    DMA2D->CR = DMA2D_M2M_PFC;
                DMA2D->FGMAR = (uint32_t)get;
                DMA2D->OMAR = (uint32_t)put;
                DMA2D->FGOR = canvas->gx_canvas_x_resolution - copy_width;
                DMA2D->OOR = g_LcdWidth - copy_width;
    DMA2D->FGPFCCR = LTDC_PIXEL_FORMAT_ARGB8888;
                DMA2D->OPFCCR = LTDC_PIXEL_FORMAT_RGB888;
    DMA2D->NLR = (uint32_t)(copy_width << 16) | (uint16_t)copy_height;
    /* 启动DMA2D */
    DMA2D->CR |= DMA2D_CR_START;
    /* 等待DMA2D传输结束 */
    while ((DMA2D->ISR & (DMA2D_FLAG_TC)) == 0){}
    /* 清除DMA2D传输完成标志 */
    DMA2D->IFCR |= DMA2D_FLAG_TC;
*        函 数 名: stm32h7_graphics_driver_setup_24xrgb
*        功能说明: 驱动接口函数
*        形    参: --
*        返 回 值: GX_SUCCESS
UINT stm32h7_graphics_driver_setup_24xrgb(GX_DISPLAY *display)
        _gx_display_driver_24xrgb_setup(display, (VOID*)STM32_SCREEN_HANDLE, stm32h7_24xrgb_buffer_toggle);
  //_gx_display_driver_32argb_setup(display, (VOID*)STM32_SCREEN_HANDLE, stm32h7_24xrgb_buffer_toggle);
#if defined(GX_CHROMEART_ENABLE)
  display -> gx_display_driver_pixelmap_blend     = gx_chromeart_pixelmap_blend;
        display -> gx_display_driver_pixelmap_draw      = gx_chromeart_pixelmap_draw;
        display -> gx_display_driver_canvas_copy        = gx_chromeart_canvas_copy;
  display -> gx_display_driver_horizontal_line_draw = gx_chromeart_horizontal_line_draw;
  display -> gx_display_driver_vertical_line_draw = gx_chromeart_vertical_line_draw;
        display -> gx_display_driver_8bit_glyph_draw    = gx_chromeart_glyph_8bit_draw;
    return(GX_SUCCESS);
静态显示
静态显示
点击按钮
点击按钮
发表于 2024-8-15 09:54:20 | 显示全部楼层
这个加速去掉,看看正常不
 楼主| 发表于 2024-8-15 22:01:06 | 显示全部楼层
eric2013 发表于 2024-8-15 09:54
这个加速去掉,看看正常不
感谢硬汉,去掉试过,也是一样。点击其他地方,屏幕会闪横的条纹。
发表于 2024-8-16 09:45:07 | 显示全部楼层
合理配置下MPU/Cache试试,参考我们工程的配置方式
发表于 2024-8-16 10:26:18 | 显示全部楼层
我之前出现同样的问题,把LTDC时钟降低就好了。LCD数据手册上写着支持50Mhz,但就是花屏,降到20、30Mhz才稳定。
GMT+8, 2025-4-29 06:19 , Processed in 0.349688 second(s), 28 queries .
