查看: 5766|回复: 4
[FreeRTOS] 新版FreeRTOS8.2.2 下载
发表于 2015-8-15 15:55:47 | 显示全部楼层 |阅读模式
FreeRTOS8.2.2更新内容如下
  Changes between V8.2.1 and V8.2.2 released August 12, 2015
    RTOS kernel updates:+ Added Intel IA32/x86 32-bit port.+ General maintenance.+ PRIVILEGED_FUNCTION and PRIVILEGED_DATA macros, which are used in memoryprotected systems, have been added to the newer event group and softwaretimer functions.+ Add the errno definitions used by FreeRTOS+ components into projdefs.h.+ Remove the restriction that prevented tick-less idle implementationswaiting indefinitely when software timers were used in the sameapplication.+ Introduce xTaskNotifyAndQueryFromISR() as the interrupt safe version ofxTaskNotifyAndQuery().+ Add additional NOPs to the MSP430X port layers to ensure strict compliancewith the hardware documentation.+ Microblaze port: Added option for port optimised task selection.+ Microblaze port: Previously tasks inherited the exception enable stateat the time the task was created.  Now all tasks are created withexceptions enabled if the Microblaze design supports exceptions.+ Windows port: Add additional safe guards to ensure the correct start upsequence and thread switching timing.+ Windows port: Improve the implementation of the port optimised taskselection assembly code.+ Update heap_4 and heap_5 to allow use on 64-bit processors.+ Simplify the code that creates a queue.+ General improved tick-less idle behaviour.+ Ensure none of the variables in the common kernel files are initialised toanything other than zero.+ Correct calculation of xHeapStructSize in heap_4 and heap_5.
    Demo application updates:
+ Added demo project for the new IA32/x86 port that targets the Galileohardware.+ Added MSP430FR5969 demos (previously provided as a separate download).+ Added FreeRTOS BSP repository for automatic creation of FreeRTOSapplications in the Xilinx SDK.+ Added Atmel Studio / GCC project for the SAMV71 (ARM Cortex-M7)+ Update Xilinx SDK projects to use version 2015.2 of the SDK.+ Remove Microblaze demos that were using obsolete tools.+ Add MSP43FR5969 IAR and CCS demos.
FreeRTOS+ Updates:
+ Updated FreeRTOS+Trace recorder library, which requires an update to theFreeRTOS+Trace application.+ Added Reliance Edge source code and demo application.  Reliance edge isa fail safe transactional file system ideal for applications that requirefile storage, and especially when high reliability is essential.+ Introduce configAPPLICATION_PROVIDES_cOutputBuffer to allow FreeRTOS+CLIusers to place the output buffer at a fixed memory address.+ Improve the NetworkInterface.c file provided for the Windows port ofFreeRTOS+UDP.
FreeRTOS官网下载地址
FreeRTOSv8.2.2.rar
11.85 MB, 下载次数: 2131
发表于 2015-8-15 16:56:29 | 显示全部楼层
非常感谢,V4板子就配套8.2.2的代码了。[s:151]
 楼主| 发表于 2015-8-15 17:56:28 | 显示全部楼层
那么快,不是8月12日才更新的吗?你那么快就用上了?
发表于 2015-8-15 18:21:46 | 显示全部楼层
回 gdqyjoy 的帖子
gdqyjoy:那么快,不是8月12日才更新的吗?你那么快就用上了? (2015-08-15 17:56)
还没有,我是我说打算。[s:149]
发表于 2015-8-17 18:54:31 | 显示全部楼层
整理下内容,方便发微信:
FreeRTOS升级到V8.2.2版本(更新日期2015-8-12)
官网下载地址:http://www.freertos.org/a00104.html
更新内容如下:
GMT+8, 2024-5-18 06:49 , Processed in 0.182768 second(s), 28 queries .
