int main(void)
OLED_GPIOInit();
MyRTC_Init();
AD_Init();
ESP_Init();
Store_Init();
Count_Init();
Serial_UsartInit();
Modbus_Init();
Modbus_TimeIRQInit();
W25QXX_Init();
Encoder_Init();
RCC_APB1PeriphClockCmd(RCC_APB1Periph_PWR, ENABLE);
PWR_WakeUpPinCmd(ENABLE); //使能位于PA0的WKUP引脚,WKUP引脚上升沿唤醒待机模式
uint32_t Alarm = RTC_GetCounter() + 60;//60 //闹钟为唤醒后当前时间的后60s
RTC_SetAlarm(Alarm); //写入闹钟值到RTC的ALR寄存器
Clean = Count_Data[1];
Count = Count_Data[2];
Count++;
OLED_GUIInit();
Paint_NewImage(Image_BW,OLED_W,OLED_H,0,WHITE);
OLED_Clear(WHITE);
Bry_Display();
mqttconn();
sys_data.error = Modbus_Event();
if(sys_data.error != 0x05&&sys_data.error != 0x06)//
switch(sys_data.error)
//如果错误码为ERR_CRC:表示未知错误
case 0x01:Flag = 0;break;
//如果错误码为ERR_CRC:表示地址错误
case 0x04:Flag = 3;break;
//如果错误码为ERR_ADDR:表示校验错误
case 0x03:Flag = 4;break;
default:break;
if(Count >= 2|Clean == 1)
OLED_Clear(WHITE);
OLED_GUIInit();
LCD_Display();
OLED_Display(Image_BW);
Count = 0;
Clean = 0;
Count_Data[1] = Clean;
Count_Data[2] = Count;
Count_Save();
else if(sys_data.error == 0x06)
OLED_Clear(WHITE);
OLED_GUIInit();
LCD_Display();
Count = 0;
Clean = 0;
Count_Save();
Flag = 1;
OLED_Clear(WHITE);
OLED_GUIInit();
LCD_Display();
Count = 0;
Count_Save();
Flag = 1;
Light();
PUB();
EPD_Sleep();
Delay_ms(1000);
PWR_EnterSTANDBYMode();
uint16_t MyRTC_Time[] = {2023, 1, 1, 23, 59, 55}; //定义全局的时间数组,数组内容分别为年、月、日、时、分、秒
void MyRTC_SetTime(void); //函数声明
* 函 数:RTC初始化
* 参 数:无
* 返 回 值:无
void MyRTC_Init(void)
/*开启时钟*/
RCC_APB1PeriphClockCmd(RCC_APB1Periph_PWR, ENABLE); //开启PWR的时钟
RCC_APB1PeriphClockCmd(RCC_APB1Periph_BKP, ENABLE); //开启BKP的时钟
/*备份寄存器访问使能*/
PWR_BackupAccessCmd(ENABLE); //使用PWR开启对备份寄存器的访问
if (BKP_ReadBackupRegister(BKP_DR1) != 0xA5A5) //通过写入备份寄存器的标志位,判断RTC是否是第一次配置
//if成立则执行第一次的RTC配置
RCC_LSEConfig(RCC_LSE_ON); //开启LSE时钟
while (RCC_GetFlagStatus(RCC_FLAG_LSERDY) != SET); //等待LSE准备就绪
RCC_RTCCLKConfig(RCC_RTCCLKSource_LSE); //选择RTCCLK来源为LSE
RCC_RTCCLKCmd(ENABLE); //RTCCLK使能
RTC_WaitForSynchro(); //等待同步
RTC_WaitForLastTask(); //等待上一次操作完成
RTC_SetPrescaler(32768 - 1); //设置RTC预分频器,预分频后的计数频率为1Hz
MyRTC_SetTime(); //设置时间,调用此函数,全局数组里时间值刷新到RTC硬件电路
BKP_WriteBackupRegister(BKP_DR1, 0xA5A5); //在备份寄存器写入自己规定的标志位,用于判断RTC是不是第一次执行配置
else //RTC不是第一次配置
进入待机模式后除非上拉wake引脚或者下拉NRST引脚唤醒单片机,不然单片机就一直睡着,请解答!!
